vtkPEnSightGoldReader.h
3  Program: Visualization Toolkit
4  Module: vtkPEnSightGoldReader.h
5
6  Copyright (c) Ken Martin, Will Schroeder, Bill Lorensen
7  All rights reserved.
8  See Copyright.txt or http://www.kitware.com/Copyright.htm for details.
9
10  This software is distributed WITHOUT ANY WARRANTY; without even
11  the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR
12  PURPOSE. See the above copyright notice for more information.
13
14  =========================================================================*/
35 #ifndef vtkPEnSightGoldReader_h
36 #define vtkPEnSightGoldReader_h
37
38 #include "vtkPEnSightReader.h"
39 #include "vtkPVVTKExtensionsIOEnSightModule.h" //needed for exports
40
41 class UndefPartialInternal;
42
44 class vtkPoints;
45
46 class VTKPVVTKEXTENSIONSIOENSIGHT_EXPORT vtkPEnSightGoldReader : public vtkPEnSightReader
47 {
48 public:
49  static vtkPEnSightGoldReader* New();
51  void PrintSelf(ostream& os, vtkIndent indent) override;
52
53 protected:
55  ~vtkPEnSightGoldReader() override;
56
60  int ReadGeometryFile(const char* fileName, int timeStep, vtkMultiBlockDataSet* output) override;
61
67  const char* fileName, int timeStep, vtkMultiBlockDataSet* output) override;
68
74  int ReadScalarsPerNode(const char* fileName, const char* description, int timeStep,
75  vtkMultiBlockDataSet* output, int measured = 0, int numberOfComponents = 1,
76  int component = 0) override;
77
82  int ReadVectorsPerNode(const char* fileName, const char* description, int timeStep,
83  vtkMultiBlockDataSet* output, int measured = 0) override;
84
89  int ReadTensorsPerNode(const char* fileName, const char* description, int timeStep,
90  vtkMultiBlockDataSet* output) override;
91
97  int ReadScalarsPerElement(const char* fileName, const char* description, int timeStep,
98  vtkMultiBlockDataSet* output, int numberOfComponents = 1, int component = 0) override;
99
104  int ReadVectorsPerElement(const char* fileName, const char* description, int timeStep,
105  vtkMultiBlockDataSet* output) override;
106
111  int ReadTensorsPerElement(const char* fileName, const char* description, int timeStep,
112  vtkMultiBlockDataSet* output) override;
113
120  int partId, char line[256], const char* name, vtkMultiBlockDataSet* output) override;
121
127  int partId, char line[256], const char* name, vtkMultiBlockDataSet* output) override;
128
133  int CreateRectilinearGridOutput(
134  int partId, char line[256], const char* name, vtkMultiBlockDataSet* output);
135
140  int CreateImageDataOutput(
141  int partId, char line[256], const char* name, vtkMultiBlockDataSet* output);
142
146  int ReadOrSkipCoordinates(
147  vtkPoints* points, long offset, int partId, int* lineRead, char* line, bool skip);
148
153  int InjectCoordinatesAtEnd(vtkUnstructuredGrid* output, long coordinatesOffset, int partId);
154
159  int CheckForUndefOrPartial(const char* line);
160
164  UndefPartialInternal* UndefPartial;
165
168
169 private:
171  void operator=(const vtkPEnSightGoldReader&) = delete;
172 };
173
174 #endif
virtual int ReadScalarsPerElement(const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output, int numberOfComponents=1, int component=0)=0
Read scalars per element for this dataset.
virtual int CreateStructuredGridOutput(int partId, char line[80], const char *name, vtkMultiBlockDataSet *output)=0
Read a structured part from the geometry file and create a vtkStructuredGridOutput.
Superclass for EnSight file parallel readers.
Parallel version of vtkEnSightGoldReader.
virtual int ReadScalarsPerNode(const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output, int measured=0, int numberOfComponents=1, int component=0)=0
Read scalars per node for this dataset.
UndefPartialInternal * UndefPartial
Handle the undef / partial support for EnSight gold.
virtual int ReadMeasuredGeometryFile(const char *fileName, int timeStep, vtkMultiBlockDataSet *output)=0
Read the measured geometry file.
virtual int ReadVectorsPerElement(const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output)=0
Read vectors per element for this dataset.
static vtkPGenericEnSightReader * New()
virtual int ReadTensorsPerNode(const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output)=0
Read tensors per node for this dataset.
virtual int CreateUnstructuredGridOutput(int partId, char line[80], const char *name, vtkMultiBlockDataSet *output)=0
Read an unstructured part (partId) from the geometry file and create a vtkUnstructuredGrid output...
virtual int ReadVectorsPerNode(const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output, int measured=0)=0
Read vectors per node for this dataset.
virtual int ReadGeometryFile(const char *fileName, int timeStep, vtkMultiBlockDataSet *output)=0
Read the geometry file.
virtual int ReadTensorsPerElement(const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output)=0
Read tensors per element for this dataset.
