Public Slots | Signals | Public Member Functions | Protected Slots | Protected Member Functions | Properties | Friends | List of all members
pqMultiViewWidget Class Reference
pqMultiViewWidget is a widget that manages layout of multiple views. More...
#include <pqMultiViewWidget.h>
Inherits QWidget.
Public Slots
void reload ()
 This forces the pqMultiViewWidget to reload its layout from the vtkSMViewLayoutProxy instance. More...
void makeFrameActive ()
 In a tabbed setup, when pqMultiViewWidget becomes active, this method should be called to ensure that the first view/frame in this widget is indeed made active, as the user would expect. More...
void lockViewSize (const QSize &)
 Locks the maximum size for each view-frame to the given size. More...
void reset ()
 cleans up the layout. More...
void destroyAllViews ()
 destroys each of the views present in this layout. More...
void setDecorationsVisibility (bool)
 Set the visibility for frame decorations and splitter handles. More...
void showDecorations ()
void hideDecorations ()
Signals
void frameActivated ()
 fired when a frame in this widget becomes active. More...
void decorationsVisibilityChanged (bool visible)
 fired when the decorations visibility is changed (by calling setDecorationsVisible). More...
 pqMultiViewWidget (QWidget *parent=nullptr, Qt::WindowFlags f=Qt::WindowFlags{})
 ~pqMultiViewWidget () override
void setLayoutManager (vtkSMViewLayoutProxy *)
 Get/Set the vtkSMViewLayoutProxy instance this widget is using as the layout manager. More...
vtkSMViewLayoutProxy * layoutManager () const
bool decorationsVisibility () const
 Returns whether window decorations and splitter handles are visible. More...
QList< vtkSMViewProxy * > viewProxies () const
 Returns list of views assigned to frames in this widget. More...
bool isViewAssigned (pqView *) const
 Returns true if the view has been assigned to this layout. More...
bool togglePopout ()
 pqMultiViewWidget supports popout mode i.e. More...
QSize preview (const QSize &previewSize=QSize())
 Enter (or exit) preview mode. More...
int activeFrameLocation () const
 Returns the location of the active frame, if any, else -1. More...
Protected Slots
void standardButtonPressed (int)
 Slots called on different signals fired by the nested frames or splitters. More...
void makeActive (pqViewFrame *frame)
 Makes a frame active. More...
void markActive (pqView *view)
 Marks the frame corresponding to the view, if present in the widget, as active. More...
void markActive (pqViewFrame *frame)
void swapPositions (const QString &)
 swap frame positions. More...
void proxyRemoved (pqProxy *)
 when a view proxy is unregistered, we ensure that the frame is marked as empty. More...
void viewAdded (pqView *)
 called when a new view is added. More...
void resizeEvent (QResizeEvent *evt) override
 If in preview mode, we need to update the widget's constraints based on the current widget geometry. More...
virtual pqViewFrame * newFrame (vtkSMProxy *view)
 Called whenever a new frame needs to be created for a view. More...
bool eventFilter (QObject *caller, QEvent *evt) override
 Event filter callback to detect when a sub-frame becomes active, so that we can mark it as such. More...
Properties
Friends
class pqInternals
It works together with a vtkSMViewLayoutProxy instance to keep track of the layout for the views. It's acceptable to create multiple instances of pqMultiViewWidget in the same application.
See also
pqHierarchicalGridLayout, pqHierarchicalGridWidget
Definition at line 28 of file pqMultiViewWidget.h.
◆ pqMultiViewWidget()
pqMultiViewWidget::pqMultiViewWidget ( QWidget *  parent = nullptr,
Qt::WindowFlags  f = Qt::WindowFlags{}
◆ ~pqMultiViewWidget()
pqMultiViewWidget::~pqMultiViewWidget ( )
override
◆ setLayoutManager()
void pqMultiViewWidget::setLayoutManager ( vtkSMViewLayoutProxy *  )
◆ layoutManager()
vtkSMViewLayoutProxy* pqMultiViewWidget::layoutManager ( ) const
◆ decorationsVisibility()
bool pqMultiViewWidget::decorationsVisibility ( ) const
◆ viewProxies()
QList<vtkSMViewProxy*> pqMultiViewWidget::viewProxies ( ) const
◆ isViewAssigned()
bool pqMultiViewWidget::isViewAssigned ( pqView *  ) const
◆ togglePopout()
bool pqMultiViewWidget::togglePopout ( )
the views could be laid out in separate popup widget rather than simply placing them under this pqMultiViewWidget frame. Use this method to toggle that. Returns true if the view is popped out at the end of this call, false otherwise.
◆ preview()
QSize pqMultiViewWidget::preview ( const QSize &  previewSize = QSize())
Preview mode is a mode were various widget's decorations are hidden and the widget is locked to the specified size. If the widget's current size is less than the size specified, then the widget is locked to a size with similar aspect ratio as requested. Pass in invalid (or empty) size to exit preview mode.
Preview mode is preferred over toggleWidgetDecoration and lockViewSize and is mutually exclusive with either. Mixing them can have unintended consequences.
Returns
the size to which the widget was locked. When unlocked, this will be QSize(QWIDGETSIZE_MAX, QWIDGETSIZE_MAX). When entering preview mode this will same as requested previewSize or a smaller size preserving aspect ratio as much as possible.
◆ activeFrameLocation()
int pqMultiViewWidget::activeFrameLocation ( ) const
◆ frameActivated
void pqMultiViewWidget::frameActivated ( )
signal
◆ decorationsVisibilityChanged
void pqMultiViewWidget::decorationsVisibilityChanged ( bool  visible)
signal
◆ reload
void pqMultiViewWidget::reload ( )
slot
One does not need to call this method explicitly, it is called automatically when the layoutManager is modified.
◆ makeFrameActive
void pqMultiViewWidget::makeFrameActive ( )
slot
◆ setDecorationsVisibility
void pqMultiViewWidget::setDecorationsVisibility ( bool  )
slot
◆ showDecorations
void pqMultiViewWidget::showDecorations ( )
inlineslot
Definition at line 126 of file pqMultiViewWidget.h.
◆ hideDecorations
void pqMultiViewWidget::hideDecorations ( )
inlineslot
Definition at line 127 of file pqMultiViewWidget.h.
◆ lockViewSize
void pqMultiViewWidget::lockViewSize ( const QSize &  )
slot
Use empty QSize() instance to indicate no limits.
◆ reset
void pqMultiViewWidget::reset ( )
slot
◆ destroyAllViews
void pqMultiViewWidget::destroyAllViews ( )
slot
Useful when user closes the frame expecting that all containing views are destroyed.
◆ standardButtonPressed
void pqMultiViewWidget::standardButtonPressed ( int  )
protectedslot
Note that these slots use this->sender(), hence these should not be called directly. These result in updating the layoutManager.
◆ makeActive
void pqMultiViewWidget::makeActive ( pqViewFrame *  frame)
protectedslot
This also call pqActiveObjects::setActiveView() to make the corresponding view active.
◆ markActive [1/2]
void pqMultiViewWidget::markActive ( pqView *  view)
protectedslot
Note that this method does not fire the activeChanged() signal.
◆ markActive [2/2]
void pqMultiViewWidget::markActive ( pqViewFrame *  frame)
protectedslot
◆ swapPositions
void pqMultiViewWidget::swapPositions ( const QString &  )
protectedslot
◆ proxyRemoved
void pqMultiViewWidget::proxyRemoved ( pqProxy *  )
protectedslot
◆ viewAdded
void pqMultiViewWidget::viewAdded ( pqView *  )
protectedslot
we update the layout if the view added belongs to this layout.
◆ resizeEvent
void pqMultiViewWidget::resizeEvent ( QResizeEvent *  evt)
overrideprotectedslot
We do that in this overridden method which is called when the geometry may have potentially changed.
◆ newFrame()
virtual pqViewFrame* pqMultiViewWidget::newFrame ( vtkSMProxy *  view)
protectedvirtual
Note that view may be null, in which case a place-holder frame is expected. The caller takes over the ownership of the created frame and will delete/re-parent it as and when appropriate.
◆ eventFilter()
bool pqMultiViewWidget::eventFilter ( QObject *  caller,
QEvent *  evt
◆ pqInternals
friend class pqInternals
friend
Definition at line 217 of file pqMultiViewWidget.h.
Property Documentation
readwrite
Definition at line 33 of file pqMultiViewWidget.h.
