Abstraction of style away from button. More...
#include <vtkPVCameraManipulator.h>
| virtual void | OnMouseMove (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *iren) |
| virtual void | OnButtonDown (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *iren) |
| virtual void | OnButtonUp (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *iren) |
| virtual void | StartInteraction () |
| Event bindings controlling the effects of pressing mouse buttons or moving the mouse. More... | |
| virtual void | EndInteraction () |
| virtual void | OnKeyUp (vtkRenderWindowInteractor *iren) |
| These methods are called on all registered manipulators, not just the active one. More... | |
| virtual void | OnKeyDown (vtkRenderWindowInteractor *iren) |
| virtual void | SetButton (int) |
| These settings determine which button and modifiers the manipulator responds to. More... | |
| virtual int | GetButton () |
| virtual void | SetShift (int) |
| virtual int | GetShift () |
| virtual void | ShiftOn () |
| virtual void | ShiftOff () |
| virtual void | SetControl (int) |
| virtual int | GetControl () |
| virtual void | ControlOn () |
| virtual void | ControlOff () |
| virtual void | SetCenter (double, double, double) |
| For setting the center of rotation. More... | |
| virtual void | SetCenter (double [3]) |
| virtual double * | GetCenter () |
| virtual void | GetCenter (double &, double &, double &) |
| virtual void | GetCenter (double [3]) |
| virtual void | SetRotationFactor (double) |
| Set and get the rotation factor. More... | |
| virtual double | GetRotationFactor () |
| virtual void | SetManipulatorName (const char *) |
| Set and get the manipulator name. More... | |
| virtual char * | GetManipulatorName () |
| static vtkPVCameraManipulator * | New () |
| static vtkPVCameraManipulator * | SafeDownCast (vtkObject *o) |
| void | ComputeDisplayCenter (vtkRenderer *ren) |
Protected Attributes | |
| char * | ManipulatorName |
| int | Button |
| int | Shift |
| int | Control |
| double | Center [3] |
| double | RotationFactor |
| double | DisplayCenter [2] |
| vtkCameraManipulatorGUIHelper * | GUIHelper |
| void | SetGUIHelper (vtkCameraManipulatorGUIHelper *) |
| Get/Set the GUI helper. More... | |
| virtual vtkCameraManipulatorGUIHelper * | GetGUIHelper () |
| vtkPVCameraManipulator () | |
| ~vtkPVCameraManipulator () override | |
vtkPVCameraManipulator is a superclass foractions inside an interactor style and associated with a single button. An example might be rubber-band bounding-box zoom. This abstraction allows a camera manipulator to be assigned to any button. This super class might become a subclass of vtkInteractorObserver in the future.
Definition at line 24 of file vtkPVCameraManipulator.h.
Definition at line 28 of file vtkPVCameraManipulator.h.
Reimplemented in vtkPVTrackballMultiRotate, vtkPVTrackballZoom, vtkPVTrackballPanAxisConstrained, vtkPVTrackballMoveActor, vtkPVTrackballPan, vtkPVJoystickFly, vtkPVTrackballRoll, vtkPVTrackballZoomToMouse, vtkPVJoystickFlyIn, vtkPVJoystickFlyOut, vtkPVTrackballEnvironmentRotate, and vtkPVTrackballRotate.
Reimplemented in vtkPVTrackballMultiRotate, vtkPVTrackballZoom, vtkPVTrackballPanAxisConstrained, vtkPVTrackballMoveActor, vtkPVTrackballPan, vtkPVJoystickFly, vtkPVTrackballRoll, vtkPVTrackballZoomToMouse, vtkPVJoystickFlyIn, vtkPVJoystickFlyOut, and vtkPVTrackballRotate.
Hence, these should just be used to record state and not perform any interactions.
Reimplemented in vtkPVTrackballRotate, and vtkPVTrackballPanAxisConstrained.
Button can be either 1 (left), 2 (middle), and 3 right.
| void vtkPVCameraManipulator::SetGUIHelper | ( | vtkCameraManipulatorGUIHelper * | ) |
Definition at line 106 of file vtkPVCameraManipulator.h.
Definition at line 108 of file vtkPVCameraManipulator.h.
Definition at line 109 of file vtkPVCameraManipulator.h.
Definition at line 110 of file vtkPVCameraManipulator.h.
Definition at line 112 of file vtkPVCameraManipulator.h.
Definition at line 113 of file vtkPVCameraManipulator.h.
Definition at line 114 of file vtkPVCameraManipulator.h.
Definition at line 117 of file vtkPVCameraManipulator.h.
1.8.13 on Tue Oct 13 2026
