Public Types | Public Member Functions | Static Public Member Functions | Protected Types | Protected Member Functions | Protected Attributes | List of all members
vtkSIProxyProperty Class Reference
#include <vtkSIProxyProperty.h>
Inheritance diagram for vtkSIProxyProperty:
Collaboration diagram for vtkSIProxyProperty:
typedef vtkSIProperty Superclass
- Public Types inherited from vtkSIProperty
virtual bool GetNullOnEmpty ()
virtual char * GetCleanCommand ()
 Command that can be used to remove inputs. More...
virtual char * GetRemoveCommand ()
 Remove command is the command called to remove the VTK object on the server-side. More...
- Public Member Functions inherited from vtkSIProperty
virtual char * GetXMLName ()
 The name assigned by the xml parser. More...
virtual char * GetCommand ()
 The command name used to set the value on the server object. More...
virtual bool GetInformationOnly ()
 Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More...
virtual bool GetRepeatable ()
 If repeatable, a property can have 1 or more values of the same kind. More...
virtual void SetIsInternal (bool)
 This ivar is configured when the xml file is read and is mainly useful to trigger a method call. More...
virtual bool GetIsInternal ()
static vtkSIProxyProperty * New ()
static vtkSIProxyProperty * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSIProperty
static vtkSIProperty * New ()
static vtkSIProperty * SafeDownCast (vtkObject *o)
Protected Types
enum  TypeArg { VTK, SMProxy, SIProxy }
 vtkSIProxyProperty ()
 ~vtkSIProxyProperty () override
bool Push (vtkSMMessage *, int) override
 Push a new state to the underneath implementation. More...
bool ReadXMLAttributes (vtkSIProxy *proxyhelper, vtkPVXMLElement *element) override
 Parse the xml for the property. More...
virtual void SetNullOnEmpty (bool)
vtkObjectBase * GetObjectBase (vtkTypeUInt32 globalId)
bool IsValidNull (vtkTypeUInt32 globalId)
- Protected Member Functions inherited from vtkSIProperty
 vtkSIProperty ()
 ~vtkSIProperty () override
vtkSIObject * GetSIObject (vtkTypeUInt32 globalid)
 Convenience method to obtain a vtkSIObject subclass given its global id. More...
virtual bool Pull (vtkSMMessage *)
 Pull the current state of the underneath implementation. More...
virtual void SetCommand (const char *)
void SaveValueToCache (vtkSMMessage *proxyStateUpdate, int offset)
bool ProcessMessage (vtkClientServerStream &stream)
 Interprets the message. More...
const vtkClientServerStream & GetLastResult ()
vtkObjectBase * GetVTKObject ()
bool NullOnEmpty
TypeArg ArgumentType
- Protected Attributes inherited from vtkSIProperty
char * XMLName
char * Command
bool InformationOnly
bool Repeatable
bool IsInternal
vtkWeakPointer< vtkSIProxy > SIProxyObject
char * CleanCommand
virtual void SetCleanCommand (const char *)
char * RemoveCommand
virtual void SetRemoveCommand (const char *)
ServerSide Property use to set Object array as method argument. Those object could be either SMProxy instance or their SIProxy instance or the VTK object managed by the SIProxy instance. The type of object is specified inside the XML definition of the property with the attribute argument_type=[VTK, SMProxy, SIProxy].
Definition at line 19 of file vtkSIProxyProperty.h.
Definition at line 23 of file vtkSIProxyProperty.h.
◆ TypeArg
Enumerator
VTK
SMProxy
SIProxy
Definition at line 91 of file vtkSIProxyProperty.h.
◆ vtkSIProxyProperty()
vtkSIProxyProperty::vtkSIProxyProperty ( )
◆ ~vtkSIProxyProperty()
vtkSIProxyProperty::~vtkSIProxyProperty ( )
static vtkSIProxyProperty* vtkSIProxyProperty::New ( )
virtual const char* vtkSIProxyProperty::GetClassName ( )
static int vtkSIProxyProperty::IsTypeOf ( const char *  type)
virtual int vtkSIProxyProperty::IsA ( const char *  type)
static vtkSIProxyProperty* vtkSIProxyProperty::SafeDownCast ( vtkObject *  o)
void vtkSIProxyProperty::PrintSelf ( ostream &  os,
◆ GetCleanCommand()
virtual char* vtkSIProxyProperty::GetCleanCommand ( )
If set, this command is called before the main Command is called with all the arguments.
◆ GetRemoveCommand()
virtual char* vtkSIProxyProperty::GetRemoveCommand ( )
If set, CleanCommand is ignored. Instead for every proxy that was absent from the proxies previously pushed, the RemoveCommand is invoked.
◆ GetNullOnEmpty()
virtual bool vtkSIProxyProperty::GetNullOnEmpty ( )
◆ Push()
bool vtkSIProxyProperty::Push ( vtkSMMessage *  ,
int
overrideprotectedvirtual
◆ ReadXMLAttributes()
bool vtkSIProxyProperty::ReadXMLAttributes ( vtkSIProxy *  proxyhelper,
vtkPVXMLElement *  element
◆ SetCleanCommand()
virtual void vtkSIProxyProperty::SetCleanCommand ( const char *  )
protectedvirtual
◆ SetRemoveCommand()
virtual void vtkSIProxyProperty::SetRemoveCommand ( const char *  )
protectedvirtual
◆ SetNullOnEmpty()
virtual void vtkSIProxyProperty::SetNullOnEmpty ( bool  )
protectedvirtual
◆ GetObjectBase()
vtkObjectBase* vtkSIProxyProperty::GetObjectBase ( vtkTypeUInt32  globalId)
◆ IsValidNull()
bool vtkSIProxyProperty::IsValidNull ( vtkTypeUInt32  globalId)
◆ CleanCommand
char* vtkSIProxyProperty::CleanCommand
Definition at line 70 of file vtkSIProxyProperty.h.
◆ RemoveCommand
char* vtkSIProxyProperty::RemoveCommand
Definition at line 81 of file vtkSIProxyProperty.h.
◆ NullOnEmpty
bool vtkSIProxyProperty::NullOnEmpty
Definition at line 88 of file vtkSIProxyProperty.h.
◆ ArgumentType
TypeArg vtkSIProxyProperty::ArgumentType
Definition at line 102 of file vtkSIProxyProperty.h.
