vtkXMLPVAnimationWriter Class Reference
Data writer for ParaView. More...
#include <vtkXMLPVAnimationWriter.h>
Inheritance diagram for vtkXMLPVAnimationWriter:
Collaboration diagram for vtkXMLPVAnimationWriter:
typedef vtkXMLPVDWriter Superclass
- Public Types inherited from vtkXMLPVDWriter
typedef vtkXMLWriter Superclass
- Public Types inherited from vtkXMLWriter
enum  CompressorType
enum  DesiredOutputPrecision
void Start ()
 Start a new animation with the current set of inputs. More...
void WriteTime (double time)
 Write the current time step. More...
void Finish ()
 Finish an animation by writing the collection file. More...
void AddRepresentation (vtkAlgorithm *, const char *groupname)
 Add/Remove representations. More...
void RemoveAllRepresentations ()
- Public Member Functions inherited from vtkXMLPVDWriter
const char * GetDefaultFileExtension () override
 Get the default file extension for files written by this writer. More...
 Add an input of this algorithm. More...
int ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
virtual int GetPiece ()
 Get/Set the piece number to write. More...
virtual void SetPiece (int)
virtual int GetNumberOfPieces ()
 Get/Set the number of pieces into which the inputs are split. More...
virtual void SetNumberOfPieces (int)
virtual int GetGhostLevel ()
 Get/Set the number of ghost levels to be written for unstructured data. More...
virtual void SetGhostLevel (int)
virtual void SetWriteAllTimeSteps (int)
 When WriteAllTimeSteps is turned ON, the writer is executed once for each timestep available from its input. More...
virtual int GetWriteAllTimeSteps ()
virtual void WriteAllTimeStepsOn ()
virtual void WriteAllTimeStepsOff ()
virtual int GetWriteCollectionFile ()
 Get/Set whether this instance will write the main collection file. More...
virtual void SetWriteCollectionFile (int flag)
- Public Member Functions inherited from vtkXMLWriter
vtkXMLWriter * NewInstance () const
int Write ()
virtual void SetByteOrder (int)
virtual int GetByteOrder ()
void SetByteOrderToBigEndian ()
void SetByteOrderToLittleEndian ()
virtual void SetHeaderType (int)
virtual int GetHeaderType ()
void SetHeaderTypeToUInt32 ()
void SetHeaderTypeToUInt64 ()
virtual void SetIdType (int)
virtual int GetIdType ()
void SetIdTypeToInt32 ()
void SetIdTypeToInt64 ()
virtual char * GetFileName ()
virtual void SetWriteToOutputString (int)
virtual int GetWriteToOutputString ()
virtual void WriteToOutputStringOn ()
virtual void WriteToOutputStringOff ()
std::string GetOutputString ()
virtual void SetCompressor (vtkDataCompressor *)
virtual vtkDataCompressor * GetCompressor ()
void SetCompressorType (int compressorType)
void SetCompressorTypeToNone ()
void SetCompressorTypeToZLib ()
virtual void SetBlockSize (size_t blockSize)
virtual size_t GetBlockSize ()
virtual void SetDataMode (int)
virtual int GetDataMode ()
void SetDataModeToAscii ()
void SetDataModeToBinary ()
void SetDataModeToAppended ()
virtual void SetEncodeAppendedData (int)
virtual int GetEncodeAppendedData ()
virtual void EncodeAppendedDataOn ()
virtual void EncodeAppendedDataOff ()
vtkDataObject * GetInput ()
virtual int GetNumberOfTimeSteps ()
virtual void SetNumberOfTimeSteps (int)
void Start ()
void Stop ()
void WriteNextTime (double time)
void Start ()
void Stop ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkXMLPVAnimationWriter * New ()
static vtkXMLPVAnimationWriter * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkXMLPVDWriter
static vtkXMLPVDWriter * New ()
static vtkXMLPVDWriter * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkXMLWriter
static vtkXMLWriter * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkXMLPVAnimationWriter ()
 ~vtkXMLPVAnimationWriter () override
int WriteInternal () override
void AddFileName (const char *fileName)
void DeleteFileNames ()
void DeleteFiles ()
void AddInputInternal (const char *group)
- Protected Member Functions inherited from vtkXMLPVDWriter
 vtkXMLPVDWriter ()
 ~vtkXMLPVDWriter () override
int WriteData () override
const char * GetDataSetName () override
void CreateWriters ()
vtkXMLWriter * GetWriter (int index)
void SplitFileName ()
const char * GetFilePrefix ()
const char * GetFilePath ()
void AppendEntry (const char *entry)
void DeleteAllEntries ()
int WriteCollectionFileIfRequested ()
void MakeDirectory (const char *name)
void RemoveADirectory (const char *name)
virtual void ProgressCallback (vtkAlgorithm *w)
void ReportReferences (vtkGarbageCollector *) override
- Protected Member Functions inherited from vtkXMLWriter
 vtkXMLWriter ()
 ~vtkXMLWriter ()
virtual void SetDataStream (vtkOutputStream *)
virtual vtkOutputStream * GetDataStream ()
virtual int GetDataSetMajorVersion ()
virtual int GetDataSetMinorVersion ()
vtkDataSet * GetInputAsDataSet ()
virtual int StartFile ()
virtual void WriteFileAttributes ()
virtual int EndFile ()
void DeleteAFile ()
void DeleteAFile (const char *name)
virtual int WritePrimaryElement (ostream &os, vtkIndent indent)
virtual void WritePrimaryElementAttributes (ostream &os, vtkIndent indent)
void StartAppendedData ()
void EndAppendedData ()
vtkTypeInt64 ReserveAttributeSpace (const char *attr, size_t length=20)
vtkTypeInt64 GetAppendedDataOffset ()
void WriteAppendedDataOffset (vtkTypeInt64 streamPos, vtkTypeInt64 &lastoffset, const char *attr=0)
void ForwardAppendedDataOffset (vtkTypeInt64 streamPos, vtkTypeInt64 offset, const char *attr=0)
void ForwardAppendedDataDouble (vtkTypeInt64 streamPos, double value, const char *attr)
int WriteScalarAttribute (const char *name, int data)
int WriteScalarAttribute (const char *name, float data)
int WriteScalarAttribute (const char *name, double data)
int WriteVectorAttribute (const char *name, int length, int *data)
int WriteVectorAttribute (const char *name, int length, float *data)
int WriteVectorAttribute (const char *name, int length, double *data)
int WriteDataModeAttribute (const char *name)
int WriteWordTypeAttribute (const char *name, int dataType)
int WriteStringAttribute (const char *name, const char *value)
bool WriteInformation (vtkInformation *info, vtkIndent indent)
void WriteArrayHeader (vtkAbstractArray *a, vtkIndent indent, const char *alternateName, int writeNumTuples, int timestep)
virtual void WriteArrayFooter (ostream &os, vtkIndent indent, vtkAbstractArray *a, int shortFormat)
virtual void WriteArrayInline (vtkAbstractArray *a, vtkIndent indent, const char *alternateName=0, int writeNumTuples=0)
virtual void WriteInlineData (vtkAbstractArray *a, vtkIndent indent)
void WriteArrayAppended (vtkAbstractArray *a, vtkIndent indent, OffsetsManager &offs, const char *alternateName=0, int writeNumTuples=0, int timestep=0)
int WriteAsciiData (vtkAbstractArray *a, vtkIndent indent)
int WriteBinaryData (vtkAbstractArray *a)
int WriteBinaryDataInternal (vtkAbstractArray *a)
void WriteArrayAppendedData (vtkAbstractArray *a, vtkTypeInt64 pos, vtkTypeInt64 &lastoffset)
void WriteFieldData (vtkIndent indent)
void WriteFieldDataInline (vtkFieldData *fd, vtkIndent indent)
void WritePointDataInline (vtkPointData *pd, vtkIndent indent)
void WriteCellDataInline (vtkCellData *cd, vtkIndent indent)
void WriteFieldDataAppended (vtkFieldData *fd, vtkIndent indent, OffsetsManagerGroup *fdManager)
void WriteFieldDataAppendedData (vtkFieldData *fd, int timestep, OffsetsManagerGroup *fdManager)
void WritePointDataAppended (vtkPointData *pd, vtkIndent indent, OffsetsManagerGroup *pdManager)
void WritePointDataAppendedData (vtkPointData *pd, int timestep, OffsetsManagerGroup *pdManager)
void WriteCellDataAppended (vtkCellData *cd, vtkIndent indent, OffsetsManagerGroup *cdManager)
void WriteCellDataAppendedData (vtkCellData *cd, int timestep, OffsetsManagerGroup *cdManager)
void WriteAttributeIndices (vtkDataSetAttributes *dsa, char **names)
void WritePointsAppended (vtkPoints *points, vtkIndent indent, OffsetsManager *manager)
void WritePointsAppendedData (vtkPoints *points, int timestep, OffsetsManager *pdManager)
void WritePointsInline (vtkPoints *points, vtkIndent indent)
void WriteCoordinatesInline (vtkDataArray *xc, vtkDataArray *yc, vtkDataArray *zc, vtkIndent indent)
void WriteCoordinatesAppended (vtkDataArray *xc, vtkDataArray *yc, vtkDataArray *zc, vtkIndent indent, OffsetsManagerGroup *coordManager)
void WriteCoordinatesAppendedData (vtkDataArray *xc, vtkDataArray *yc, vtkDataArray *zc, int timestep, OffsetsManagerGroup *coordManager)
void WritePPointData (vtkPointData *pd, vtkIndent indent)
void WritePCellData (vtkCellData *cd, vtkIndent indent)
void WritePPoints (vtkPoints *points, vtkIndent indent)
void WritePArray (vtkAbstractArray *a, vtkIndent indent, const char *alternateName=0)
void WritePCoordinates (vtkDataArray *xc, vtkDataArray *yc, vtkDataArray *zc, vtkIndent indent)
int WriteBinaryDataBlock (unsigned char *in_data, size_t numWords, int wordType)
void PerformByteSwap (void *data, size_t numWords, size_t wordSize)
int CreateCompressionHeader (size_t size)
int WriteCompressionBlock (unsigned char *data, size_t size)
int WriteCompressionHeader ()
size_t GetWordTypeSize (int dataType)
const char * GetWordTypeName (int dataType)
size_t GetOutputWordTypeSize (int dataType)
char ** CreateStringArray (int numStrings)
void DestroyStringArray (int numStrings, char **strings)
virtual void GetProgressRange (float range[2])
virtual void SetProgressRange (const float range[2], int curStep, int numSteps)
virtual void SetProgressRange (const float range[2], int curStep, const float *fractions)
virtual void SetProgressPartial (float fraction)
virtual void UpdateProgressDiscrete (float progress)
int OpenStream ()
int OpenFile ()
int OpenString ()
void CloseStream ()
void CloseFile ()
void CloseString ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
int StartCalled
int FinishCalled
vtkXMLPVAnimationWriterInternals * Internal
char ** FileNamesCreated
int NumberOfFileNamesCreated
- Protected Attributes inherited from vtkXMLPVDWriter
vtkXMLPVDWriterInternals * Internal
int Piece
int NumberOfPieces
int GhostLevel
int WriteCollectionFileInitialized
vtkCallbackCommand * ProgressObserver
int CurrentTimeIndex
int WriteAllTimeSteps
- Protected Attributes inherited from vtkXMLWriter
char * FileName
ostream * Stream
int WriteToOutputString
std::string OutputString
int ByteOrder
int HeaderType
int IdType
int DataMode
int EncodeAppendedData
vtkTypeInt64 AppendedDataPosition
OffsetsManagerGroup * FieldDataOM
Int32IdType * Int32IdTypeBuffer
unsigned char * ByteSwapBuffer
vtkDataCompressor * Compressor
size_t BlockSize
size_t CompressionBlockNumber
vtkXMLDataHeader * CompressionHeader
vtkTypeInt64 CompressionHeaderPosition
vtkOutputStream * DataStream
float ProgressRange [2]
ofstream * OutFile
std::ostringstream * OutStringStream
int NumberOfTimeSteps
int UserContinueExecuting
bool UsePreviousVersion
vtkTypeInt64 * NumberOfTimeValues
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
- Public Attributes inherited from vtkXMLWriter
 BigEndian
 LittleEndian
 Ascii
 Binary
 Appended
 Int32
 Int64
 UInt32
 UInt64
 NONE
 ZLIB
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Static Protected Member Functions inherited from vtkXMLPVDWriter
static void ProgressCallbackFunction (vtkObject *, unsigned long, void *, void *)
vtkXMLPVAnimationWriter is used to save all parts of a current source to a file with pieces spread across other server processes.
Definition at line 19 of file vtkXMLPVAnimationWriter.h.
Definition at line 23 of file vtkXMLPVAnimationWriter.h.
◆ vtkXMLPVAnimationWriter()
vtkXMLPVAnimationWriter::vtkXMLPVAnimationWriter ( )
◆ ~vtkXMLPVAnimationWriter()
vtkXMLPVAnimationWriter::~vtkXMLPVAnimationWriter ( )
static vtkXMLPVAnimationWriter* vtkXMLPVAnimationWriter::New ( )
virtual const char* vtkXMLPVAnimationWriter::GetClassName ( )
Reimplemented from vtkXMLPVDWriter.
static int vtkXMLPVAnimationWriter::IsTypeOf ( const char *  type)
virtual int vtkXMLPVAnimationWriter::IsA ( const char *  type)
static vtkXMLPVAnimationWriter* vtkXMLPVAnimationWriter::SafeDownCast ( vtkObject *  o)
void vtkXMLPVAnimationWriter::PrintSelf ( ostream &  os,
Reimplemented from vtkXMLWriter.
◆ AddRepresentation()
void vtkXMLPVAnimationWriter::AddRepresentation ( vtkAlgorithm *  ,
const char *  groupname
◆ RemoveAllRepresentations()
void vtkXMLPVAnimationWriter::RemoveAllRepresentations ( )
◆ Start()
void vtkXMLPVAnimationWriter::Start ( )
◆ WriteTime()
void vtkXMLPVAnimationWriter::WriteTime ( double  time)
◆ Finish()
void vtkXMLPVAnimationWriter::Finish ( )
◆ WriteInternal()
int vtkXMLPVAnimationWriter::WriteInternal ( )
overrideprotectedvirtual
◆ AddFileName()
void vtkXMLPVAnimationWriter::AddFileName ( const char *  fileName)
◆ DeleteFileNames()
void vtkXMLPVAnimationWriter::DeleteFileNames ( )
◆ DeleteFiles()
void vtkXMLPVAnimationWriter::DeleteFiles ( )
◆ AddInputInternal()
void vtkXMLPVAnimationWriter::AddInputInternal ( const char *  group)
◆ StartCalled
int vtkXMLPVAnimationWriter::StartCalled
Definition at line 57 of file vtkXMLPVAnimationWriter.h.
◆ FinishCalled
int vtkXMLPVAnimationWriter::FinishCalled
Definition at line 58 of file vtkXMLPVAnimationWriter.h.
◆ Internal
vtkXMLPVAnimationWriterInternals* vtkXMLPVAnimationWriter::Internal
Definition at line 61 of file vtkXMLPVAnimationWriter.h.
◆ FileNamesCreated
char** vtkXMLPVAnimationWriter::FileNamesCreated
Definition at line 63 of file vtkXMLPVAnimationWriter.h.
◆ NumberOfFileNamesCreated
int vtkXMLPVAnimationWriter::NumberOfFileNamesCreated
Definition at line 64 of file vtkXMLPVAnimationWriter.h.
