1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
46 file(INSTALL DESTINATION
"vtkPVVTKExtensionsInteractionStyle-hierarchy.txt" FILES
"/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkPVVTKExtensionsInteractionStyle-hierarchy.txt")
51 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsInteractionStyle-pv6.1.so.6.1
" 52 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsInteractionStyle-pv6.1.so.1
" 54 if(EXISTS "${file}
") 58 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
" TYPE SHARED_LIBRARY FILES 62 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsInteractionStyle-pv6.1.so.6.1
" 63 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsInteractionStyle-pv6.1.so.1
" 66 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsInteractionStyle-pv6.1.so.6.1
" 67 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsInteractionStyle-pv6.1.so.1
" 69 if(EXISTS "${file}
") 73 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 74 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
" "${file}
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsInteractionStyle-pv6.1.so
" OR NOT CMAKE_INSTALL_COMPONENT) 90 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.1
" TYPE FILE FILES 94 "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/
vtkPVJoystickFly.h
" 99 "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/
vtkPVTrackballPan.h
" 101 "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/
vtkPVTrackballRoll.h
" 104 "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/
vtkPVTrackballZoom.h
" 109 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 110 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.1
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/InteractionStyle/vtkPVVTKExtensionsInteractionStyleModule.h
") 113 if(CMAKE_INSTALL_COMPONENT STREQUAL "licenses
" OR NOT CMAKE_INSTALL_COMPONENT) 114 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkPVVTKExtensionsInteractionStyle
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/InteractionStyle/LICENSE
") 117 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx
" OR NOT CMAKE_INSTALL_COMPONENT) 118 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/InteractionStyle/vtkPVVTKExtensionsInteractionStyle.spdx
") Helper class for Camera Manipulators.
Pans camera with x y mouse movements.
Rotates camera with xy mouse movement.
This camera manipulator combines the vtkPVTrackballRotate and vtkPVTrackballRoll manipulators in one...
Fly camera towards or away from the object.
Rolls camera around a point.
Abstraction of style away from button.
Zooms camera with vertical mouse movement.
Rotates the environment with xy mouse movement.
Zooms camera with vertical mouse movement to mouse position.
interactive manipulation of the camera
