vtkPVKeyFrameAnimationCueForProxies Class Reference
#include <vtkPVKeyFrameAnimationCueForProxies.h>
Inheritance diagram for vtkPVKeyFrameAnimationCueForProxies:
Collaboration diagram for vtkPVKeyFrameAnimationCueForProxies:
typedef vtkPVKeyFrameAnimationCue Superclass
- Public Types inherited from vtkPVKeyFrameAnimationCue
typedef vtkPVAnimationCue Superclass
- Public Types inherited from vtkPVAnimationCue
typedef vtkAnimationCue Superclass
- Public Types inherited from vtkAnimationCue
enum  TimeCodes
void RemoveAnimatedProxy ()
void SetAnimatedProxy (vtkSMProxy *)
 Set/Get the animated proxy. More...
virtual vtkSMProxy * GetAnimatedProxy ()
virtual void SetAnimatedPropertyName (const char *)
 Set/Get the animated property name. More...
virtual char * GetAnimatedPropertyName ()
virtual void SetAnimatedDomainName (const char *)
 Set/Get the animated domain name. More...
virtual char * GetAnimatedDomainName ()
void BeginUpdateAnimationValues () override
 Used to update the animated item. More...
void SetAnimationValue (int index, double value) override
void EndUpdateAnimationValues () override
- Public Member Functions inherited from vtkPVKeyFrameAnimationCue
int AddKeyFrame (vtkPVKeyFrame *keyframe)
 Forwarded to the internal vtkPVKeyFrameCueManipulator. More...
int GetLastAddedKeyFrameIndex ()
void RemoveKeyFrame (vtkPVKeyFrame *)
void RemoveAllKeyFrames ()
- Public Member Functions inherited from vtkPVAnimationCue
virtual void SetAnimatedElement (int)
 The index of the element of the property this cue animates. More...
virtual int GetAnimatedElement ()
void SetManipulator (vtkPVCueManipulator *)
 Get/Set the manipulator used to compute values for each instance in the animation. More...
virtual vtkPVCueManipulator * GetManipulator ()
virtual void SetEnabled (int)
 Enable/Disable this cue. More...
virtual int GetEnabled ()
virtual void EnabledOn ()
virtual void EnabledOff ()
virtual void SetUseAnimationTime (bool)
 When set to true, the manipulator is skipped and the key frame value is set by using the ClockTime directly. More...
virtual bool GetUseAnimationTime ()
void Initialize () override
 Overridden to ignore the calls when this->Enabled == false. More...
void Tick (double currenttime, double deltatime, double clocktime) override
void Finalize () override
- Public Member Functions inherited from vtkAnimationCue
vtkAnimationCue * NewInstance () const
virtual void SetTimeMode (int mode)
virtual int GetTimeMode ()
void SetTimeModeToRelative ()
void SetTimeModeToNormalized ()
virtual void SetStartTime (double)
virtual double GetStartTime ()
virtual void SetEndTime (double)
virtual double GetEndTime ()
virtual double GetAnimationTime ()
virtual double GetDeltaTime ()
virtual double GetClockTime ()
static vtkPVKeyFrameAnimationCueForProxies * New ()
static vtkPVKeyFrameAnimationCueForProxies * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPVKeyFrameAnimationCue
static vtkPVKeyFrameAnimationCue * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPVAnimationCue
static vtkPVAnimationCue * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkAnimationCue
static vtkAnimationCue * SafeDownCast (vtkObjectBase *o)
static vtkAnimationCue * New ()
 vtkPVKeyFrameAnimationCueForProxies ()
 ~vtkPVKeyFrameAnimationCueForProxies () override
vtkSMProperty * GetAnimatedProperty ()
 Get the property being animated. More...
vtkSMDomain * GetAnimatedDomain ()
 Get the domain being animated. More...
- Protected Member Functions inherited from vtkPVKeyFrameAnimationCue
 vtkPVKeyFrameAnimationCue ()
 ~vtkPVKeyFrameAnimationCue () override
vtkPVKeyFrameCueManipulator * GetKeyFrameManipulator ()
- Protected Member Functions inherited from vtkPVAnimationCue
 vtkPVAnimationCue ()
 ~vtkPVAnimationCue () override
void StartCueInternal () override
void TickInternal (double currenttime, double deltatime, double clocktime) override
void EndCueInternal () override
- Protected Member Functions inherited from vtkAnimationCue
 vtkAnimationCue ()
 ~vtkAnimationCue ()
vtkSMProxy * AnimatedProxy
char * AnimatedPropertyName
char * AnimatedDomainName
int ValueIndexMax
- Protected Attributes inherited from vtkPVAnimationCue
unsigned long ObserverID
bool UseAnimationTime
int AnimatedElement
int Enabled
vtkAnimationCue * AnimationCue
vtkPVCueManipulator * Manipulator
- Protected Attributes inherited from vtkAnimationCue
 UNINITIALIZED
 INACTIVE
 ACTIVE
double StartTime
double EndTime
int TimeMode
double AnimationTime
double DeltaTime
double ClockTime
int CueState
- Public Attributes inherited from vtkAnimationCue
 TIMEMODE_NORMALIZED
 TIMEMODE_RELATIVE
vtkPVKeyFrameAnimationCueForProxies extends vtkPVKeyFrameAnimationCue to update properties on proxies in SetAnimationValue().
Definition at line 19 of file vtkPVKeyFrameAnimationCueForProxies.h.
Definition at line 24 of file vtkPVKeyFrameAnimationCueForProxies.h.
◆ vtkPVKeyFrameAnimationCueForProxies()
vtkPVKeyFrameAnimationCueForProxies::vtkPVKeyFrameAnimationCueForProxies ( )
◆ ~vtkPVKeyFrameAnimationCueForProxies()
vtkPVKeyFrameAnimationCueForProxies::~vtkPVKeyFrameAnimationCueForProxies ( )
static vtkPVKeyFrameAnimationCueForProxies* vtkPVKeyFrameAnimationCueForProxies::New ( )
virtual const char* vtkPVKeyFrameAnimationCueForProxies::GetClassName ( )
Reimplemented from vtkPVKeyFrameAnimationCue.
static int vtkPVKeyFrameAnimationCueForProxies::IsTypeOf ( const char *  type)
virtual int vtkPVKeyFrameAnimationCueForProxies::IsA ( const char *  type)
static vtkPVKeyFrameAnimationCueForProxies* vtkPVKeyFrameAnimationCueForProxies::SafeDownCast ( vtkObject *  o)
void vtkPVKeyFrameAnimationCueForProxies::PrintSelf ( ostream &  os,
◆ SetAnimatedProxy()
void vtkPVKeyFrameAnimationCueForProxies::SetAnimatedProxy ( vtkSMProxy *  )
◆ GetAnimatedProxy()
virtual vtkSMProxy* vtkPVKeyFrameAnimationCueForProxies::GetAnimatedProxy ( )
◆ RemoveAnimatedProxy()
void vtkPVKeyFrameAnimationCueForProxies::RemoveAnimatedProxy ( )
◆ SetAnimatedPropertyName()
virtual void vtkPVKeyFrameAnimationCueForProxies::SetAnimatedPropertyName ( const char *  )
◆ GetAnimatedPropertyName()
virtual char* vtkPVKeyFrameAnimationCueForProxies::GetAnimatedPropertyName ( )
◆ SetAnimatedDomainName()
virtual void vtkPVKeyFrameAnimationCueForProxies::SetAnimatedDomainName ( const char *  )
◆ GetAnimatedDomainName()
virtual char* vtkPVKeyFrameAnimationCueForProxies::GetAnimatedDomainName ( )
◆ BeginUpdateAnimationValues()
void vtkPVKeyFrameAnimationCueForProxies::BeginUpdateAnimationValues ( )
This API makes it possible for vtk-level classes to update properties without actually linking with the ServerManager library. This only works since they object are created only on the client.
Implements vtkPVAnimationCue.
◆ SetAnimationValue()
void vtkPVKeyFrameAnimationCueForProxies::SetAnimationValue ( int  index,
double  value
◆ EndUpdateAnimationValues()
void vtkPVKeyFrameAnimationCueForProxies::EndUpdateAnimationValues ( )
◆ GetAnimatedProperty()
vtkSMProperty* vtkPVKeyFrameAnimationCueForProxies::GetAnimatedProperty ( )
◆ GetAnimatedDomain()
vtkSMDomain* vtkPVKeyFrameAnimationCueForProxies::GetAnimatedDomain ( )
◆ AnimatedProxy
vtkSMProxy* vtkPVKeyFrameAnimationCueForProxies::AnimatedProxy
Definition at line 79 of file vtkPVKeyFrameAnimationCueForProxies.h.
◆ AnimatedPropertyName
char* vtkPVKeyFrameAnimationCueForProxies::AnimatedPropertyName
Definition at line 80 of file vtkPVKeyFrameAnimationCueForProxies.h.
◆ AnimatedDomainName
char* vtkPVKeyFrameAnimationCueForProxies::AnimatedDomainName
Definition at line 81 of file vtkPVKeyFrameAnimationCueForProxies.h.
◆ ValueIndexMax
int vtkPVKeyFrameAnimationCueForProxies::ValueIndexMax
Definition at line 82 of file vtkPVKeyFrameAnimationCueForProxies.h.
