vtkPVTrackballPanAxisConstrained Class Reference
Pans camera with x y mouse movements. More...
#include <vtkPVTrackballPanAxisConstrained.h>
Inheritance diagram for vtkPVTrackballPanAxisConstrained:
Collaboration diagram for vtkPVTrackballPanAxisConstrained:
typedef vtkPVCameraManipulator Superclass
- Public Types inherited from vtkPVCameraManipulator
void OnKeyUp (vtkRenderWindowInteractor *) override
void OnKeyDown (vtkRenderWindowInteractor *) override
void OnMouseMove (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *iren) override
void OnButtonDown (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *iren) override
void OnButtonUp (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *iren) override
- Public Member Functions inherited from vtkPVCameraManipulator
virtual void SetButton (int)
virtual int GetButton ()
virtual void SetShift (int)
virtual int GetShift ()
virtual void ShiftOn ()
virtual void ShiftOff ()
virtual void SetControl (int)
virtual int GetControl ()
virtual void ControlOn ()
virtual void ControlOff ()
virtual void SetCenter (double [3])
virtual doubleGetCenter ()
virtual void GetCenter (double [3])
virtual vtkCameraManipulatorGUIHelperGetGUIHelper ()
static vtkPVTrackballPanAxisConstrainedNew ()
static vtkPVTrackballPanAxisConstrainedSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPVCameraManipulator
static vtkPVCameraManipulatorNew ()
static vtkPVCameraManipulatorSafeDownCast (vtkObject *o)
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkPVTrackballPanAxisConstrained ()
 ~vtkPVTrackballPanAxisConstrained () override
 vtkPVTrackballPanAxisConstrained (const vtkPVTrackballPanAxisConstrained &)=delete
void operator= (const vtkPVTrackballPanAxisConstrained &)=delete
- Protected Member Functions inherited from vtkPVCameraManipulator
 vtkPVCameraManipulator ()
 ~vtkPVCameraManipulator () override
std::unique_ptr< Internal > Internals
- Protected Attributes inherited from vtkPVCameraManipulator
char * ManipulatorName
int Button
int Shift
int Control
double Center [3]
double RotationFactor
double DisplayCenter [2]
vtkCameraManipulatorGUIHelperGUIHelper
vtkPVTrackballPanAxisConstrained allows the user to interactively manipulate the camera, the viewpoint of the scene. Moving the mouse down zooms in. Up zooms out. This manipulator has not been extended to parallel projection yet. It works in perspective by rotating the camera. This manipulator allows constraining the axis of movement
Definition at line 22 of file vtkPVTrackballPanAxisConstrained.h.
Definition at line 27 of file vtkPVTrackballPanAxisConstrained.h.
◆ vtkPVTrackballPanAxisConstrained() [1/2]
vtkPVTrackballPanAxisConstrained::vtkPVTrackballPanAxisConstrained ( )
◆ ~vtkPVTrackballPanAxisConstrained()
vtkPVTrackballPanAxisConstrained::~vtkPVTrackballPanAxisConstrained ( )
◆ vtkPVTrackballPanAxisConstrained() [2/2]
vtkPVTrackballPanAxisConstrained::vtkPVTrackballPanAxisConstrained ( const vtkPVTrackballPanAxisConstrained )
protecteddelete
static vtkPVTrackballPanAxisConstrained* vtkPVTrackballPanAxisConstrained::New ( )
virtual const char* vtkPVTrackballPanAxisConstrained::GetClassName ( )
Reimplemented from vtkPVCameraManipulator.
static int vtkPVTrackballPanAxisConstrained::IsTypeOf ( const char *  type)
virtual int vtkPVTrackballPanAxisConstrained::IsA ( const char *  type)
static vtkPVTrackballPanAxisConstrained* vtkPVTrackballPanAxisConstrained::SafeDownCast ( vtkObject o)
void vtkPVTrackballPanAxisConstrained::PrintSelf ( ostream &  os,
◆ OnKeyUp()
void vtkPVTrackballPanAxisConstrained::OnKeyUp ( vtkRenderWindowInteractor iren)
These methods are called on all registered manipulators, not just the active one.
Hence, these should just be used to record state and not perform any interactions.
◆ OnKeyDown()
void vtkPVTrackballPanAxisConstrained::OnKeyDown ( vtkRenderWindowInteractor iren)
◆ OnMouseMove()
void vtkPVTrackballPanAxisConstrained::OnMouseMove ( int  x,
int  y,
vtkRenderer ren,
◆ OnButtonDown()
void vtkPVTrackballPanAxisConstrained::OnButtonDown ( int  x,
int  y,
vtkRenderer ren,
◆ OnButtonUp()
void vtkPVTrackballPanAxisConstrained::OnButtonUp ( int  x,
int  y,
vtkRenderer ren,
◆ operator=()
void vtkPVTrackballPanAxisConstrained::operator= ( const vtkPVTrackballPanAxisConstrained )
protecteddelete
◆ Internals
std::unique_ptr<Internal> vtkPVTrackballPanAxisConstrained::Internals
Definition at line 50 of file vtkPVTrackballPanAxisConstrained.h.
