Classes | Public Slots | Signals | Public Member Functions | Protected Slots | Protected Member Functions | Properties | Friends | List of all members
pqTabbedMultiViewWidget Class Reference
pqTabbedMultiViewWidget is used to to enable adding of multiple pqMultiViewWidget instances in tabs. More...
#include <pqTabbedMultiViewWidget.h>
Inheritance diagram for pqTabbedMultiViewWidget:
class  pqTabWidget
 Internal class used as the TabWidget. More...
Public Slots
virtual int createTab ()
virtual int createTab (pqServer *)
virtual int createTab (vtkSMViewLayoutProxy *)
virtual void closeTab (int)
void setCurrentTab (int index)
 Makes the tab at the given index current. More...
virtual void toggleFullScreen ()
 toggles fullscreen state. More...
virtual void toggleWidgetDecoration ()
 toggles decoration visibility on the current widget More...
virtual void lockViewSize (const QSize &)
 Locks the maximum size for each view-frame to the given size. More...
virtual void reset ()
 cleans up the layout. More...
QSize preview (const QSize &previewSize=QSize())
 Enter (or exit) preview mode. More...
void setDecorationsVisibility (bool)
 When set to false, all decorations including title frames, separators, tab-bars are hidden. More...
void showDecorations ()
void hideDecorations ()
Signals
void viewSizeLocked (bool)
 fired when lockViewSize() is called. More...
 pqTabbedMultiViewWidget (QWidget *parent=nullptr)
 ~pqTabbedMultiViewWidget () override
virtual QSize clientSize () const
 Returns the size for the tabs in the widget. More...
void setReadOnly (bool val)
 When set to true (off by default), the widget will not allow adding/removing tabs trough user interactions. More...
bool readOnly () const
void setTabVisibility (bool visible)
 Set the tab visibility. More...
bool tabVisibility () const
vtkSMViewLayoutProxy * layoutProxy () const
 Return the layout proxy for the current tab. More...
bool decorationsVisibility () const
 Returns whether frame decorations are shown. More...
pqMultiViewWidget * findTab (vtkSMViewLayoutProxy *) const
 Locate the pqMultiViewWidget associated with the vtkSMViewLayoutProxy held by this pqTabbedMultiViewWidget instance, if any. More...
void updateVisibleTabs ()
 While generally not necessary to call this, if the annotations for the layout proxies are changed after they are created, applications can use this method to refresh the tabs that are visible. More...
QList< QString > visibleTabLabels () const
 This is primarily for testing purposes. More...
void enableAnnotationFilter (const QString &annotationKey)
 APIs for filtering of tab widgets. More...
void disableAnnotationFilter ()
void setAnnotationFilterMatching (bool matching)
Protected Slots
virtual void proxyAdded (pqProxy *)
 slots connects to corresponding signals on pqServerManagerObserver. More...
virtual void proxyRemoved (pqProxy *)
virtual void serverRemoved (pqServer *)
virtual void currentTabChanged (int)
 called when the active tab changes. More...
virtual void onStateLoaded ()
 verifies that all views loaded from state are indeed assigned to some view layout, or we just assign them to one. More...
void contextMenuRequested (const QPoint &)
 called when context menu need to be created on the tab title. More...
void onLayoutNameChanged (pqServerManagerModelItem *)
bool eventFilter (QObject *obj, QEvent *event) override
Properties
bool readOnly
Friends
class pqInternals
This class directly listens to the server-manager to automatically create pqMultiViewWidget instances for every vtkSMViewLayoutProxy registered.
Definition at line 28 of file pqTabbedMultiViewWidget.h.
◆ pqTabbedMultiViewWidget()
pqTabbedMultiViewWidget::pqTabbedMultiViewWidget ( QWidget *  parent = nullptr)
◆ ~pqTabbedMultiViewWidget()
pqTabbedMultiViewWidget::~pqTabbedMultiViewWidget ( )
override
◆ clientSize()
virtual QSize pqTabbedMultiViewWidget::clientSize ( ) const
◆ setReadOnly()
void pqTabbedMultiViewWidget::setReadOnly ( bool  val)
◆ readOnly()
bool pqTabbedMultiViewWidget::readOnly ( ) const
◆ setTabVisibility()
void pqTabbedMultiViewWidget::setTabVisibility ( bool  visible)
To save some screen space when only one tab is needed, this can be set to false. True by default.
◆ tabVisibility()
bool pqTabbedMultiViewWidget::tabVisibility ( ) const
◆ layoutProxy()
vtkSMViewLayoutProxy* pqTabbedMultiViewWidget::layoutProxy ( ) const
◆ decorationsVisibility()
bool pqTabbedMultiViewWidget::decorationsVisibility ( ) const
◆ findTab()
pqMultiViewWidget* pqTabbedMultiViewWidget::findTab ( vtkSMViewLayoutProxy *  ) const
◆ enableAnnotationFilter()
void pqTabbedMultiViewWidget::enableAnnotationFilter ( const QString &  annotationKey)
This matches the API exposed by pqPipelineBrowserWidget.
◆ disableAnnotationFilter()
void pqTabbedMultiViewWidget::disableAnnotationFilter ( )
◆ setAnnotationFilterMatching()
void pqTabbedMultiViewWidget::setAnnotationFilterMatching ( bool  matching)
◆ updateVisibleTabs()
void pqTabbedMultiViewWidget::updateVisibleTabs ( )
◆ visibleTabLabels()
QList<QString> pqTabbedMultiViewWidget::visibleTabLabels ( ) const
Returns list of names for visible tabs.
◆ viewSizeLocked
void pqTabbedMultiViewWidget::viewSizeLocked ( bool  )
signal
◆ createTab [1/3]
virtual int pqTabbedMultiViewWidget::createTab ( )
virtualslot
◆ createTab [2/3]
virtual int pqTabbedMultiViewWidget::createTab ( pqServer *  )
virtualslot
◆ createTab [3/3]
virtual int pqTabbedMultiViewWidget::createTab ( vtkSMViewLayoutProxy *  )
virtualslot
◆ closeTab
virtual void pqTabbedMultiViewWidget::closeTab ( int  )
virtualslot
◆ setCurrentTab
void pqTabbedMultiViewWidget::setCurrentTab ( int  index)
slot
◆ setDecorationsVisibility
void pqTabbedMultiViewWidget::setDecorationsVisibility ( bool  )
slot
◆ showDecorations
void pqTabbedMultiViewWidget::showDecorations ( )
inlineslot
Definition at line 118 of file pqTabbedMultiViewWidget.h.
◆ hideDecorations
void pqTabbedMultiViewWidget::hideDecorations ( )
inlineslot
Definition at line 119 of file pqTabbedMultiViewWidget.h.
◆ toggleFullScreen
virtual void pqTabbedMultiViewWidget::toggleFullScreen ( )
virtualslot
◆ toggleWidgetDecoration
virtual void pqTabbedMultiViewWidget::toggleWidgetDecoration ( )
virtualslot
◆ lockViewSize
virtual void pqTabbedMultiViewWidget::lockViewSize ( const QSize &  )
virtualslot
Use empty QSize() instance to indicate no limits.
◆ reset
virtual void pqTabbedMultiViewWidget::reset ( )
virtualslot
◆ preview
QSize pqTabbedMultiViewWidget::preview ( const QSize &  previewSize = QSize())
slot
Preview mode is a mode were various widget's decorations are hidden and the widget is locked to the specified size. If the widget's current size is less than the size specified, then the widget is locked to a size with similar aspect ratio as requested. Pass in invalid (or empty) size to exit preview mode.
Preview mode is preferred over toggleWidgetDecoration and lockViewSize and is mutually exclusive with either. Mixing them can have unintended consequences.
Returns
the size to which the widget was locked. When unlocked, this will be QSize(QWIDGETSIZE_MAX, QWIDGETSIZE_MAX). When entering preview mode this will same as requested previewSize or a smaller size preserving aspect ratio as much as possible.
◆ proxyAdded
virtual void pqTabbedMultiViewWidget::proxyAdded ( pqProxy *  )
protectedvirtualslot
◆ proxyRemoved
virtual void pqTabbedMultiViewWidget::proxyRemoved ( pqProxy *  )
◆ serverRemoved
virtual void pqTabbedMultiViewWidget::serverRemoved ( pqServer *  )
◆ currentTabChanged
virtual void pqTabbedMultiViewWidget::currentTabChanged ( int  )
If the active tab is the "+" tab, then add a new tab to the widget.
◆ onStateLoaded
virtual void pqTabbedMultiViewWidget::onStateLoaded ( )
◆ contextMenuRequested
void pqTabbedMultiViewWidget::contextMenuRequested ( const QPoint &  )
protectedslot
◆ onLayoutNameChanged
void pqTabbedMultiViewWidget::onLayoutNameChanged ( pqServerManagerModelItem *  )
protectedslot
◆ eventFilter()
bool pqTabbedMultiViewWidget::eventFilter ( QObject *  obj,
QEvent *  event
◆ pqInternals
friend class pqInternals
friend
Definition at line 272 of file pqTabbedMultiViewWidget.h.
Property Documentation
◆ readOnly
readwrite
Definition at line 32 of file pqTabbedMultiViewWidget.h.
