vtkCaveSynchronizedRenderers Class Reference
vtkSynchronizedRenderers subclass that handles adjusting of camera for cave configurations. More...
#include <vtkCaveSynchronizedRenderers.h>
Inheritance diagram for vtkCaveSynchronizedRenderers:
Collaboration diagram for vtkCaveSynchronizedRenderers:
typedef vtkSynchronizedRenderers Superclass
- Public Types inherited from vtkSynchronizedRenderers
- Public Member Functions inherited from vtkSynchronizedRenderers
vtkSynchronizedRenderers * NewInstance () const
void CollectiveExpandForVisiblePropBounds (double bounds[6])
virtual vtkRenderer * GetRenderer ()
virtual void SetParallelController (vtkMultiProcessController *)
virtual vtkMultiProcessController * GetParallelController ()
virtual void SetParallelRendering (bool)
virtual bool GetParallelRendering ()
virtual void ParallelRenderingOn ()
virtual void ParallelRenderingOff ()
virtual void SetImageReductionFactor (int)
virtual int GetImageReductionFactor ()
virtual void SetWriteBackImages (bool)
virtual bool GetWriteBackImages ()
virtual void WriteBackImagesOn ()
virtual void WriteBackImagesOff ()
virtual void SetRootProcessId (int)
virtual int GetRootProcessId ()
virtual void SetCaptureDelegate (vtkSynchronizedRenderers *)
virtual vtkSynchronizedRenderers * GetCaptureDelegate ()
virtual void SetAutomaticEventHandling (bool)
virtual bool GetAutomaticEventHandling ()
virtual void AutomaticEventHandlingOn ()
virtual void AutomaticEventHandlingOff ()
static vtkCaveSynchronizedRenderers * New ()
static vtkCaveSynchronizedRenderers * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSynchronizedRenderers
static vtkSynchronizedRenderers * New ()
static vtkSynchronizedRenderers * SafeDownCast (vtkObjectBase *o)
 vtkCaveSynchronizedRenderers ()
 ~vtkCaveSynchronizedRenderers () override
void HandleStartRender () override
 Called at the start of each render. More...
void ProcessCaveConfiguration ()
 During constructor, processes the configuration file to setup the display information. More...
void SetNumberOfDisplays (int numberOfDisplays)
 These are to initialize the displays. More...
void SetEyeSeparation (double eyeSeparation)
 Set the eye separation for all the displays. More...
void DefineDisplay (int idx, double origin[3], double x[3], double y[3])
void ComputeCamera (vtkCamera *cam)
 Method to update the camera. More...
void SetRenderer (vtkRenderer *renderer) override
 Override Superclass to compute Displays parameters in case of a single screen cave (e.g. More...
- Protected Member Functions inherited from vtkSynchronizedRenderers
 vtkSynchronizedRenderers ()
 ~vtkSynchronizedRenderers ()
virtual void HandleEndRender ()
virtual void HandleAbortRender ()
virtual void MasterStartRender ()
virtual void SlaveStartRender ()
virtual void MasterEndRender ()
virtual void SlaveEndRender ()
virtual vtkRawImage & CaptureRenderedImage ()
virtual void PushImageToScreen ()
double EyeSeparation
int NumberOfDisplays
double ** Displays
double DisplayOrigin [3]
double DisplayX [3]
double DisplayY [3]
int once
- Protected Attributes inherited from vtkSynchronizedRenderers
vtkMultiProcessController * ParallelController
vtkOpenGLRenderer * Renderer
vtkSynchronizedRenderers * CaptureDelegate
vtkRawImage ReducedImage
vtkRawImage FullImage
bool ParallelRendering
int ImageReductionFactor
bool WriteBackImages
int RootProcessId
bool AutomaticEventHandling
- Public Attributes inherited from vtkSynchronizedRenderers
 SYNC_RENDERER_TAG
 RESET_CAMERA_TAG
 COMPUTE_BOUNDS_TAG
vtkCaveSynchronizedRenderers is vtkSynchronizedRenderers used for in CAVE configuration. It is used on the render-server side. It ensures that the camera is transformed based on the orientations specified in the pvx configuration file. This code was previously in class vtkCaveRenderManager.
In case of a single display, if the cave bounds are not set, we compute these values from vtkDisplayConfiguration::Geometry and the client camera view angle.
Definition at line 27 of file vtkCaveSynchronizedRenderers.h.
Definition at line 31 of file vtkCaveSynchronizedRenderers.h.
◆ vtkCaveSynchronizedRenderers()
vtkCaveSynchronizedRenderers::vtkCaveSynchronizedRenderers ( )
◆ ~vtkCaveSynchronizedRenderers()
vtkCaveSynchronizedRenderers::~vtkCaveSynchronizedRenderers ( )
static vtkCaveSynchronizedRenderers* vtkCaveSynchronizedRenderers::New ( )
virtual const char* vtkCaveSynchronizedRenderers::GetClassName ( )
static int vtkCaveSynchronizedRenderers::IsTypeOf ( const char *  type)
virtual int vtkCaveSynchronizedRenderers::IsA ( const char *  type)
Reimplemented from vtkSynchronizedRenderers.
static vtkCaveSynchronizedRenderers* vtkCaveSynchronizedRenderers::SafeDownCast ( vtkObject *  o)
void vtkCaveSynchronizedRenderers::PrintSelf ( ostream &  os,
◆ HandleStartRender()
void vtkCaveSynchronizedRenderers::HandleStartRender ( )
overrideprotectedvirtual
Overridden to ensure that the camera is updated based on the configuration.
◆ ProcessCaveConfiguration()
void vtkCaveSynchronizedRenderers::ProcessCaveConfiguration ( )
◆ SetNumberOfDisplays()
void vtkCaveSynchronizedRenderers::SetNumberOfDisplays ( int  numberOfDisplays)
(This is directly copied from vtkCaveRenderManager).
◆ SetEyeSeparation()
void vtkCaveSynchronizedRenderers::SetEyeSeparation ( double  eyeSeparation)
◆ DefineDisplay()
void vtkCaveSynchronizedRenderers::DefineDisplay ( int  idx,
double  origin[3],
double  x[3],
double  y[3]
◆ ComputeCamera()
void vtkCaveSynchronizedRenderers::ComputeCamera ( vtkCamera *  cam)
◆ SetRenderer()
void vtkCaveSynchronizedRenderers::SetRenderer ( vtkRenderer *  renderer)
zSpace)
◆ EyeSeparation
double vtkCaveSynchronizedRenderers::EyeSeparation
Definition at line 74 of file vtkCaveSynchronizedRenderers.h.
◆ NumberOfDisplays
int vtkCaveSynchronizedRenderers::NumberOfDisplays
Definition at line 75 of file vtkCaveSynchronizedRenderers.h.
◆ Displays
double** vtkCaveSynchronizedRenderers::Displays
Definition at line 76 of file vtkCaveSynchronizedRenderers.h.
◆ DisplayOrigin
double vtkCaveSynchronizedRenderers::DisplayOrigin[3]
Definition at line 77 of file vtkCaveSynchronizedRenderers.h.
◆ DisplayX
double vtkCaveSynchronizedRenderers::DisplayX[3]
Definition at line 78 of file vtkCaveSynchronizedRenderers.h.
◆ DisplayY
double vtkCaveSynchronizedRenderers::DisplayY[3]
Definition at line 79 of file vtkCaveSynchronizedRenderers.h.
◆ once
int vtkCaveSynchronizedRenderers::once
Definition at line 80 of file vtkCaveSynchronizedRenderers.h.
