vtkPVTrackballRotate Class Reference
Rotates camera with xy mouse movement. More...
#include <vtkPVTrackballRotate.h>
Inheritance diagram for vtkPVTrackballRotate:
Collaboration diagram for vtkPVTrackballRotate:
typedef vtkPVCameraManipulator Superclass
- Public Types inherited from vtkPVCameraManipulator
virtual char GetKeyCode ()
 Returns the currently pressed key code. More...
void OnButtonDown (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *rwi) override
void OnButtonUp (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *rwi) override
void OnKeyUp (vtkRenderWindowInteractor *iren) override
void OnKeyDown (vtkRenderWindowInteractor *iren) override
- Public Member Functions inherited from vtkPVCameraManipulator
virtual void SetButton (int)
virtual int GetButton ()
virtual void SetShift (int)
virtual int GetShift ()
virtual void ShiftOn ()
virtual void ShiftOff ()
virtual void SetControl (int)
virtual int GetControl ()
virtual void ControlOn ()
virtual void ControlOff ()
virtual void SetCenter (double [3])
virtual doubleGetCenter ()
virtual void GetCenter (double [3])
virtual vtkCameraManipulatorGUIHelperGetGUIHelper ()
static vtkPVTrackballRotateNew ()
static vtkPVTrackballRotateSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPVCameraManipulator
static vtkPVCameraManipulatorNew ()
static vtkPVCameraManipulatorSafeDownCast (vtkObject *o)
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkPVTrackballRotate ()
 ~vtkPVTrackballRotate () override
 vtkPVTrackballRotate (const vtkPVTrackballRotate &)=delete
void operator= (const vtkPVTrackballRotate &)=delete
- Protected Member Functions inherited from vtkPVCameraManipulator
 vtkPVCameraManipulator ()
 ~vtkPVCameraManipulator () override
char KeyCode
- Protected Attributes inherited from vtkPVCameraManipulator
char * ManipulatorName
int Button
int Shift
int Control
double Center [3]
double RotationFactor
double DisplayCenter [2]
vtkCameraManipulatorGUIHelperGUIHelper
vtkPVTrackballRotate allows the user to interactively manipulate the camera, the viewpoint of the scene.
Definition at line 17 of file vtkPVTrackballRotate.h.
Definition at line 21 of file vtkPVTrackballRotate.h.
◆ vtkPVTrackballRotate() [1/2]
vtkPVTrackballRotate::vtkPVTrackballRotate ( )
◆ ~vtkPVTrackballRotate()
vtkPVTrackballRotate::~vtkPVTrackballRotate ( )
◆ vtkPVTrackballRotate() [2/2]
vtkPVTrackballRotate::vtkPVTrackballRotate ( const vtkPVTrackballRotate )
protecteddelete
static vtkPVTrackballRotate* vtkPVTrackballRotate::New ( )
virtual const char* vtkPVTrackballRotate::GetClassName ( )
Reimplemented from vtkPVCameraManipulator.
static int vtkPVTrackballRotate::IsTypeOf ( const char *  type)
virtual int vtkPVTrackballRotate::IsA ( const char *  type)
static vtkPVTrackballRotate* vtkPVTrackballRotate::SafeDownCast ( vtkObject o)
void vtkPVTrackballRotate::PrintSelf ( ostream &  os,
◆ OnMouseMove()
void vtkPVTrackballRotate::OnMouseMove ( int  x,
int  y,
vtkRenderer ren,
vtkRenderWindowInteractor rwi
◆ OnButtonDown()
void vtkPVTrackballRotate::OnButtonDown ( int  x,
int  y,
vtkRenderer ren,
◆ OnButtonUp()
void vtkPVTrackballRotate::OnButtonUp ( int  x,
int  y,
vtkRenderer ren,
◆ OnKeyUp()
void vtkPVTrackballRotate::OnKeyUp ( vtkRenderWindowInteractor iren)
These methods are called on all registered manipulators, not just the active one.
Hence, these should just be used to record state and not perform any interactions. Overridden to capture if the x,y,z key is pressed.
◆ OnKeyDown()
void vtkPVTrackballRotate::OnKeyDown ( vtkRenderWindowInteractor iren)
◆ GetKeyCode()
virtual char vtkPVTrackballRotate::GetKeyCode ( )
◆ operator=()
void vtkPVTrackballRotate::operator= ( const vtkPVTrackballRotate )
protecteddelete
◆ KeyCode
char vtkPVTrackballRotate::KeyCode
Definition at line 54 of file vtkPVTrackballRotate.h.
