vtkPVImageChartRepresentation Class Reference
Representation for the "Image Chart View". More...
#include <vtkPVImageChartRepresentation.h>
Inheritance diagram for vtkPVImageChartRepresentation:
Collaboration diagram for vtkPVImageChartRepresentation:
typedef vtkChartRepresentation Superclass
- Public Types inherited from vtkChartRepresentation
enum  DesiredOutputPrecision
void SetVisibility (bool visible) override
 Set visibility of the representation. More...
vtkChartHistogram2D * GetChart ()
 Provides access to the underlying VTK representation. More...
void SetLookupTable (vtkScalarsToColors *lut)
 Set the color map to use for the points in the plot. More...
- Public Member Functions inherited from vtkChartRepresentation
void SetSelectionRepresentation (vtkChartSelectionRepresentation *)
 These must only be set during initialization before adding the representation to any views or calling Update(). More...
void MarkModified () override
 This needs to be called on all instances of vtkGeometryRepresentation when the input is modified. More...
void SetCompositeDataSetIndex (unsigned int)
void AddCompositeDataSetIndex (unsigned int)
void ResetCompositeDataSetIndices ()
unsigned int Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) override
 Override because of internal selection representations that need to be initialized as well. More...
virtual std::string GetDefaultSeriesLabel (const std::string &tableName, const std::string &columnName)
 Method to provide the default name given the name of a table and a column in that table. More...
virtual bool MapSelectionToInput (vtkSelection *sel)
 This method is called on the client-side by the vtkPVContextView whenever a new selection is made on all the visible representations in that view. More...
virtual bool MapSelectionToView (vtkSelection *sel)
 This is the inverse of MapSelectionToInput(). More...
virtual bool Export (vtkAbstractChartExporter *vtkNotUsed(exporter))
 Called by vtkPVContextView::Export() to export the representation's data to a CSV file. More...
void SetFieldAssociation (int)
 Set the field association for arrays to use. More...
virtual void SetFlattenTable (int)
 Flatten the table, i.e. More...
virtual int GetFlattenTable ()
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVImageChartRepresentation * New ()
static vtkPVImageChartRepresentation * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkChartRepresentation
static vtkChartRepresentation * New ()
static vtkChartRepresentation * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkPVImageChartRepresentation ()=default
 ~vtkPVImageChartRepresentation () override
void PrepareForRendering () override
 This method is called before actual render if this->MTime was modified since the last time this method was called. More...
vtkSmartPointer< vtkDataObject > ReduceDataToRoot (vtkDataObject *data) override
 Override to simply pass the data instead of converting it to vtkTable. More...
- Protected Member Functions inherited from vtkChartRepresentation
 vtkChartRepresentation ()
 ~vtkChartRepresentation () override
 Subclasses should override this to connect inputs to the internal pipeline as necessary. More...
vtkTable * GetLocalOutput (bool pre_delivery=false)
 Convenience method to get the first vtkTable from LocalOutput, if any. More...
virtual vtkSmartPointer< vtkDataObject > TransformInputData (vtkDataObject *data)
 Method to be overridden to transform input data. More...
virtual vtkSmartPointer< vtkDataObject > TransformTable (vtkSmartPointer< vtkDataObject > table)
 Method to be overridden to apply an operation of the table after it is gathered to the first rank for rendering the chart. More...
bool GetLocalOutput (MapOfTables &tables)
 Convenience method to get all vtkTable instances with their associated names. More...
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Protected Types inherited from vtkChartRepresentation
typedef std::map< std::string, std::pair< vtkSmartPointer< vtkTable >, unsigned int > > MapOfTables
- Protected Attributes inherited from vtkChartRepresentation
int FieldAssociation
vtkWeakPointer< vtkPVContextView > ContextView
int FlattenTable
vtkSmartPointer< vtkMultiBlockDataSet > LocalOutput
std::set< unsigned int > CompositeIndices
vtkWeakPointer< vtkChartSelectionRepresentation > SelectionRepresentation
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
vtkPVImageChartRepresentation is the vtkChartRepresentation subclass for image data representation, in a vtkPlotHistogram2D.
If the input if a multi-block, it will display the first image data it finds and skip the rest.
Definition at line 24 of file vtkPVImageChartRepresentation.h.
Definition at line 28 of file vtkPVImageChartRepresentation.h.
◆ vtkPVImageChartRepresentation()
vtkPVImageChartRepresentation::vtkPVImageChartRepresentation ( )
protecteddefault
◆ ~vtkPVImageChartRepresentation()
vtkPVImageChartRepresentation::~vtkPVImageChartRepresentation ( )
static vtkPVImageChartRepresentation* vtkPVImageChartRepresentation::New ( )
virtual const char* vtkPVImageChartRepresentation::GetClassName ( )
Reimplemented from vtkChartRepresentation.
static int vtkPVImageChartRepresentation::IsTypeOf ( const char *  type)
virtual int vtkPVImageChartRepresentation::IsA ( const char *  type)
static vtkPVImageChartRepresentation* vtkPVImageChartRepresentation::SafeDownCast ( vtkObject *  o)
void vtkPVImageChartRepresentation::PrintSelf ( ostream &  os,
◆ SetVisibility()
void vtkPVImageChartRepresentation::SetVisibility ( bool  visible)
◆ GetChart()
vtkChartHistogram2D* vtkPVImageChartRepresentation::GetChart ( )
◆ SetLookupTable()
void vtkPVImageChartRepresentation::SetLookupTable ( vtkScalarsToColors *  lut)
◆ PrepareForRendering()
void vtkPVImageChartRepresentation::PrepareForRendering ( )
overrideprotectedvirtual
Subclasses should override to update "appearance" related changes that don't affect data. When this method is called, you're assured that this->ContextView is valid. Note that this method will not be called if this->GetVisibility() returns false, this subclasses should also override SetVisibility() to hide "actors" and such.
◆ RemoveFromView()
bool vtkPVImageChartRepresentation::RemoveFromView ( vtkView *  view)
◆ ReduceDataToRoot()
vtkSmartPointer<vtkDataObject> vtkPVImageChartRepresentation::ReduceDataToRoot ( vtkDataObject *  data)
It is needed because the vtkChartHistogram2D takes a vtkImageData directly.
