Public Slots | Signals | Public Member Functions | Static Public Member Functions | Protected Slots | Protected Member Functions | Protected Attributes | List of all members
pqPipelineBrowserWidget Class Reference
pqPipelineBrowserWidget is the widget for the pipeline browser. More...
#include <pqPipelineBrowserWidget.h>
Inheritance diagram for pqPipelineBrowserWidget:
Collaboration diagram for pqPipelineBrowserWidget:
Public Slots
void setActiveView (pqView *)
 Set the active view. More...
- Public Slots inherited from pqFlatTreeView
void reset ()
void selectAll ()
void setCurrentIndex (const QModelIndex &index)
void expandAll ()
void expand (const QModelIndex &index)
void collapse (const QModelIndex &index)
void scrollTo (const QModelIndex &index)
Signals
void deleteKey ()
 Fired when the delete key is pressed. More...
- Signals inherited from pqFlatTreeView
void activated (const QModelIndex &index)
void clicked (const QModelIndex &index)
 pqPipelineBrowserWidget (QWidget *parent=nullptr)
 ~pqPipelineBrowserWidget () override
bool eventFilter (QObject *object, QEvent *e) override
 Used to monitor the key press events in the tree view. More...
void setSelectionVisibility (bool visible)
 Set the visibility of selected items. More...
void enableAnnotationFilter (const QString &annotationKey)
 Set Annotation filter to use. More...
void disableAnnotationFilter ()
 Disable any Annotation filter. More...
void setAnnotationFilterMatching (bool matching)
 Choose wether Annotation filter should display matching or non-matching sources. More...
void enableSessionFilter (vtkSession *session)
 Set Session filter to use. More...
void disableSessionFilter ()
 Disable any Session filter. More...
void setModel (pqPipelineModel *model)
 Overload of pqFlatTreeView::setModel. More...
QModelIndex pipelineModelIndex (const QModelIndex &index) const
 TODO document. More...
const pqPipelineModel * getPipelineModel (const QModelIndex &index) const
QMenu * contextMenu () const
 Provides access to the context menu. More...
- Public Member Functions inherited from pqFlatTreeView
 pqFlatTreeView (QWidget *parent=nullptr)
 Creates a flat tree view. More...
 ~pqFlatTreeView () override
 Used to monitor the header view. More...
QAbstractItemModel * getModel () const
void setModel (QAbstractItemModel *model)
QModelIndex getRootIndex () const
void setRootIndex (const QModelIndex &index)
QItemSelectionModel * getSelectionModel () const
void setSelectionModel (QItemSelectionModel *selectionModel)
SelectionBehavior getSelectionBehavior () const
void setSelectionBehavior (SelectionBehavior behavior)
SelectionMode getSelectionMode () const
void setSelectionMode (SelectionMode mode)
QHeaderView * getHeader () const
 Gets whether or not the column size is managed by the view. More...
void setHeader (QHeaderView *headerView)
bool isColumnSizeManaged () const
void setColumnSizeManaged (bool managed)
 Sets whether or not the column size is managed by the view. More...
int getIconSize () const
void setIconSize (int iconSize)
bool isIndexHidden (const QModelIndex &index) const
void getVisibleRect (const QModelIndex &index, QRect &area) const
QModelIndex getIndexVisibleAt (const QPoint &point) const
QModelIndex getIndexCellAt (const QPoint &point) const
void getSelectionIn (const QRect &rect, QItemSelection &items) const
bool isIndexExpanded (const QModelIndex &index) const
QModelIndex getNextVisibleIndex (const QModelIndex &index, const QModelIndex &root=QModelIndex()) const
QModelIndex getRelativeIndex (const QString &id, const QModelIndex &root=QModelIndex()) const
void getRelativeIndexId (const QModelIndex &index, QString &id, const QModelIndex &root=QModelIndex()) const
bool startEditing (const QModelIndex &index)
void finishEditing ()
void cancelEditing ()
static void setVisibility (bool visible, pqOutputPort *port)
 static method to sets the visibility of a pqOutputPort More...
Protected Slots
void handleIndexClicked (const QModelIndex &index)
void expandWithModelIndexTranslation (const QModelIndex &)
- Protected Slots inherited from pqFlatTreeView
void insertRows (const QModelIndex &parent, int start, int end)
void startRowRemoval (const QModelIndex &parent, int start, int end)
void finishRowRemoval (const QModelIndex &parent, int start, int end)
void insertColumns (const QModelIndex &parent, int start, int end)
void startColumnRemoval (const QModelIndex &parent, int start, int end)
void finishColumnRemoval (const QModelIndex &parent, int start, int end)
void updateData (const QModelIndex &topLeft, const QModelIndex &bottomRight)
void setVisibility (bool visible, const QModelIndexList &indices)
 sets the visibility for items in the indices list. More...
void contextMenuEvent (QContextMenuEvent *e) override
bool viewportEvent (QEvent *e) override
 Overridden to pass changed font to pqPipelineModel. More...
- Protected Member Functions inherited from pqFlatTreeView
int horizontalOffset () const
int verticalOffset () const
void resizeEvent (QResizeEvent *e) override
void paintEvent (QPaintEvent *e) override
QStyleOptionViewItem getViewOptions () const
void keyPressEvent (QKeyEvent *e) override
void keyboardSearch (const QString &search)
void mousePressEvent (QMouseEvent *e) override
void mouseMoveEvent (QMouseEvent *e) override
void mouseReleaseEvent (QMouseEvent *e) override
void mouseDoubleClickEvent (QMouseEvent *e) override
bool event (QEvent *e) override
pqPipelineModel * PipelineModel
pqPipelineAnnotationFilterModel * FilteredPipelineModel
QPointer< QMenu > ContextMenu
- Public Types inherited from pqFlatTreeView
enum  SelectionBehavior { SelectItems, SelectRows, SelectColumns }
enum  SelectionMode { NoSelection, SingleSelection, ExtendedSelection }
This is a replacement for pqPipelineBrowser.
Definition at line 24 of file pqPipelineBrowserWidget.h.
◆ pqPipelineBrowserWidget()
pqPipelineBrowserWidget::pqPipelineBrowserWidget ( QWidget *  parent = nullptr)
◆ ~pqPipelineBrowserWidget()
pqPipelineBrowserWidget::~pqPipelineBrowserWidget ( )
override
◆ eventFilter()
bool pqPipelineBrowserWidget::eventFilter ( QObject *  object,
QEvent *  e
override
Returns True if the event should not be sent to the object.
◆ setSelectionVisibility()
void pqPipelineBrowserWidget::setSelectionVisibility ( bool  visible)
◆ enableAnnotationFilter()
void pqPipelineBrowserWidget::enableAnnotationFilter ( const QString &  annotationKey)
◆ disableAnnotationFilter()
void pqPipelineBrowserWidget::disableAnnotationFilter ( )
◆ setAnnotationFilterMatching()
void pqPipelineBrowserWidget::setAnnotationFilterMatching ( bool  matching)
Default is matching.
◆ enableSessionFilter()
void pqPipelineBrowserWidget::enableSessionFilter ( vtkSession *  session)
◆ disableSessionFilter()
void pqPipelineBrowserWidget::disableSessionFilter ( )
◆ setModel()
void pqPipelineBrowserWidget::setModel ( pqPipelineModel *  model)
◆ pipelineModelIndex()
QModelIndex pqPipelineBrowserWidget::pipelineModelIndex ( const QModelIndex &  index) const
TODO document.
Note
Moved from proteced
◆ getPipelineModel()
const pqPipelineModel* pqPipelineBrowserWidget::getPipelineModel ( const QModelIndex &  index) const
◆ setVisibility() [1/2]
static void pqPipelineBrowserWidget::setVisibility ( bool  visible,
pqOutputPort *  port
◆ contextMenu()
QMenu* pqPipelineBrowserWidget::contextMenu ( ) const
◆ deleteKey
void pqPipelineBrowserWidget::deleteKey ( )
signal
Typically implies that the selected items need to be deleted.
◆ setActiveView
void pqPipelineBrowserWidget::setActiveView ( pqView *  )
slot
By default connected to pqActiveObjects::viewChanged() so it keeps track of the active view.
◆ handleIndexClicked
void pqPipelineBrowserWidget::handleIndexClicked ( const QModelIndex &  index)
protectedslot
◆ expandWithModelIndexTranslation
void pqPipelineBrowserWidget::expandWithModelIndexTranslation ( const QModelIndex &  )
protectedslot
◆ setVisibility() [2/2]
const QModelIndexList &  indices
◆ contextMenuEvent()
void pqPipelineBrowserWidget::contextMenuEvent ( QContextMenuEvent *  e)
◆ viewportEvent()
bool pqPipelineBrowserWidget::viewportEvent ( QEvent *  e)
◆ PipelineModel
pqPipelineModel* pqPipelineBrowserWidget::PipelineModel
Definition at line 123 of file pqPipelineBrowserWidget.h.
◆ FilteredPipelineModel
pqPipelineAnnotationFilterModel* pqPipelineBrowserWidget::FilteredPipelineModel
Definition at line 124 of file pqPipelineBrowserWidget.h.
◆ ContextMenu
QPointer<QMenu> pqPipelineBrowserWidget::ContextMenu
Definition at line 125 of file pqPipelineBrowserWidget.h.
