vtkSIXMLAnimationWriterRepresentationProperty Class Reference
#include <vtkSIXMLAnimationWriterRepresentationProperty.h>
Inheritance diagram for vtkSIXMLAnimationWriterRepresentationProperty:
Collaboration diagram for vtkSIXMLAnimationWriterRepresentationProperty:
typedef vtkSIInputProperty Superclass
- Public Types inherited from vtkSIInputProperty
typedef vtkSIProxyProperty Superclass
- Public Types inherited from vtkSIProxyProperty
typedef vtkSIProperty Superclass
- Public Types inherited from vtkSIProperty
- Public Member Functions inherited from vtkSIInputProperty
virtual int GetPortIndex ()
 Controls which input port this property uses when making connections. More...
- Public Member Functions inherited from vtkSIProxyProperty
virtual bool GetNullOnEmpty ()
virtual char * GetCleanCommand ()
 Command that can be used to remove inputs. More...
virtual char * GetRemoveCommand ()
 Remove command is the command called to remove the VTK object on the server-side. More...
- Public Member Functions inherited from vtkSIProperty
virtual char * GetXMLName ()
 The name assigned by the xml parser. More...
virtual char * GetCommand ()
 The command name used to set the value on the server object. More...
virtual bool GetInformationOnly ()
 Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More...
virtual bool GetRepeatable ()
 If repeatable, a property can have 1 or more values of the same kind. More...
virtual void SetIsInternal (bool)
 This ivar is configured when the xml file is read and is mainly useful to trigger a method call. More...
virtual bool GetIsInternal ()
static vtkSIXMLAnimationWriterRepresentationProperty * New ()
static vtkSIXMLAnimationWriterRepresentationProperty * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSIInputProperty
static vtkSIInputProperty * New ()
static vtkSIInputProperty * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSIProxyProperty
static vtkSIProxyProperty * New ()
static vtkSIProxyProperty * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSIProperty
static vtkSIProperty * New ()
static vtkSIProperty * SafeDownCast (vtkObject *o)
 vtkSIXMLAnimationWriterRepresentationProperty ()
 ~vtkSIXMLAnimationWriterRepresentationProperty () override
bool Push (vtkSMMessage *, int) override
 Overridden to call AddRepresentation on the vtkXMLPVAnimationWriter instance with correct API. More...
- Protected Member Functions inherited from vtkSIInputProperty
 vtkSIInputProperty ()
 ~vtkSIInputProperty () override
 Push a new state to the underneath implementation. More...
bool ReadXMLAttributes (vtkSIProxy *proxyhelper, vtkPVXMLElement *element) override
 Parse the xml for the property. More...
virtual void SetPortIndex (int)
- Protected Member Functions inherited from vtkSIProxyProperty
 vtkSIProxyProperty ()
 ~vtkSIProxyProperty () override
virtual void SetNullOnEmpty (bool)
vtkObjectBase * GetObjectBase (vtkTypeUInt32 globalId)
bool IsValidNull (vtkTypeUInt32 globalId)
virtual void SetCleanCommand (const char *)
virtual void SetRemoveCommand (const char *)
- Protected Member Functions inherited from vtkSIProperty
 vtkSIProperty ()
 ~vtkSIProperty () override
vtkSIObject * GetSIObject (vtkTypeUInt32 globalid)
 Convenience method to obtain a vtkSIObject subclass given its global id. More...
virtual bool Pull (vtkSMMessage *)
 Pull the current state of the underneath implementation. More...
virtual void SetCommand (const char *)
void SaveValueToCache (vtkSMMessage *proxyStateUpdate, int offset)
bool ProcessMessage (vtkClientServerStream &stream)
 Interprets the message. More...
const vtkClientServerStream & GetLastResult ()
vtkObjectBase * GetVTKObject ()
- Protected Types inherited from vtkSIProxyProperty
enum  TypeArg { VTK, SMProxy, SIProxy }
- Protected Attributes inherited from vtkSIInputProperty
int PortIndex
- Protected Attributes inherited from vtkSIProxyProperty
bool NullOnEmpty
TypeArg ArgumentType
char * CleanCommand
char * RemoveCommand
- Protected Attributes inherited from vtkSIProperty
char * XMLName
char * Command
bool InformationOnly
bool Repeatable
bool IsInternal
vtkWeakPointer< vtkSIProxy > SIProxyObject
vtkSIXMLAnimationWriterRepresentationProperty extends vtkSIInputProperty to add push-API specific to vtkXMLPVAnimationWriter to add representations while assigning them unique names consistently across all processes.
Definition at line 17 of file vtkSIXMLAnimationWriterRepresentationProperty.h.
◆ vtkSIXMLAnimationWriterRepresentationProperty()
vtkSIXMLAnimationWriterRepresentationProperty::vtkSIXMLAnimationWriterRepresentationProperty ( )
◆ ~vtkSIXMLAnimationWriterRepresentationProperty()
vtkSIXMLAnimationWriterRepresentationProperty::~vtkSIXMLAnimationWriterRepresentationProperty ( )
static vtkSIXMLAnimationWriterRepresentationProperty* vtkSIXMLAnimationWriterRepresentationProperty::New ( )
virtual const char* vtkSIXMLAnimationWriterRepresentationProperty::GetClassName ( )
Reimplemented from vtkSIInputProperty.
static int vtkSIXMLAnimationWriterRepresentationProperty::IsTypeOf ( const char *  type)
virtual int vtkSIXMLAnimationWriterRepresentationProperty::IsA ( const char *  type)
static vtkSIXMLAnimationWriterRepresentationProperty* vtkSIXMLAnimationWriterRepresentationProperty::SafeDownCast ( vtkObject *  o)
void vtkSIXMLAnimationWriterRepresentationProperty::PrintSelf ( ostream &  os,
◆ Push()
bool vtkSIXMLAnimationWriterRepresentationProperty::Push ( vtkSMMessage *  ,
int
overrideprotectedvirtual
