vtkPVTrackballZoom Class Reference
Zooms camera with vertical mouse movement. More...
#include <vtkPVTrackballZoom.h>
Inheritance diagram for vtkPVTrackballZoom:
Collaboration diagram for vtkPVTrackballZoom:
typedef vtkPVCameraManipulator Superclass
- Public Types inherited from vtkPVCameraManipulator
virtual void SetUseDollyForPerspectiveProjection (bool)
 Set this to false (true by default) to not dolly in case of perspective projection and use zoom i.e. More...
virtual bool GetUseDollyForPerspectiveProjection ()
virtual void UseDollyForPerspectiveProjectionOn ()
virtual void UseDollyForPerspectiveProjectionOff ()
void OnButtonDown (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *rwi) override
void OnButtonUp (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *rwi) override
- Public Member Functions inherited from vtkPVCameraManipulator
virtual void OnKeyUp (vtkRenderWindowInteractor *iren)
virtual void OnKeyDown (vtkRenderWindowInteractor *iren)
virtual void SetButton (int)
virtual int GetButton ()
virtual void SetShift (int)
virtual int GetShift ()
virtual void ShiftOn ()
virtual void ShiftOff ()
virtual void SetControl (int)
virtual int GetControl ()
virtual void ControlOn ()
virtual void ControlOff ()
virtual void SetCenter (double [3])
virtual doubleGetCenter ()
virtual void GetCenter (double [3])
virtual vtkCameraManipulatorGUIHelperGetGUIHelper ()
static vtkPVTrackballZoomNew ()
static vtkPVTrackballZoomSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPVCameraManipulator
static vtkPVCameraManipulatorNew ()
static vtkPVCameraManipulatorSafeDownCast (vtkObject *o)
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkPVTrackballZoom ()
 ~vtkPVTrackballZoom () override
 vtkPVTrackballZoom (const vtkPVTrackballZoom &)=delete
void operator= (const vtkPVTrackballZoom &)=delete
- Protected Member Functions inherited from vtkPVCameraManipulator
 vtkPVCameraManipulator ()
 ~vtkPVCameraManipulator () override
bool UseDollyForPerspectiveProjection
double ZoomScale
- Protected Attributes inherited from vtkPVCameraManipulator
char * ManipulatorName
int Button
int Shift
int Control
double Center [3]
double RotationFactor
double DisplayCenter [2]
vtkCameraManipulatorGUIHelperGUIHelper
vtkPVTrackballZoom allows the user to interactively manipulate the camera, the viewpoint of the scene. Moving the mouse down zooms in. Up zooms out.
When zooming in Perpective projection, this manipulator by default, dollys (rather than zooms) i.e. moves the camera further (or farther) in the view direction. This is default behavior. You can change that to use zoom instead i.e. change view angle on camera, by setting UseDollyForPerspectiveProjection to off.
Definition at line 24 of file vtkPVTrackballZoom.h.
Definition at line 28 of file vtkPVTrackballZoom.h.
◆ vtkPVTrackballZoom() [1/2]
vtkPVTrackballZoom::vtkPVTrackballZoom ( )
◆ ~vtkPVTrackballZoom()
vtkPVTrackballZoom::~vtkPVTrackballZoom ( )
◆ vtkPVTrackballZoom() [2/2]
vtkPVTrackballZoom::vtkPVTrackballZoom ( const vtkPVTrackballZoom )
protecteddelete
static vtkPVTrackballZoom* vtkPVTrackballZoom::New ( )
virtual const char* vtkPVTrackballZoom::GetClassName ( )
Reimplemented from vtkPVCameraManipulator.
Reimplemented in vtkPVTrackballZoomToMouse.
static int vtkPVTrackballZoom::IsTypeOf ( const char *  type)
virtual int vtkPVTrackballZoom::IsA ( const char *  type)
static vtkPVTrackballZoom* vtkPVTrackballZoom::SafeDownCast ( vtkObject o)
void vtkPVTrackballZoom::PrintSelf ( ostream &  os,
◆ OnMouseMove()
void vtkPVTrackballZoom::OnMouseMove ( int  x,
int  y,
vtkRenderer ren,
vtkRenderWindowInteractor rwi
◆ OnButtonDown()
void vtkPVTrackballZoom::OnButtonDown ( int  x,
int  y,
vtkRenderer ren,
◆ OnButtonUp()
void vtkPVTrackballZoom::OnButtonUp ( int  x,
int  y,
vtkRenderer ren,
◆ SetUseDollyForPerspectiveProjection()
virtual void vtkPVTrackballZoom::SetUseDollyForPerspectiveProjection ( bool  )
change view angle, instead.
◆ GetUseDollyForPerspectiveProjection()
virtual bool vtkPVTrackballZoom::GetUseDollyForPerspectiveProjection ( )
◆ UseDollyForPerspectiveProjectionOn()
virtual void vtkPVTrackballZoom::UseDollyForPerspectiveProjectionOn ( )
◆ UseDollyForPerspectiveProjectionOff()
virtual void vtkPVTrackballZoom::UseDollyForPerspectiveProjectionOff ( )
◆ operator=()
void vtkPVTrackballZoom::operator= ( const vtkPVTrackballZoom )
protecteddelete
bool vtkPVTrackballZoom::UseDollyForPerspectiveProjection
Definition at line 53 of file vtkPVTrackballZoom.h.
◆ ZoomScale
double vtkPVTrackballZoom::ZoomScale
Definition at line 54 of file vtkPVTrackballZoom.h.
