Public Slots | Signals | Public Member Functions | Static Public Member Functions | Protected Slots | List of all members
pqSpreadSheetView Class Reference
View for spread-sheet view. More...
#include <pqSpreadSheetView.h>
Inheritance diagram for pqSpreadSheetView:
Collaboration diagram for pqSpreadSheetView:
Public Slots
void onAddRepresentation (pqRepresentation *)
 Called when a new repr is added. More...
- Public Slots inherited from pqView
virtual void render ()
 Request a StillRender on idle. More...
virtual void forceRender ()
 Forces an immediate render. More...
void cancelPendingRenders ()
 Cancels any pending renders. More...
virtual void undo ()
 Called to undo interaction. More...
virtual void redo ()
 Called to redo interaction. More...
virtual void resetDisplay (bool closest=false)
 Called to reset the view's display. More...
Signals
void showing (pqDataRepresentation *repr)
 Fired when the currently shown representation changes. More...
void viewportUpdated ()
- Signals inherited from pqView
void updateDataEvent ()
 Fired when the vtkSMViewProxy fires the vtkCommand::UpdateDataEvent The view proxy fires this event at the end of vtkSMViewProxy::Update() when the update executes, not just when the method is called. More...
void representationAdded (pqRepresentation *)
 Fired after a representation has been added to this view. More...
void representationRemoved (pqRepresentation *)
 Fired after a representation has been removed from this view. More...
void beginRender ()
 Fired when the render module fires a vtkCommand::StartEvent signalling the beginning of rendering. More...
void endRender ()
 Fired when the render module fires a vtkCommand::EndEvent signalling the end of rendering. More...
void representationVisibilityChanged (pqRepresentation *repr, bool visible)
 Fired when any representation visibility changes. More...
void canUndoChanged (bool)
 Fired when interaction undo stack status changes. More...
void canRedoChanged (bool)
void selected (pqOutputPort *opport)
 Fired when a selection is made in this view. More...
void picked (pqOutputPort *opport)
 Fired when a port is picked. More...
void beginProgress ()
 Fired before doing any actions that may result in progress events that must be reported by the client. More...
void endProgress ()
 Fired after performing any actions that may result in progress events. More...
void progress (const QString &message, int percent_progress)
 Fired to notify the current execution progress. More...
void multipleSelected (QList< pqOutputPort * > opports)
 Fired when UseMultipleRepresentationSelection is set to on and selection on multiple representations is made in this view. More...
- Signals inherited from pqProxy
void nameChanged (pqServerManagerModelItem *)
 Fired when the name of the proxy is changed. More...
void modifiedStateChanged (pqServerManagerModelItem *)
 Fired when the modified status changes for the proxy. More...
 pqSpreadSheetView (const QString &group, const QString &name, vtkSMViewProxy *viewModule, pqServer *server, QObject *parent=nullptr)
 ~pqSpreadSheetView () override
pqSpreadSheetViewModel * getViewModel ()
 Get the internal model for the view. More...
pqDataRepresentation * activeRepresentation () const
 Returns the currently visible representation, if any. More...
- Public Member Functions inherited from pqView
 ~pqView () override
vtkSMViewProxy * getViewProxy () const
 Returns the internal render Module proxy associated with this object. More...
virtual vtkView * getClientSideView () const
 Return the client-side vtkView encapsulated by this view (if any), or return nullptr. More...
QWidget * widget ()
 Return a widget associated with this view. More...
virtual bool supportsUndo () const
 Returns if this view module can support undo/redo. More...
virtual bool supportsCapture () const
 Returns if this view module can support image capture. More...
QString getViewType () const
 Returns the type of this view module. More...
virtual bool canUndo () const
 Returns true if undo can be done. More...
virtual bool canRedo () const
 Returns true if redo can be done. More...
virtual QSize getSize ()
 Returns the current size of the rendering context. More...
bool hasRepresentation (pqRepresentation *repr) const
 This method checks if the representation is shown in this view. More...
int getNumberOfRepresentations () const
 Returns the number representations in the view. More...
int getNumberOfVisibleRepresentations () const
int getNumberOfVisibleDataRepresentations () const
pqRepresentation * getRepresentation (int index) const
 Returns the representation for the specified index where (index < getNumberOfRepresentations()). More...
QList< pqRepresentation * > getRepresentations () const
 Returns a list of representations in this view. More...
bool canDisplay (pqOutputPort *opPort) const
 This method returns is any pqPipelineSource can be displayed in this view. More...
- Public Member Functions inherited from pqProxy
 pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr)
 ~pqProxy () override
pqServer * getServer () const
 Get the server on which this proxy exists. More...
void rename (const QString &newname)
 This is a convenience method. More...
const QString & getSMName ()
 Get the name with which this proxy is registered on the server manager. More...
const QString & getSMGroup ()
vtkSMProxy * getProxy () const
 Get the vtkSMProxy this object stands for. More...
ModifiedState modifiedState () const
 Gets whether or not the source has been modified. More...
void setModifiedState (ModifiedState modified)
 Sets whether or not the source has been modified. More...
vtkPVXMLElement * getHints () const
 Returns the hints for this proxy, if any. More...
QList< vtkSMProxy * > getHelperProxies () const
 Returns a list of all helper proxies. More...
QList< vtkSMProxy * > getHelperProxies (const QString &key) const
 Returns a list of all the helper proxies added with a given key. More...
QList< QString > getHelperKeys () const
 Returns the keys for helper proxies. More...
virtual void addHelperProxy (const QString &key, vtkSMProxy *)
 Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More...
void removeHelperProxy (const QString &key, vtkSMProxy *)
void updateHelperProxies () const
 Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More...
vtkSMSessionProxyManager * proxyManager () const
 Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More...
bool userModifiedSMName ()
 Return whether or not the user has modified the GUI name of the source. More...
- Public Member Functions inherited from pqServerManagerModelItem
 pqServerManagerModelItem (QObject *parent=nullptr)
 ~pqServerManagerModelItem () override
static QString spreadsheetViewType ()
- Static Public Member Functions inherited from pqProxy
static pqProxy * findProxyWithHelper (vtkSMProxy *aproxy, QString &key)
 Returns a pqProxy instance, of any, whose helper proxy is the aproxy. More...
static std::string rstToHtml (const char *rstStr)
 convert proxy documentation from RST to HTML (so that it can be used in Qt) More...
static QString rstToHtml (const QString &rstStr)
Protected Slots
void updateRepresentationVisibility (pqRepresentation *repr, bool visible)
 Called to ensure that at most 1 repr is visible at a time. More...
void onEndRender ()
 Called at end of every render. More...
void onCreateSelection (vtkSMSourceProxy *selSource)
 When user creates a "surface" selection on the view. More...
void onSelectionOnly ()
 Called when checkbox "Show Only Selected Elements" is updated. More...
void onFontSizeChanged ()
 Called when the "Font Size" property is updated. More...
QWidget * createWidget () override
 Create a QWidget for the view's viewport. More...
- Protected Slots inherited from pqProxy
void onProxyRegistered (const QString &, const QString &, vtkSMProxy *)
void onProxyUnRegistered (const QString &, const QString &, vtkSMProxy *)
- Public Types inherited from pqView
enum  SelectionModifier { PV_SELECTION_DEFAULT = 0, PV_SELECTION_ADDITION, PV_SELECTION_SUBTRACTION, PV_SELECTION_TOGGLE }
- Public Types inherited from pqProxy
enum  ModifiedState { UNINITIALIZED, MODIFIED, UNMODIFIED }
 The modification state of this proxy. More...
- Protected Member Functions inherited from pqView
 pqView (const QString &type, const QString &group, const QString &name, vtkSMViewProxy *view, pqServer *server, QObject *parent=nullptr)
 Constructor: type :- view type. More...
void initialize () override
 Use this method to initialize the pqObject state using the underlying vtkSMProxy. More...
virtual QWidget * createWidget ()=0
 Subclasses must override this method to create a widget for the view. More...
- Protected Member Functions inherited from pqProxy
void setSMName (const QString &new_name)
 Make this pqProxy take on a new identity. More...
virtual void addInternalHelperProxy (const QString &key, vtkSMProxy *) const
virtual void removeInternalHelperProxy (const QString &key, vtkSMProxy *) const
- Protected Member Functions inherited from pqServerManagerModelItem
vtkEventQtSlotConnect * getConnector ()
 All subclasses generally need some vtkEventQtSlotConnect instance to connect to VTK events. More...
It can show data from any source/filter on the client. Uses pqSpreadSheetViewModel, pqSpreadSheetViewWidget and pqSpreadSheetViewSelectionModel.
Definition at line 18 of file pqSpreadSheetView.h.
◆ pqSpreadSheetView()
pqSpreadSheetView::pqSpreadSheetView ( const QString &  group,
const QString &  name,
vtkSMViewProxy *  viewModule,
pqServer *  server,
QObject *  parent = nullptr
◆ ~pqSpreadSheetView()
pqSpreadSheetView::~pqSpreadSheetView ( )
override
◆ spreadsheetViewType()
static QString pqSpreadSheetView::spreadsheetViewType ( )
inlinestatic
Definition at line 24 of file pqSpreadSheetView.h.
◆ getViewModel()
pqSpreadSheetViewModel* pqSpreadSheetView::getViewModel ( )
◆ activeRepresentation()
pqDataRepresentation* pqSpreadSheetView::activeRepresentation ( ) const
Note that this view supports showing only one representation at a time.
◆ showing
void pqSpreadSheetView::showing ( pqDataRepresentation *  repr)
signal
repr may be nullptr.
◆ viewportUpdated
void pqSpreadSheetView::viewportUpdated ( )
signal
◆ onAddRepresentation
void pqSpreadSheetView::onAddRepresentation ( pqRepresentation *  )
slot
◆ updateRepresentationVisibility
void pqSpreadSheetView::updateRepresentationVisibility ( pqRepresentation *  repr,
bool  visible
protectedslot
◆ onEndRender
void pqSpreadSheetView::onEndRender ( )
protectedslot
We update the table view.
◆ onCreateSelection
void pqSpreadSheetView::onCreateSelection ( vtkSMSourceProxy *  selSource)
protectedslot
◆ onSelectionOnly
void pqSpreadSheetView::onSelectionOnly ( )
protectedslot
◆ onFontSizeChanged
void pqSpreadSheetView::onFontSizeChanged ( )
protectedslot
◆ createWidget
QWidget* pqSpreadSheetView::createWidget ( )
overrideprotectedslot
