vtkPVPlotMatrixRepresentation Class Reference
vtkChartRepresentation subclass for scatter-plot-matrix representation. More...
#include <vtkPVPlotMatrixRepresentation.h>
Inheritance diagram for vtkPVPlotMatrixRepresentation:
Collaboration diagram for vtkPVPlotMatrixRepresentation:
typedef vtkChartRepresentation Superclass
- Public Types inherited from vtkChartRepresentation
enum  DesiredOutputPrecision
void SetVisibility (bool visible) override
 Sets the visibility for the plot matrix representation. More...
void SetColor (double r, double g, double b)
 Sets the color for the scatter plots in the plot matrix. More...
void SetActivePlotColor (double r, double g, double b)
 Sets the color for the active plot. More...
void SetHistogramColor (double r, double g, double b)
 Sets the color for the histograms. More...
void SetMarkerStyle (int style)
 Sets the marker style for the scatter plots. More...
void SetActivePlotMarkerStyle (int style)
 Sets the marker style for the active plot. More...
void SetMarkerSize (double size)
 Sets the marker size for the scatter plots. More...
void SetActivePlotMarkerSize (double size)
 Sets the marker size for the active plots. More...
void SetDensityMapVisibility (bool visible)
 Set the scatter plot density map visibility. More...
void SetActivePlotDensityMapVisibility (bool visible)
 Set the active plot density map visibility. More...
void SetDensityLineSize (double size)
 Sets the line size for the density map in the plot matrix. More...
void SetActivePlotDensityLineSize (double size)
 Sets the line size for the density map in the active plot. More...
void SetDensityMapFirstDecileColor (double r, double g, double b)
 Sets the color for the density map first DecileColor in the scatter plots. More...
void SetActivePlotDensityMapFirstDecileColor (double r, double g, double b)
void SetDensityMapMedianColor (double r, double g, double b)
 Sets the color for the density map MeanColor in the scatter plots. More...
void SetActivePlotDensityMapMedianColor (double r, double g, double b)
void SetDensityMapLastDecileColor (double r, double g, double b)
 Sets the color for the density map last DecileColor in the scatter plots. More...
void SetActivePlotDensityMapLastDecileColor (double r, double g, double b)
vtkScatterPlotMatrix * GetPlotMatrix () const
 Returns the scatter plot matrix. More...
void SetSeriesVisibility (const char *series, bool visibility)
 Set series visibility given its name. More...
void ClearSeriesVisibilities ()
- Public Member Functions inherited from vtkChartRepresentation
void SetSelectionRepresentation (vtkChartSelectionRepresentation *)
 These must only be set during initialization before adding the representation to any views or calling Update(). More...
void MarkModified () override
 This needs to be called on all instances of vtkGeometryRepresentation when the input is modified. More...
void SetCompositeDataSetIndex (unsigned int)
void AddCompositeDataSetIndex (unsigned int)
void ResetCompositeDataSetIndices ()
unsigned int Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) override
 Override because of internal selection representations that need to be initialized as well. More...
virtual std::string GetDefaultSeriesLabel (const std::string &tableName, const std::string &columnName)
 Method to provide the default name given the name of a table and a column in that table. More...
virtual bool MapSelectionToInput (vtkSelection *sel)
 This method is called on the client-side by the vtkPVContextView whenever a new selection is made on all the visible representations in that view. More...
virtual bool MapSelectionToView (vtkSelection *sel)
 This is the inverse of MapSelectionToInput(). More...
virtual bool Export (vtkAbstractChartExporter *vtkNotUsed(exporter))
 Called by vtkPVContextView::Export() to export the representation's data to a CSV file. More...
void SetFieldAssociation (int)
 Set the field association for arrays to use. More...
virtual void SetFlattenTable (int)
 Flatten the table, i.e. More...
virtual int GetFlattenTable ()
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVPlotMatrixRepresentation * New ()
static vtkPVPlotMatrixRepresentation * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkChartRepresentation
static vtkChartRepresentation * New ()
static vtkChartRepresentation * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkPVPlotMatrixRepresentation ()
 ~vtkPVPlotMatrixRepresentation () override
void PrepareForRendering () override
 Overridden to pass information about changes to series visibility etc. More...
 Add the plot matrix representation to the view. More...
 Remove the plot matrix representation from the view. More...
- Protected Member Functions inherited from vtkChartRepresentation
 vtkChartRepresentation ()
 ~vtkChartRepresentation () override
 Subclasses should override this to connect inputs to the internal pipeline as necessary. More...
vtkTable * GetLocalOutput (bool pre_delivery=false)
 Convenience method to get the first vtkTable from LocalOutput, if any. More...
virtual vtkSmartPointer< vtkDataObject > TransformInputData (vtkDataObject *data)
 Method to be overridden to transform input data. More...
virtual vtkSmartPointer< vtkDataObject > ReduceDataToRoot (vtkDataObject *data)
 Chart representation/views expect that the data is reduced to root node and then passed on the rendering nodes. More...
virtual vtkSmartPointer< vtkDataObject > TransformTable (vtkSmartPointer< vtkDataObject > table)
 Method to be overridden to apply an operation of the table after it is gathered to the first rank for rendering the chart. More...
bool GetLocalOutput (MapOfTables &tables)
 Convenience method to get all vtkTable instances with their associated names. More...
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Protected Types inherited from vtkChartRepresentation
typedef std::map< std::string, std::pair< vtkSmartPointer< vtkTable >, unsigned int > > MapOfTables
- Protected Attributes inherited from vtkChartRepresentation
int FieldAssociation
vtkWeakPointer< vtkPVContextView > ContextView
int FlattenTable
vtkSmartPointer< vtkMultiBlockDataSet > LocalOutput
std::set< unsigned int > CompositeIndices
vtkWeakPointer< vtkChartSelectionRepresentation > SelectionRepresentation
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
vtkPVPlotMatrixRepresentation manages representations in a vtkScatterPlotMatrix view. It exposes API that affects how the matrix is rendered as well as API to control which of the columns in the input vtkTable are to be plotted in the matrix.
vtkPVPlotMatrixRepresentation currently does not support multiblock of tables and only the first table is rendered.
Definition at line 28 of file vtkPVPlotMatrixRepresentation.h.
Definition at line 32 of file vtkPVPlotMatrixRepresentation.h.
◆ vtkPVPlotMatrixRepresentation()
vtkPVPlotMatrixRepresentation::vtkPVPlotMatrixRepresentation ( )
◆ ~vtkPVPlotMatrixRepresentation()
vtkPVPlotMatrixRepresentation::~vtkPVPlotMatrixRepresentation ( )
static vtkPVPlotMatrixRepresentation* vtkPVPlotMatrixRepresentation::New ( )
virtual const char* vtkPVPlotMatrixRepresentation::GetClassName ( )
Reimplemented from vtkChartRepresentation.
static int vtkPVPlotMatrixRepresentation::IsTypeOf ( const char *  type)
virtual int vtkPVPlotMatrixRepresentation::IsA ( const char *  type)
static vtkPVPlotMatrixRepresentation* vtkPVPlotMatrixRepresentation::SafeDownCast ( vtkObject *  o)
void vtkPVPlotMatrixRepresentation::PrintSelf ( ostream &  os,
◆ SetVisibility()
void vtkPVPlotMatrixRepresentation::SetVisibility ( bool  visible)
◆ SetSeriesVisibility()
void vtkPVPlotMatrixRepresentation::SetSeriesVisibility ( const char *  series,
bool  visibility
The order in which SetSeriesVisibility is called is used to determine the order for each of the plots in the grid.
◆ ClearSeriesVisibilities()
void vtkPVPlotMatrixRepresentation::ClearSeriesVisibilities ( )
◆ SetColor()
void vtkPVPlotMatrixRepresentation::SetColor ( double  r,
double  g,
double  b
◆ SetActivePlotColor()
void vtkPVPlotMatrixRepresentation::SetActivePlotColor ( double  r,
double  g,
double  b
◆ SetHistogramColor()
void vtkPVPlotMatrixRepresentation::SetHistogramColor ( double  r,
double  g,
double  b
◆ SetMarkerStyle()
void vtkPVPlotMatrixRepresentation::SetMarkerStyle ( int  style)
◆ SetActivePlotMarkerStyle()
void vtkPVPlotMatrixRepresentation::SetActivePlotMarkerStyle ( int  style)
◆ SetMarkerSize()
void vtkPVPlotMatrixRepresentation::SetMarkerSize ( double  size)
◆ SetActivePlotMarkerSize()
void vtkPVPlotMatrixRepresentation::SetActivePlotMarkerSize ( double  size)
◆ SetDensityMapVisibility()
void vtkPVPlotMatrixRepresentation::SetDensityMapVisibility ( bool  visible)
◆ SetActivePlotDensityMapVisibility()
void vtkPVPlotMatrixRepresentation::SetActivePlotDensityMapVisibility ( bool  visible)
◆ SetDensityLineSize()
void vtkPVPlotMatrixRepresentation::SetDensityLineSize ( double  size)
◆ SetActivePlotDensityLineSize()
void vtkPVPlotMatrixRepresentation::SetActivePlotDensityLineSize ( double  size)
◆ SetDensityMapFirstDecileColor()
void vtkPVPlotMatrixRepresentation::SetDensityMapFirstDecileColor ( double  r,
double  g,
double  b
◆ SetActivePlotDensityMapFirstDecileColor()
void vtkPVPlotMatrixRepresentation::SetActivePlotDensityMapFirstDecileColor ( double  r,
double  g,
double  b
◆ SetDensityMapMedianColor()
void vtkPVPlotMatrixRepresentation::SetDensityMapMedianColor ( double  r,
double  g,
double  b
◆ SetActivePlotDensityMapMedianColor()
void vtkPVPlotMatrixRepresentation::SetActivePlotDensityMapMedianColor ( double  r,
double  g,
double  b
◆ SetDensityMapLastDecileColor()
void vtkPVPlotMatrixRepresentation::SetDensityMapLastDecileColor ( double  r,
double  g,
double  b
◆ SetActivePlotDensityMapLastDecileColor()
void vtkPVPlotMatrixRepresentation::SetActivePlotDensityMapLastDecileColor ( double  r,
double  g,
double  b
◆ GetPlotMatrix()
vtkScatterPlotMatrix* vtkPVPlotMatrixRepresentation::GetPlotMatrix ( ) const
◆ PrepareForRendering()
void vtkPVPlotMatrixRepresentation::PrepareForRendering ( )
overrideprotectedvirtual
to the plot-matrix.
◆ AddToView()
bool vtkPVPlotMatrixRepresentation::AddToView ( vtkView *  view)
◆ RemoveFromView()
bool vtkPVPlotMatrixRepresentation::RemoveFromView ( vtkView *  view)
