virtual void SetAnimationValue(vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
Set the value of an element of a property from the animation editor.
static vtkSMIntRangeDomain * New()
int range domain based on data set extent
virtual void Update(vtkSMProperty *requestingProperty)
Update self based on the "unchecked" values of all required properties.
virtual int SetDefaultValues(vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
type specific extension to vtkSMRangeDomainTemplate for ints.
