animation scene for ParaView. More...
#include <vtkSMAnimationScene.h>
| enum | { UpdateStartEndTimesEvent = vtkCommand::UserEvent } |
| typedef vtkAnimationCue | Superclass |
Public Types inherited from vtkAnimationCue | |
| enum | TimeCodes |
| virtual double | GetSceneTime () |
| virtual void | SetOverrideStillRender (bool) |
| When set, we skip calling still render to render each frame. More... | |
| virtual bool | GetOverrideStillRender () |
| void | AddCue (vtkAnimationCue *cue) |
| Add/Remove an AnimationCue to/from the Scene. More... | |
| void | RemoveCue (vtkAnimationCue *cue) |
| void | RemoveAllCues () |
| int | GetNumberOfCues () |
| void | AddViewProxy (vtkSMViewProxy *proxy) |
| Add view proxies that are involved in the animation generated by this scene. More... | |
| void | RemoveViewProxy (vtkSMViewProxy *proxy) |
| void | RemoveAllViewProxies () |
| unsigned int | GetNumberOfViewProxies () |
| Access the view proxies. More... | |
| vtkSMViewProxy * | GetViewProxy (unsigned int cc) |
| void | SetTimeKeeper (vtkSMProxy *) |
| Set the time keeper. More... | |
| virtual vtkSMProxy * | GetTimeKeeper () |
| virtual void | SetLockStartTime (bool) |
| Lock the start time. More... | |
| virtual bool | GetLockStartTime () |
| virtual void | LockStartTimeOn () |
| virtual void | LockStartTimeOff () |
| virtual void | SetLockEndTime (bool) |
| Lock the end time. More... | |
| virtual bool | GetLockEndTime () |
| virtual void | LockEndTimeOn () |
| virtual void | LockEndTimeOff () |
| void | SetSceneTime (double time) |
| Sets the current animation time. More... | |
| virtual void | SetPlaybackTimeWindow (double, double) |
| Get/Set the Playback Window for this cue. More... | |
| void | SetPlaybackTimeWindow (double [2]) |
| virtual double * | GetPlaybackTimeWindow () |
| virtual void | GetPlaybackTimeWindow (double &, double &) |
| virtual void | GetPlaybackTimeWindow (double [2]) |
| void | SetLoop (int val) |
| Forwarded to vtkCompositeAnimationPlayer. More... | |
| int | GetLoop () |
| void | Play () |
| void | Reverse () |
| void | Stop () |
| void | GoToNext () |
| void | GoToPrevious () |
| void | GoToFirst () |
| void | GoToLast () |
| void | SetPlayMode (int val) |
| int | GetPlayMode () |
| void | SetNumberOfFrames (int val) |
| void | SetDuration (int vtkNotUsed(val)) |
| void | SetFramesPerTimestep (int val) |
| void | SetStride (int val) |
| virtual void | SetForceDisableCaching (bool) |
| Set to true to force caching to be disabled. More... | |
| virtual bool | GetForceDisableCaching () |
Public Member Functions inherited from vtkAnimationCue | |
| vtkAnimationCue * | NewInstance () const |
| virtual void | Tick (double currenttime, double deltatime, double clocktime) |
| virtual void | Initialize () |
| virtual void | Finalize () |
| virtual void | SetTimeMode (int mode) |
| virtual int | GetTimeMode () |
| void | SetTimeModeToRelative () |
| void | SetTimeModeToNormalized () |
| virtual void | SetStartTime (double) |
| virtual double | GetStartTime () |
| virtual void | SetEndTime (double) |
| virtual double | GetEndTime () |
| virtual double | GetAnimationTime () |
| virtual double | GetDeltaTime () |
| virtual double | GetClockTime () |
| static vtkSMAnimationScene * | New () |
| static vtkSMAnimationScene * | SafeDownCast (vtkObject *o) |
| static void | SetGlobalUseGeometryCache (bool) |
| Turn caching on/off globally. More... | |
| static bool | GetGlobalUseGeometryCache () |
Static Public Member Functions inherited from vtkAnimationCue | |
| static vtkAnimationCue * | SafeDownCast (vtkObjectBase *o) |
| static vtkAnimationCue * | New () |
| vtkSMAnimationScene () | |
| ~vtkSMAnimationScene () override | |
| void | StartCueInternal () override |
| Overridden to ensure that caching parameters are passed to the view correctly. More... | |
| void | TickInternal (double currenttime, double deltatime, double clocktime) override |
| void | EndCueInternal () override |
| void | TimeKeeperTimeRangeChanged () |
| Called when the timekeeper's time range changes. More... | |
| void | TimeKeeperTimestepsChanged () |
Protected Member Functions inherited from vtkAnimationCue | |
| vtkAnimationCue () | |
| ~vtkAnimationCue () | |
Protected Attributes | |
| bool | LockStartTime |
| bool | LockEndTime |
| bool | InTick |
| double | SceneTime |
| double | PlaybackTimeWindow [2] |
| bool | ForceDisableCaching |
| vtkSMProxy * | TimeKeeper |
| vtkCompositeAnimationPlayer * | AnimationPlayer |
| vtkEventForwarderCommand * | Forwarder |
| bool | OverrideStillRender |
Protected Attributes inherited from vtkAnimationCue | |
| UNINITIALIZED | |
| INACTIVE | |
| ACTIVE | |
| double | StartTime |
| double | EndTime |
| int | TimeMode |
| double | AnimationTime |
| double | DeltaTime |
| double | ClockTime |
| int | CueState |
Public Attributes inherited from vtkAnimationCue | |
| TIMEMODE_NORMALIZED | |
| TIMEMODE_RELATIVE | |
vtkSMAnimationScene extends vtkAnimationCue to add support for a scene in ParaView.
We don't use vtkAnimationScene since ParaView has more elaborate playback requirements. To support that, this class delegates playback responsibility to vtkAnimationPlayer and subclasses.
vtkSMAnimationScene also is proxy-aware and hence can work with proxies and views proxies for updating property values, rendering, etc.
vtkSMAnimationScene forwards the vtkCommand::StartEvent and vtkCommand::EndEvent from vtkCompositeAnimationPlayer to mark the start and end of animation playback.
Definition at line 36 of file vtkSMAnimationScene.h.
Definition at line 40 of file vtkSMAnimationScene.h.
| anonymous enum |
| Enumerator | |
| UpdateStartEndTimesEvent | |
Definition at line 163 of file vtkSMAnimationScene.h.
Reimplemented from vtkAnimationCue.
| void vtkSMAnimationScene::AddCue | ( | vtkAnimationCue * | cue | ) |
It's an error to add a cue twice to the Scene.
| void vtkSMAnimationScene::RemoveCue | ( | vtkAnimationCue * | cue | ) |
| void vtkSMAnimationScene::RemoveAllCues | ( | ) |
| int vtkSMAnimationScene::GetNumberOfCues | ( | ) |
| void vtkSMAnimationScene::AddViewProxy | ( | vtkSMViewProxy * | proxy | ) |
When playing the animation, the scene will call StillRender() on the view proxies it is aware of, also updating any caching parameters.
| void vtkSMAnimationScene::RemoveViewProxy | ( | vtkSMViewProxy * | proxy | ) |
| void vtkSMAnimationScene::RemoveAllViewProxies | ( | ) |
| unsigned int vtkSMAnimationScene::GetNumberOfViewProxies | ( | ) |
| vtkSMViewProxy* vtkSMAnimationScene::GetViewProxy | ( | unsigned int | cc | ) |
| void vtkSMAnimationScene::SetTimeKeeper | ( | vtkSMProxy * | ) |
Time keeper is used to obtain the information about timesteps. This is required to play animation in "Snap To Timesteps" mode.
When locked, the StartTime won't be automatically updated when data time changes.
Lock the end time.
When locked, the EndTime won't be automatically updated when the data time changes.
Lock the end time.
Lock the end time.
Lock the end time.
Definition at line 106 of file vtkSMAnimationScene.h.
The Playback Window is use to mask out time that belong to a given cue but that we don't want to play back. This is particularly useful when we want to export a subset of an animation without recomputing any start and end value relative to the cue and the number of frame associated to it. This is used by the Animation Player to only play a subset of the cue. To disable it just make the lower bound bigger than the upper one.
| void vtkSMAnimationScene::SetPlaybackTimeWindow | ( | double | [2] | ) |
| void vtkSMAnimationScene::SetLoop | ( | int | val | ) |
| int vtkSMAnimationScene::GetLoop | ( | ) |
| void vtkSMAnimationScene::Play | ( | ) |
| void vtkSMAnimationScene::Reverse | ( | ) |
| void vtkSMAnimationScene::Stop | ( | ) |
| void vtkSMAnimationScene::GoToNext | ( | ) |
| void vtkSMAnimationScene::GoToPrevious | ( | ) |
| void vtkSMAnimationScene::GoToFirst | ( | ) |
| void vtkSMAnimationScene::GoToLast | ( | ) |
| void vtkSMAnimationScene::SetPlayMode | ( | int | val | ) |
| int vtkSMAnimationScene::GetPlayMode | ( | ) |
| void vtkSMAnimationScene::SetNumberOfFrames | ( | int | val | ) |
Definition at line 157 of file vtkSMAnimationScene.h.
| void vtkSMAnimationScene::SetFramesPerTimestep | ( | int | val | ) |
| void vtkSMAnimationScene::SetStride | ( | int | val | ) |
When false (default), caching is determined based on the value from vtkPVGeneralSettings::GetInstance()->GetCacheGeometryForAnimation().
Useful to avoid updating screen when saving animations to disk, for example.
Typically, on uses vtkPVGeneralSettings to toggle cache settings rather than using this API directly.
overrideprotectedvirtual |
Definition at line 220 of file vtkSMAnimationScene.h.
Definition at line 221 of file vtkSMAnimationScene.h.
Definition at line 222 of file vtkSMAnimationScene.h.
Definition at line 223 of file vtkSMAnimationScene.h.
Definition at line 224 of file vtkSMAnimationScene.h.
Definition at line 225 of file vtkSMAnimationScene.h.
Definition at line 226 of file vtkSMAnimationScene.h.
Definition at line 227 of file vtkSMAnimationScene.h.
Definition at line 228 of file vtkSMAnimationScene.h.
Definition at line 230 of file vtkSMAnimationScene.h.
