vtkPVCameraAnimationCue Class Reference
#include <vtkPVCameraAnimationCue.h>
Inheritance diagram for vtkPVCameraAnimationCue:
Collaboration diagram for vtkPVCameraAnimationCue:
typedef vtkPVKeyFrameAnimationCue Superclass
- Public Types inherited from vtkPVKeyFrameAnimationCue
typedef vtkPVAnimationCue Superclass
- Public Types inherited from vtkPVAnimationCue
typedef vtkAnimationCue Superclass
- Public Types inherited from vtkAnimationCue
enum  TimeCodes
vtkCamera * GetCamera ()
 Returns the animated camera, if any. More...
void BeginUpdateAnimationValues () override
 Used to update the animated item. More...
void SetAnimationValue (int, double) override
void EndUpdateAnimationValues () override
void SetDataSourceProxy (vtkSMProxy *dataSourceProxy)
void SetView (vtkPVRenderView *)
 Get/Set the render view. More...
virtual vtkPVRenderView * GetView ()
void SetMode (int mode)
 Forwarded to vtkPVCameraCueManipulator. More...
void SetInterpolationMode (int mode)
virtual vtkSMProxy * GetTimeKeeper ()
 Get/Set the animation timekeeper. More...
void SetTimeKeeper (vtkSMProxy *)
- Public Member Functions inherited from vtkPVKeyFrameAnimationCue
int AddKeyFrame (vtkPVKeyFrame *keyframe)
 Forwarded to the internal vtkPVKeyFrameCueManipulator. More...
int GetLastAddedKeyFrameIndex ()
void RemoveKeyFrame (vtkPVKeyFrame *)
void RemoveAllKeyFrames ()
- Public Member Functions inherited from vtkPVAnimationCue
virtual void SetAnimatedElement (int)
 The index of the element of the property this cue animates. More...
virtual int GetAnimatedElement ()
void SetManipulator (vtkPVCueManipulator *)
 Get/Set the manipulator used to compute values for each instance in the animation. More...
virtual vtkPVCueManipulator * GetManipulator ()
virtual void SetEnabled (int)
 Enable/Disable this cue. More...
virtual int GetEnabled ()
virtual void EnabledOn ()
virtual void EnabledOff ()
virtual void SetUseAnimationTime (bool)
 When set to true, the manipulator is skipped and the key frame value is set by using the ClockTime directly. More...
virtual bool GetUseAnimationTime ()
void Initialize () override
 Overridden to ignore the calls when this->Enabled == false. More...
void Tick (double currenttime, double deltatime, double clocktime) override
void Finalize () override
- Public Member Functions inherited from vtkAnimationCue
vtkAnimationCue * NewInstance () const
virtual void SetTimeMode (int mode)
virtual int GetTimeMode ()
void SetTimeModeToRelative ()
void SetTimeModeToNormalized ()
virtual void SetStartTime (double)
virtual double GetStartTime ()
virtual void SetEndTime (double)
virtual double GetEndTime ()
virtual double GetAnimationTime ()
virtual double GetDeltaTime ()
virtual double GetClockTime ()
static vtkPVCameraAnimationCue * New ()
static vtkPVCameraAnimationCue * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPVKeyFrameAnimationCue
static vtkPVKeyFrameAnimationCue * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPVAnimationCue
static vtkPVAnimationCue * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkAnimationCue
static vtkAnimationCue * SafeDownCast (vtkObjectBase *o)
static vtkAnimationCue * New ()
 vtkPVCameraAnimationCue ()
 ~vtkPVCameraAnimationCue () override
- Protected Member Functions inherited from vtkPVKeyFrameAnimationCue
 vtkPVKeyFrameAnimationCue ()
 ~vtkPVKeyFrameAnimationCue () override
vtkPVKeyFrameCueManipulator * GetKeyFrameManipulator ()
- Protected Member Functions inherited from vtkPVAnimationCue
 vtkPVAnimationCue ()
 ~vtkPVAnimationCue () override
void StartCueInternal () override
void TickInternal (double currenttime, double deltatime, double clocktime) override
void EndCueInternal () override
- Protected Member Functions inherited from vtkAnimationCue
 vtkAnimationCue ()
 ~vtkAnimationCue ()
vtkPVRenderView * View
vtkSMProxy * DataSourceProxy
vtkSMProxy * TimeKeeper
- Protected Attributes inherited from vtkPVAnimationCue
unsigned long ObserverID
bool UseAnimationTime
int AnimatedElement
int Enabled
vtkAnimationCue * AnimationCue
vtkPVCueManipulator * Manipulator
- Protected Attributes inherited from vtkAnimationCue
 UNINITIALIZED
 INACTIVE
 ACTIVE
double StartTime
double EndTime
int TimeMode
double AnimationTime
double DeltaTime
double ClockTime
int CueState
- Public Attributes inherited from vtkAnimationCue
 TIMEMODE_NORMALIZED
 TIMEMODE_RELATIVE
vtkPVCameraAnimationCue is a specialization of the vtkPVKeyFrameAnimationCue suitable for animating cameras from a vtkPVRenderView.
Definition at line 21 of file vtkPVCameraAnimationCue.h.
Definition at line 25 of file vtkPVCameraAnimationCue.h.
◆ vtkPVCameraAnimationCue()
vtkPVCameraAnimationCue::vtkPVCameraAnimationCue ( )
◆ ~vtkPVCameraAnimationCue()
vtkPVCameraAnimationCue::~vtkPVCameraAnimationCue ( )
static vtkPVCameraAnimationCue* vtkPVCameraAnimationCue::New ( )
virtual const char* vtkPVCameraAnimationCue::GetClassName ( )
Reimplemented from vtkPVKeyFrameAnimationCue.
static int vtkPVCameraAnimationCue::IsTypeOf ( const char *  type)
virtual int vtkPVCameraAnimationCue::IsA ( const char *  type)
static vtkPVCameraAnimationCue* vtkPVCameraAnimationCue::SafeDownCast ( vtkObject *  o)
void vtkPVCameraAnimationCue::PrintSelf ( ostream &  os,
Reimplemented from vtkPVAnimationCue.
◆ SetView()
void vtkPVCameraAnimationCue::SetView ( vtkPVRenderView *  )
◆ GetView()
virtual vtkPVRenderView* vtkPVCameraAnimationCue::GetView ( )
◆ GetCamera()
vtkCamera* vtkPVCameraAnimationCue::GetCamera ( )
◆ SetMode()
void vtkPVCameraAnimationCue::SetMode ( int  mode)
◆ SetInterpolationMode()
void vtkPVCameraAnimationCue::SetInterpolationMode ( int  mode)
◆ GetTimeKeeper()
virtual vtkSMProxy* vtkPVCameraAnimationCue::GetTimeKeeper ( )
◆ SetTimeKeeper()
void vtkPVCameraAnimationCue::SetTimeKeeper ( vtkSMProxy *  )
◆ BeginUpdateAnimationValues()
void vtkPVCameraAnimationCue::BeginUpdateAnimationValues ( )
inlineoverridevirtual
This API makes it possible for vtk-level classes to update properties without actually linking with the ServerManager library. This only works since they object are created only on the client.
Implements vtkPVAnimationCue.
Definition at line 57 of file vtkPVCameraAnimationCue.h.
◆ SetAnimationValue()
void vtkPVCameraAnimationCue::SetAnimationValue ( int  index,
double  value
Definition at line 58 of file vtkPVCameraAnimationCue.h.
◆ EndUpdateAnimationValues()
void vtkPVCameraAnimationCue::EndUpdateAnimationValues ( )
◆ SetDataSourceProxy()
void vtkPVCameraAnimationCue::SetDataSourceProxy ( vtkSMProxy *  dataSourceProxy)
◆ View
vtkPVRenderView* vtkPVCameraAnimationCue::View
Definition at line 67 of file vtkPVCameraAnimationCue.h.
◆ DataSourceProxy
vtkSMProxy* vtkPVCameraAnimationCue::DataSourceProxy
Definition at line 68 of file vtkPVCameraAnimationCue.h.
◆ TimeKeeper
vtkSMProxy* vtkPVCameraAnimationCue::TimeKeeper
Definition at line 69 of file vtkPVCameraAnimationCue.h.
