Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Friends | List of all members
vtkSMSelectionLink Class Reference
#include <vtkSMSelectionLink.h>
Inheritance diagram for vtkSMSelectionLink:
Collaboration diagram for vtkSMSelectionLink:
typedef vtkSMLink Superclass
unsigned int GetNumberOfLinkedObjects () override
 Get the number of properties that are involved in this link. More...
vtkSMProxy * GetLinkedProxy (int index) override
 Get a proxy involved in this link. More...
int GetLinkedObjectDirection (int index) override
 Get the direction of a Selection involved in this link (see vtkSMLink::UpdateDirections) More...
void RemoveAllLinks () override
 Remove all links. More...
 This method is used to initialize the object to the given protobuf state. More...
virtual void SetConvertToIndices (bool)
 Set/Get the convert to indices flag. More...
virtual bool GetConvertToIndices ()
void AddLinkedSelection (vtkSMProxy *proxy, int updateDir)
 Add a selection to the link. More...
void RemoveLinkedSelection (vtkSMProxy *proxy)
bool HasGlobalID ()
virtual void EnableLocalPushOnly ()
virtual void DisableLocalPushOnly ()
virtual void SetLocation (vtkTypeUInt32)
virtual void PrototypeOn ()
virtual void PrototypeOff ()
bool IsPrototype ()
virtual void SetPrototype (bool)
static vtkSMSelectionLink * New ()
static vtkSMSelectionLink * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMSelectionLink ()
 ~vtkSMSelectionLink () override
int LoadXMLState (vtkPVXMLElement *linkElement, vtkSMProxyLocator *locator) override
 Load the link state. More...
void SaveXMLState (const char *linkname, vtkPVXMLElement *parent) override
 Save the state of the link. More...
void UpdateVTKObjects (vtkSMProxy *vtkNotUsed(caller)) override
 Not implemented. More...
void PropertyModified (vtkSMProxy *vtkNotUsed(caller), const char *vtkNotUsed(pname)) override
void UpdateProperty (vtkSMProxy *vtkNotUsed(caller), const char *vtkNotUsed(pname)) override
virtual void SelectionModified (vtkSMSourceProxy *caller, unsigned int portIndex)
 This method find the caller in the link and update selection output accordingly. More...
void UpdateState () override
 Update the internal protobuf state. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
Friends
class vtkSMSelectionLinkInternals
class vtkSMSelectionLinkObserver
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
Creates a link between two properties. Can create M->N links. At the time when the link is created every output Selection is synchronized with the first input Selection.
Definition at line 21 of file vtkSMSelectionLink.h.
Definition at line 25 of file vtkSMSelectionLink.h.
◆ vtkSMSelectionLink()
vtkSMSelectionLink::vtkSMSelectionLink ( )
◆ ~vtkSMSelectionLink()
vtkSMSelectionLink::~vtkSMSelectionLink ( )
static vtkSMSelectionLink* vtkSMSelectionLink::New ( )
virtual const char* vtkSMSelectionLink::GetClassName ( )
Reimplemented from vtkSMLink.
static int vtkSMSelectionLink::IsTypeOf ( const char *  type)
virtual int vtkSMSelectionLink::IsA ( const char *  type)
static vtkSMSelectionLink* vtkSMSelectionLink::SafeDownCast ( vtkObject *  o)
void vtkSMSelectionLink::PrintSelf ( ostream &  os,
◆ AddLinkedSelection()
void vtkSMSelectionLink::AddLinkedSelection ( vtkSMProxy *  proxy,
int  updateDir
updateDir determines whether the proxy used is an input or an output. When a selection of an input proxy changes, it's selection is set to all other output proxies in the link. A selection can be set to be both input and output by adding 2 links, one to INPUT and the other to OUTPUT When a link is added, all output Selection values are synchronized with that of the input.
◆ RemoveLinkedSelection()
void vtkSMSelectionLink::RemoveLinkedSelection ( vtkSMProxy *  proxy)
◆ GetNumberOfLinkedObjects()
unsigned int vtkSMSelectionLink::GetNumberOfLinkedObjects ( )
Implements vtkSMLink.
◆ GetLinkedProxy()
vtkSMProxy* vtkSMSelectionLink::GetLinkedProxy ( int  index)
◆ GetLinkedObjectDirection()
int vtkSMSelectionLink::GetLinkedObjectDirection ( int  index)
◆ RemoveAllLinks()
void vtkSMSelectionLink::RemoveAllLinks ( )
Remove all links.
◆ LoadState()
void vtkSMSelectionLink::LoadState ( const vtkSMMessage *  msg,
vtkSMProxyLocator *  locator
◆ SetConvertToIndices()
virtual void vtkSMSelectionLink::SetConvertToIndices ( bool  )
When on, the input selection will always be converted into an indices based selection before being applied to outputs
◆ GetConvertToIndices()
virtual bool vtkSMSelectionLink::GetConvertToIndices ( )
◆ LoadXMLState()
int vtkSMSelectionLink::LoadXMLState ( vtkPVXMLElement *  linkElement,
overrideprotectedvirtual
◆ SaveXMLState()
void vtkSMSelectionLink::SaveXMLState ( const char *  linkname,
vtkPVXMLElement *  parent
◆ UpdateVTKObjects()
void vtkSMSelectionLink::UpdateVTKObjects ( vtkSMProxy *  vtkNotUsedcaller)
inlineoverrideprotected
Not implemented.
Definition at line 96 of file vtkSMSelectionLink.h.
◆ PropertyModified()
void vtkSMSelectionLink::PropertyModified ( vtkSMProxy *  vtkNotUsedcaller,
const char *  vtkNotUsedpname
Not implemented.
Definition at line 101 of file vtkSMSelectionLink.h.
◆ UpdateProperty()
void vtkSMSelectionLink::UpdateProperty ( vtkSMProxy *  vtkNotUsedcaller,
Not implemented.
Definition at line 106 of file vtkSMSelectionLink.h.
◆ SelectionModified()
virtual void vtkSMSelectionLink::SelectionModified ( vtkSMSourceProxy *  caller,
protectedvirtual
◆ UpdateState()
void vtkSMSelectionLink::UpdateState ( )
◆ vtkSMSelectionLinkInternals
friend class vtkSMSelectionLinkInternals
friend
Definition at line 80 of file vtkSMSelectionLink.h.
◆ vtkSMSelectionLinkObserver
friend class vtkSMSelectionLinkObserver
friend
Definition at line 81 of file vtkSMSelectionLink.h.
