vtkChartTextRepresentation Class Reference
representation to add text to vtkPVContextView More...
#include <vtkChartTextRepresentation.h>
Inheritance diagram for vtkChartTextRepresentation:
Collaboration diagram for vtkChartTextRepresentation:
enum  DesiredOutputPrecision
virtual double * GetPosition ()
 Get/Set the normalized text position in the scene when AnyLocation is used. More...
virtual void GetPosition (double &, double &)
virtual void GetPosition (double[2])
virtual void SetPosition (double, double)
void SetPosition (double[2])
void SetInteractivity (bool)
 Set the interactivity. More...
void SetTextProperty (vtkTextProperty *)
 Forwarded to vtkBlockItem. More...
void SetVisibility (bool val) override
virtual void MarkModified ()
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkChartTextRepresentation * New ()
static vtkChartTextRepresentation * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkChartTextRepresentation ()
 ~vtkChartTextRepresentation () override=default
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
enum  {
  AnyLocation = 0, LowerLeftCorner, LowerRightCorner, LowerCenter,
  UpperLeftCorner, UpperRightCorner, UpperCenter
void SetLabelLocation (int location)
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
vtkChartTextRepresentation supports adding text to vtkPVContextView. It is the vtkTextSourceRepresentation counterpart except for vtkPVContextView instead of vtkPVRenderView. It adds a vtkBlockItem to the vtkContextScene maintained by the vtkPVContextView to render the text.
In theory, we can support interacting with the label to place it interactively. For now, we only support anchoring the label at one of the predefined anchor locations or specifying normalized coordinates manually.
Definition at line 26 of file vtkChartTextRepresentation.h.
Definition at line 30 of file vtkChartTextRepresentation.h.
◆ anonymous enum
anonymous enum
Enumerator
AnyLocation
LowerLeftCorner
LowerRightCorner
LowerCenter
UpperLeftCorner
UpperRightCorner
UpperCenter
Definition at line 34 of file vtkChartTextRepresentation.h.
◆ vtkChartTextRepresentation()
vtkChartTextRepresentation::vtkChartTextRepresentation ( )
◆ ~vtkChartTextRepresentation()
vtkChartTextRepresentation::~vtkChartTextRepresentation ( )
overrideprotecteddefault
static vtkChartTextRepresentation* vtkChartTextRepresentation::New ( )
virtual const char* vtkChartTextRepresentation::GetClassName ( )
static int vtkChartTextRepresentation::IsTypeOf ( const char *  type)
virtual int vtkChartTextRepresentation::IsA ( const char *  type)
static vtkChartTextRepresentation* vtkChartTextRepresentation::SafeDownCast ( vtkObject *  o)
void vtkChartTextRepresentation::PrintSelf ( ostream &  os,
◆ SetLabelLocation()
void vtkChartTextRepresentation::SetLabelLocation ( int  location)
◆ GetPosition() [1/3]
virtual double* vtkChartTextRepresentation::GetPosition ( )
Default is { 0.05, 0.05 }.
◆ GetPosition() [2/3]
virtual void vtkChartTextRepresentation::GetPosition ( double &  ,
double &
◆ GetPosition() [3/3]
virtual void vtkChartTextRepresentation::GetPosition ( double  [2])
◆ SetPosition() [1/2]
virtual void vtkChartTextRepresentation::SetPosition ( double  ,
double
◆ SetPosition() [2/2]
void vtkChartTextRepresentation::SetPosition ( double  [2])
◆ SetInteractivity()
void vtkChartTextRepresentation::SetInteractivity ( bool  )
◆ SetTextProperty()
void vtkChartTextRepresentation::SetTextProperty ( vtkTextProperty *  )
◆ SetVisibility()
void vtkChartTextRepresentation::SetVisibility ( bool  val)
When the visibility of representation of false, all view passes are ignored.
◆ ProcessViewRequest()
int vtkChartTextRepresentation::ProcessViewRequest ( vtkInformationRequestKey *  request_type,
vtkInformation *  inInfo,
vtkInformation *  outInfo
Note
Starting with ParaView 5.8, this method is no longer called for hidden representation i.e. representations for which vtkDataRepresentation::GetVisibility() returns false.
◆ FillInputPortInformation()
int vtkChartTextRepresentation::FillInputPortInformation ( int  port,
vtkInformation *  info
overrideprotectedvirtual
Fill input port information.
◆ RequestData()
int vtkChartTextRepresentation::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
Overridden to invoke vtkCommand::UpdateDataEvent.
◆ AddToView()
bool vtkChartTextRepresentation::AddToView ( vtkView *  view)
◆ RemoveFromView()
bool vtkChartTextRepresentation::RemoveFromView ( vtkView *  view)
