vtkSMChartSeriesListDomain.h
3  Program: ParaView
4  Module: $RCSfile$
5
6  Copyright (c) Kitware, Inc.
7  All rights reserved.
8  See Copyright.txt or http://www.paraview.org/HTML/Copyright.html for details.
9
10  This software is distributed WITHOUT ANY WARRANTY; without even
11  the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR
12  PURPOSE. See the above copyright notice for more information.
13
14 =========================================================================*/
37 #ifndef vtkSMChartSeriesListDomain_h
38 #define vtkSMChartSeriesListDomain_h
40 #include "vtkRemotingViewsModule.h" // needed for exports
41 #include "vtkSMStringListDomain.h"
42
45
46 class VTKREMOTINGVIEWS_EXPORT vtkSMChartSeriesListDomain : public vtkSMStringListDomain
47 {
48 public:
51  void PrintSelf(ostream& os, vtkIndent indent) override;
52
57  void Update(vtkSMProperty*) override;
58
62  int SetDefaultValues(vtkSMProperty*, bool use_unchecked_values) override;
63
69  static const char** GetKnownSeriesNames();
70
71 protected:
73  ~vtkSMChartSeriesListDomain() override;
74
78  vtkPVDataInformation* GetInputInformation();
79
80  int ReadXMLAttributes(vtkSMProperty* prop, vtkPVXMLElement* element) override;
81
82  virtual void PopulateArrayComponents(vtkPVArrayInformation*, std::vector<std::string>&);
83
85
86 private:
88  void operator=(const vtkSMChartSeriesListDomain&) = delete;
89 };
90
91 #endif
Light object for holding data information.
list of strings corresponding to the names of the arrays in the required input dataset that can be us...
int ReadXMLAttributes(vtkSMProperty *prop, vtkPVXMLElement *element) override
void Update(vtkSMProperty *) override
Update self checking the "unchecked" values of all required properties.
Data array information like type.
static vtkSMStringListDomain * New()
int SetDefaultValues(vtkSMProperty *, bool use_unchecked_values) override
