pqAnimationScene is a representation for a vtkSMAnimationScene proxy. More...
#include <pqAnimationScene.h>
Public Slots | |
| void | play () |
| Play animation. More... | |
| void | pause () |
| Pause animation. More... | |
| void | setAnimationTime (double time) |
| Set the animation time. More... | |
Signals | |
| void | preAddedCue (pqAnimationCue *) |
| Fired before a new cue is added to the scene. More... | |
| void | addedCue (pqAnimationCue *) |
| Fired after a new cue has been added to the scene. More... | |
| void | preRemovedCue (pqAnimationCue *) |
| Fired before a cue is removed from the scene. More... | |
| void | removedCue (pqAnimationCue *) |
| Fired after a cue has been removed from the scene. More... | |
| void | cuesChanged () |
| Fired after cues have been added/removed. More... | |
| void | playModeChanged () |
| Emitted when the play mode changes. More... | |
| void | loopChanged () |
| Emitted when the looping state changes on the underlying proxy. More... | |
| void | clockTimeRangesChanged () |
| Emitted when the clock time ranges change. More... | |
| void | beginPlay (vtkObject *caller, unsigned long, void *, void *reversed) |
| Emitted when animation starts playing. More... | |
| void | endPlay (vtkObject *caller, unsigned long, void *, void *reversed) |
| Emitted when animation ends playing. More... | |
| void | tick (int percentCompleted) |
| Emitted when playing animation. More... | |
| void | animationTime (double time) |
| Emitted when playing (or when animation time for the scene is set). More... | |
| void | frameCountChanged () |
| Emitted when the number of frames changes. More... | |
| void | timeStepsChanged () |
| Emitted when the number of timesteps changes. More... | |
| void | timeLabelChanged () |
| Emitted when a source is changing the label that should be use for time. More... | |
Signals inherited from pqProxy | |
| void | nameChanged (pqServerManagerModelItem *) |
| Fired when the name of the proxy is changed. More... | |
| void | modifiedStateChanged (pqServerManagerModelItem *) |
| Fired when the modified status changes for the proxy. More... | |
| pqAnimationScene (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr) | |
| ~pqAnimationScene () override | |
| pqAnimationCue * | getCue (vtkSMProxy *proxy, const char *propertyname, int index) const |
Returns the cue that animates the given index of the given property on the given proxy, in this scene, if any. More... | |
| void | removeCues (vtkSMProxy *proxy) |
| Removes all cues which animate the indicated proxy, if any. More... | |
| void | removeCue (pqAnimationCue *cue) |
| Removes cue. More... | |
| bool | contains (pqAnimationCue *) const |
| returns true is the cue is present in this scene. More... | |
| QPair< double, double > | getClockTimeRange () const |
| Get the clock time range set on the animation scene proxy. More... | |
| QSet< pqAnimationCue * > | getCues () const |
| Get all the cues in this scene. More... | |
| double | getAnimationTime () const |
| Returns the current animation time. More... | |
| QList< double > | getTimeSteps () const |
| Returns the timesteps from the timekeeper for the animation scene. More... | |
| pqAnimationCue * | createCue (vtkSMProxy *proxy, const char *propertyname, int index) |
Creates and initializes a new cue that can animate the index of the property on the given proxy in this scene. More... | |
| pqAnimationCue * | createCue (vtkSMProxy *proxy, const char *propertyname, int index, const QString &cuetype) |
| pqAnimationCue * | createCue (const QString &cuetype) |
| pqAnimationCue * | createCue (const pqAnimatedPropertyInfo &propInfo) |
Public Member Functions inherited from pqProxy | |
| pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr) | |
| ~pqProxy () override | |
| Get the server on which this proxy exists. More... | |
| This is a convenience method. More... | |
| Get the name with which this proxy is registered on the server manager. More... | |
| Get the vtkSMProxy this object stands for. More... | |
| Gets whether or not the source has been modified. More... | |
| Sets whether or not the source has been modified. More... | |
| Returns the hints for this proxy, if any. More... | |
| Returns a list of all helper proxies. More... | |
| Returns a list of all the helper proxies added with a given key. More... | |
| Returns the keys for helper proxies. More... | |
| Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More... | |
| Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More... | |
| Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More... | |
| Return whether or not the user has modified the GUI name of the source. More... | |
Public Member Functions inherited from pqServerManagerModelItem | |
| pqServerManagerModelItem (QObject *parent=nullptr) | |
| ~pqServerManagerModelItem () override | |
| void | initializeCue (vtkSMProxy *proxy, const char *propertyname, int index, pqAnimationCue *cue) |
| Initializes the newly create animation cue with default keyframes. More... | |
Protected Member Functions inherited from pqProxy | |
| Make this pqProxy take on a new identity. More... | |
| virtual void | initialize () |
Protected Member Functions inherited from pqServerManagerModelItem | |
| All subclasses generally need some vtkEventQtSlotConnect instance to connect to VTK events. More... | |
Public Types inherited from pqProxy | |
| enum | ModifiedState { UNINITIALIZED, MODIFIED, UNMODIFIED } |
| The modification state of this proxy. More... | |
Static Public Member Functions inherited from pqProxy | |
| static pqProxy * | findProxyWithHelper (vtkSMProxy *aproxy, QString &key) |
| Returns a pqProxy instance, of any, whose helper proxy is the aproxy. More... | |
| static std::string | rstToHtml (const char *rstStr) |
| convert proxy documentation from RST to HTML (so that it can be used in Qt) More... | |
| static QString | rstToHtml (const QString &rstStr) |
Protected Slots inherited from pqProxy | |
| void | onProxyRegistered (const QString &, const QString &, vtkSMProxy *) |
| void | onProxyUnRegistered (const QString &, const QString &, vtkSMProxy *) |
It provides API to access AnimationCues in the scene and to the scene times.
Definition at line 21 of file pqAnimationScene.h.
| pqAnimationScene::pqAnimationScene | ( | const QString & | group, |
| const QString & | name, | ||
| vtkSMProxy * | proxy, | ||
| pqServer * | server, | ||
| QObject * | parent = nullptr |
| pqAnimationCue* pqAnimationScene::getCue | ( | vtkSMProxy * | proxy, |
| const char * | propertyname, | ||
| int | index | ||
| ) | const |
| pqAnimationCue* pqAnimationScene::createCue | ( | vtkSMProxy * | proxy, |
| int | index | ||
This method does not check is such a cue already exists, use getCue() before calling this to avoid duplicates.
| int | index, | ||
| const QString & | cuetype | ||
| pqAnimationCue* pqAnimationScene::createCue | ( | const QString & | cuetype | ) |
| pqAnimationCue* pqAnimationScene::createCue | ( | const pqAnimatedPropertyInfo & | propInfo | ) |
| void pqAnimationScene::removeCues | ( | vtkSMProxy * | proxy | ) |
| void pqAnimationScene::removeCue | ( | pqAnimationCue * | cue | ) |
Removes cue.
| bool pqAnimationScene::contains | ( | pqAnimationCue * | ) | const |
| QSet<pqAnimationCue*> pqAnimationScene::getCues | ( | ) | const |
| double pqAnimationScene::getAnimationTime | ( | ) | const |
| QList<double> pqAnimationScene::getTimeSteps | ( | ) | const |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
reversed is a pointer to boolean that indicates if the playback direction is backward
signal |
signal |
Argument is the percent of play completed.
signal |
time is the animation clock time.
signal |
signal |
signal |
slot |
Play animation.
slot |
Pause animation.
slot |
