23 #ifndef vtkSMContextViewProxy_h 24 #define vtkSMContextViewProxy_h 27 #include "vtkRemotingViewsModule.h" 77 virtual void ResetDisplay();
105 void OnInteractionEvent();
112 void OnForwardInteractionEvent(
vtkObject*,
unsigned long,
void*);
118 void OnLeftButtonReleaseEvent();
136 vtkTypeUInt32
PreRender(
bool interactive)
override;
168 void CopyAxisRangesFromChart();
virtual const char * GetRepresentationType(vtkSMSourceProxy *producer, int outputPort)
Returns the xml name of the representation proxy to create to show the data produced in this view...
void CreateVTKObjects() override
Called at the end of CreateVTKObjects().
virtual void PostRender(bool vtkNotUsed(interactive))
Superclass for all view proxies.
static vtkSMViewProxy * New()
virtual vtkRenderWindow * GetRenderWindow()
Return the vtkRenderWindow used by this view, if any.
bool XYChartViewBase4Axes
Flag automatically set when Bottom and Right custom axes related property are present in this proxy...
vtkContextView * ChartView
The context view that is used for all context derived charts.
virtual vtkRenderWindowInteractor * GetInteractor()
Returns the interactor.
virtual vtkTypeUInt32 PreRender(bool vtkNotUsed(interactive))
This method is called before executing code that could cause a render on the underlying vtkPVView...
int ReadXMLAttributes(vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) override
Read attributes from an XML element.
proxy for a VTK source on a server
abstract base class for all Chart Views.
The vtkSMSessionProxyManager is esponsible for creating and managing proxies for a given session...
virtual bool CanDisplayData(vtkSMSourceProxy *producer, int outputPort)
Returns true if the view can display the data produced by the producer's port.
virtual void SetupInteractor(vtkRenderWindowInteractor *iren)
A client process need to set the interactor to enable interactivity.
helper class that make it easier to hook vtkRenderWindowInteractor and vtkSMViewProxy.
bool SkipPlotableCheck
To avoid showing large datasets in context views, that typically rely on delivering all data to the c...
