vtkSMProxyDefinitionManager Class Reference
#include <vtkSMProxyDefinitionManager.h>
Inheritance diagram for vtkSMProxyDefinitionManager:
Collaboration diagram for vtkSMProxyDefinitionManager:
enum  Events { ProxyDefinitionsUpdated = vtkSIProxyDefinitionManager::ProxyDefinitionsUpdated, CompoundProxyDefinitionsUpdated = vtkSIProxyDefinitionManager::CompoundProxyDefinitionsUpdated }
enum  { ALL_DEFINITIONS = vtkSIProxyDefinitionManager::ALL_DEFINITIONS, CORE_DEFINITIONS = vtkSIProxyDefinitionManager::CORE_DEFINITIONS, CUSTOM_DEFINITIONS = vtkSIProxyDefinitionManager::CUSTOM_DEFINITIONS }
void SynchronizeDefinitions ()
 Synchronizes the client-side definitions using the server-side definitions, if applicable. More...
 Overridden call SynchronizeDefinitions() when the session changes. More...
vtkPVXMLElement * GetCollapsedProxyDefinition (const char *group, const char *name, const char *subProxyName, bool throwError)
 Returns the same thing as GetProxyDefinition in a flatten manner. More...
bool HasDefinition (const char *groupName, const char *proxyName)
 Return true if the XML Definition was found. More...
void SaveCustomProxyDefinitions (vtkPVXMLElement *root)
 Save registered custom proxy definitions. More...
vtkPVXMLElement * GetProxyDefinition (const char *group, const char *name, bool throwError)
 Returns a registered proxy definition or return a nullptr otherwise. More...
vtkPVXMLElement * GetProxyDefinition (const char *group, const char *name)
VTK_NEWINSTANCE vtkPVProxyDefinitionIterator * NewIterator ()
 Return a NEW instance of vtkPVProxyDefinitionIterator configured to get through all the definition available for the requested scope. More...
VTK_NEWINSTANCE vtkPVProxyDefinitionIterator * NewIterator (int scope)
vtkPVProxyDefinitionIterator * NewSingleGroupIterator (const char *groupName)
 Return a new configured iterator for traversing a set of proxy definition for only one GroupName. More...
vtkPVProxyDefinitionIterator * NewSingleGroupIterator (const char *groupName, int scope)
void AddCustomProxyDefinition (const char *group, const char *name, vtkPVXMLElement *top)
 Add/Remove/Clear custom proxy definitions. More...
void RemoveCustomProxyDefinition (const char *group, const char *name)
void ClearCustomProxyDefinitions ()
void LoadCustomProxyDefinitions (vtkPVXMLElement *root)
 Load custom proxy definitions and register them. More...
void LoadCustomProxyDefinitionsFromString (const char *xmlContent)
bool LoadConfigurationXML (vtkPVXMLElement *root)
 Loads server-manager configuration xml. More...
bool LoadConfigurationXMLFromString (const char *xmlContent)
bool HasGlobalID ()
virtual const vtkSMMessage * GetFullState ()
virtual void EnableLocalPushOnly ()
virtual void DisableLocalPushOnly ()
virtual void SetLocation (vtkTypeUInt32)
virtual void PrototypeOn ()
virtual void PrototypeOff ()
bool IsPrototype ()
virtual void SetPrototype (bool)
static vtkSMProxyDefinitionManager * New ()
static vtkSMProxyDefinitionManager * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMProxyDefinitionManager ()
 ~vtkSMProxyDefinitionManager () override
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
vtkEventForwarderCommand * Forwarder
vtkWeakPointer< vtkSIProxyDefinitionManager > ProxyDefinitionManager
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMProxyDefinitionManager is a remote-object that represents the vtkSIProxyDefinitionManager instance on all the processes. ParaView clients should use API on this class to add/update xml definitions to ensure that the xmls are processed/updated correctly on all the processes.
Definition at line 24 of file vtkSMProxyDefinitionManager.h.
Definition at line 28 of file vtkSMProxyDefinitionManager.h.
◆ Events
Enumerator
Definition at line 47 of file vtkSMProxyDefinitionManager.h.
◆ anonymous enum
anonymous enum
Enumerator
ALL_DEFINITIONS
CORE_DEFINITIONS
CUSTOM_DEFINITIONS
Definition at line 53 of file vtkSMProxyDefinitionManager.h.
◆ vtkSMProxyDefinitionManager()
vtkSMProxyDefinitionManager::vtkSMProxyDefinitionManager ( )
◆ ~vtkSMProxyDefinitionManager()
vtkSMProxyDefinitionManager::~vtkSMProxyDefinitionManager ( )
static vtkSMProxyDefinitionManager* vtkSMProxyDefinitionManager::New ( )
virtual const char* vtkSMProxyDefinitionManager::GetClassName ( )
Reimplemented from vtkSMRemoteObject.
static int vtkSMProxyDefinitionManager::IsTypeOf ( const char *  type)
virtual int vtkSMProxyDefinitionManager::IsA ( const char *  type)
static vtkSMProxyDefinitionManager* vtkSMProxyDefinitionManager::SafeDownCast ( vtkObject *  o)
void vtkSMProxyDefinitionManager::PrintSelf ( ostream &  os,
◆ SynchronizeDefinitions()
void vtkSMProxyDefinitionManager::SynchronizeDefinitions ( )
Call this method after any code that could result in changing of the XML definitions on the server e.g. loading of plugins.
◆ SetSession()
void vtkSMProxyDefinitionManager::SetSession ( vtkSMSession *  )
Also ensures that the internal references to vtkSIProxyDefinitionManager are updated correctly.
Reimplemented from vtkSMSessionObject.
◆ GetProxyDefinition() [1/2]
vtkPVXMLElement* vtkSMProxyDefinitionManager::GetProxyDefinition ( const char *  group,
const char *  name,
bool  throwError
inline
Moreover, error can be throw if the definition was not found if the flag throwError is true.
Definition at line 70 of file vtkSMProxyDefinitionManager.h.
◆ GetProxyDefinition() [2/2]
const char *  name
inline
Definition at line 76 of file vtkSMProxyDefinitionManager.h.
◆ GetCollapsedProxyDefinition()
vtkPVXMLElement* vtkSMProxyDefinitionManager::GetCollapsedProxyDefinition ( const char *  group,
const char *  name,
const char *  subProxyName,
bool  throwError
inline
By flatten, we mean that the class hierarchy has been walked and merged into a single vtkPVXMLElement definition.
Definition at line 89 of file vtkSMProxyDefinitionManager.h.
◆ HasDefinition()
bool vtkSMProxyDefinitionManager::HasDefinition ( const char *  groupName,
const char *  proxyName
inline
Definition at line 100 of file vtkSMProxyDefinitionManager.h.
◆ SaveCustomProxyDefinitions()
void vtkSMProxyDefinitionManager::SaveCustomProxyDefinitions ( vtkPVXMLElement *  root)
inline
The caller must release the reference to the returned vtkPVXMLElement.
Definition at line 111 of file vtkSMProxyDefinitionManager.h.
◆ NewIterator() [1/2]
VTK_NEWINSTANCE vtkPVProxyDefinitionIterator* vtkSMProxyDefinitionManager::NewIterator ( )
inline
Possible scope defined as enum inside vtkSIProxyDefinitionManager: ALL_DEFINITIONS=0 / CORE_DEFINITIONS=1 / CUSTOM_DEFINITIONS=2 Some extra restriction can be set directly on the iterator itself by setting a set of GroupName...
Definition at line 129 of file vtkSMProxyDefinitionManager.h.
◆ NewIterator() [2/2]
VTK_NEWINSTANCE vtkPVProxyDefinitionIterator* vtkSMProxyDefinitionManager::NewIterator ( int  scope)
inline
Definition at line 134 of file vtkSMProxyDefinitionManager.h.
◆ NewSingleGroupIterator() [1/2]
vtkPVProxyDefinitionIterator* vtkSMProxyDefinitionManager::NewSingleGroupIterator ( const char *  groupName)
inline
Definition at line 148 of file vtkSMProxyDefinitionManager.h.
◆ NewSingleGroupIterator() [2/2]
vtkPVProxyDefinitionIterator* vtkSMProxyDefinitionManager::NewSingleGroupIterator ( const char *  groupName,
int  scope
inline
Definition at line 154 of file vtkSMProxyDefinitionManager.h.
◆ AddCustomProxyDefinition()
void vtkSMProxyDefinitionManager::AddCustomProxyDefinition ( const char *  group,
const char *  name,
vtkPVXMLElement *  top
◆ RemoveCustomProxyDefinition()
void vtkSMProxyDefinitionManager::RemoveCustomProxyDefinition ( const char *  group,
const char *  name
◆ ClearCustomProxyDefinitions()
void vtkSMProxyDefinitionManager::ClearCustomProxyDefinitions ( )
◆ LoadCustomProxyDefinitions()
void vtkSMProxyDefinitionManager::LoadCustomProxyDefinitions ( vtkPVXMLElement *  root)
◆ LoadCustomProxyDefinitionsFromString()
void vtkSMProxyDefinitionManager::LoadCustomProxyDefinitionsFromString ( const char *  xmlContent)
◆ LoadConfigurationXML()
bool vtkSMProxyDefinitionManager::LoadConfigurationXML ( vtkPVXMLElement *  root)
◆ LoadConfigurationXMLFromString()
bool vtkSMProxyDefinitionManager::LoadConfigurationXMLFromString ( const char *  xmlContent)
◆ LoadState()
void vtkSMProxyDefinitionManager::LoadState ( const vtkSMMessage *  msg,
vtkSMProxyLocator *  locator
This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set.
This allow to split the load process in 2 step to prevent invalid state when property refere to a sub-proxy that does not exist yet.
◆ Forwarder
vtkEventForwarderCommand* vtkSMProxyDefinitionManager::Forwarder
Definition at line 204 of file vtkSMProxyDefinitionManager.h.
◆ ProxyDefinitionManager
vtkWeakPointer<vtkSIProxyDefinitionManager> vtkSMProxyDefinitionManager::ProxyDefinitionManager
Definition at line 205 of file vtkSMProxyDefinitionManager.h.
