| virtual char * | GetMeasuredFileName () |
| | Get the Measured file name. More...
| virtual char * | GetMatchFileName () |
| | Get the Match file name. More...
| vtkGenericEnSightReader * | NewInstance () const |
| const char * | GetDescription (int n) |
| const char * | GetComplexDescription (int n) |
| const char * | GetDescription (int n, int type) |
| int | DetermineEnSightVersion (int quiet=0) |
| vtkGenericEnSightReader * | GetReader () |
| void | SetCaseFileName (const char *fileName) |
| virtual char * | GetCaseFileName () |
| virtual void | SetFilePath (const char *) |
| virtual char * | GetFilePath () |
| virtual int | GetEnSightVersion () |
| virtual int | GetNumberOfVariables () |
| virtual int | GetNumberOfComplexVariables () |
| int | GetNumberOfVariables (int type) |
| virtual int | GetNumberOfScalarsPerNode () |
| virtual int | GetNumberOfVectorsPerNode () |
| virtual int | GetNumberOfTensorsSymmPerNode () |
| virtual int | GetNumberOfScalarsPerElement () |
| virtual int | GetNumberOfVectorsPerElement () |
| virtual int | GetNumberOfTensorsSymmPerElement () |
| virtual int | GetNumberOfScalarsPerMeasuredNode () |
| virtual int | GetNumberOfVectorsPerMeasuredNode () |
| virtual int | GetNumberOfComplexScalarsPerNode () |
| virtual int | GetNumberOfComplexVectorsPerNode () |
| virtual int | GetNumberOfComplexScalarsPerElement () |
| virtual int | GetNumberOfComplexVectorsPerElement () |
| int | GetVariableType (int n) |
| int | GetComplexVariableType (int n) |
| virtual void | SetTimeValue (float value) |
| virtual float | GetTimeValue () |
| virtual float | GetMinimumTimeValue () |
| virtual float | GetMaximumTimeValue () |
| virtual vtkDataArrayCollection * | GetTimeSets () |
| virtual void | ReadAllVariablesOn () |
| virtual void | ReadAllVariablesOff () |
| virtual void | SetReadAllVariables (int) |
| virtual int | GetReadAllVariables () |
| virtual vtkDataArraySelection * | GetPointDataArraySelection () |
| virtual vtkDataArraySelection * | GetCellDataArraySelection () |
| int | GetNumberOfPointArrays () |
| int | GetNumberOfCellArrays () |
| const char * | GetPointArrayName (int index) |
| const char * | GetCellArrayName (int index) |
| int | GetPointArrayStatus (const char *name) |
| int | GetCellArrayStatus (const char *name) |
| void | SetPointArrayStatus (const char *name, int status) |
| void | SetCellArrayStatus (const char *name, int status) |
| void | SetByteOrderToBigEndian () |
| void | SetByteOrderToLittleEndian () |
| virtual void | SetByteOrder (int) |
| virtual int | GetByteOrder () |
| const char * | GetByteOrderAsString () |
| virtual char * | GetGeometryFileName () |
| virtual void | SetParticleCoordinatesByIndex (int) |
| virtual int | GetParticleCoordinatesByIndex () |
| virtual void | ParticleCoordinatesByIndexOn () |
| virtual void | ParticleCoordinatesByIndexOff () |
| vtkMultiBlockDataSetAlgorithm * | NewInstance () const |
| vtkMultiBlockDataSet * | GetOutput () |
| vtkMultiBlockDataSet * | GetOutput (int) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPEnSightReader () |
| | ~vtkPEnSightReader () override |
| int | RequestInformation (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| virtual int | ReadGeometryFile (const char *fileName, int timeStep, vtkMultiBlockDataSet *output)=0 |
| | Read the geometry file. More...
| virtual int | ReadMeasuredGeometryFile (const char *fileName, int timeStep, vtkMultiBlockDataSet *output)=0 |
| | Read the measured geometry file. More...
| int | ReadVariableFiles (vtkMultiBlockDataSet *output) |
| | Read the variable files. More...
| virtual int | ReadScalarsPerNode (const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output, int measured=0, int numberOfComponents=1, int component=0)=0 |
| | Read scalars per node for this dataset. More...
| virtual int | ReadVectorsPerNode (const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output, int measured=0)=0 |
| | Read vectors per node for this dataset. More...
| virtual int | ReadTensorsPerNode (const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output)=0 |
| | Read tensors per node for this dataset. More...
| virtual int | ReadScalarsPerElement (const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output, int numberOfComponents=1, int component=0)=0 |
| | Read scalars per element for this dataset. More...
| virtual int | ReadVectorsPerElement (const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output)=0 |
| | Read vectors per element for this dataset. More...
| virtual int | ReadTensorsPerElement (const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output)=0 |
| | Read tensors per element for this dataset. More...
| virtual int | CreateUnstructuredGridOutput (int partId, char line[80], const char *name, vtkMultiBlockDataSet *output)=0 |
| | Read an unstructured part (partId) from the geometry file and create a vtkUnstructuredGrid output. More...
| virtual int | CreateStructuredGridOutput (int partId, char line[80], const char *name, vtkMultiBlockDataSet *output)=0 |
| | Read a structured part from the geometry file and create a vtkStructuredGridOutput. More...
| void | AddVariableFileName (const char *fileName1, const char *fileName2=NULL) |
| | Add another file name to the list for a particular variable type. More...
| void | AddVariableDescription (const char *description) |
| | Add another description to the list for a particular variable type. More...
| void | AddVariableType () |
| | Record the variable type for the variable line just read. More...
| int | GetElementType (const char *line) |
| | Determine the element type from a line read a file. More...
| int | GetSectionType (const char *line) |
| | Determine the section type from a line read a file. More...
| void | ReplaceWildcards (char *filename, int num) |
| | Replace the *'s in the filename with the given filename number. More...
| void | RemoveLeadingBlanks (char *line) |
| | Remove leading blank spaces from a string. More...
| vtkPEnSightReaderCellIds * | GetCellIds (int index, int cellType) |
| | Get the list for the given output index and cell type. More...
| vtkPEnSightReaderCellIds * | GetPointIds (int index) |
| | Distributed Read Only. More...
| void | AddToBlock (vtkMultiBlockDataSet *output, unsigned int blockNo, vtkDataSet *dataset) |
| | Convenience method use to convert the readers from VTK 5 multiblock API to the current composite data infrastructure. More...
| vtkDataSet * | GetDataSetFromBlock (vtkMultiBlockDataSet *output, unsigned int blockNo) |
| void | SetBlockName (vtkMultiBlockDataSet *output, unsigned int blockNo, const char *name) |
| | Set the name of a block. More...
| void | MapToGlobalIds (const vtkIdType *inputIds, vtkIdType numPoints, int partId, vtkIdType *globalIds) |
| | Convenience method to map the point ids from current rank to global ids. More...
| void | PrepareStructuredDimensionsForDistribution (int partId, int *oldDimensions, int *newDimensions, int *splitDimension, int *splitDimensionBeginIndex, int ghostLevel, vtkUnsignedCharArray *pointGhostArray, vtkUnsignedCharArray *cellGhostArray) |
| virtual void | SetUseTimeSets (int) |
| virtual int | GetUseTimeSets () |
| virtual void | UseTimeSetsOn () |
| virtual void | UseTimeSetsOff () |
| virtual void | SetUseFileSets (int) |
| virtual int | GetUseFileSets () |
| virtual void | UseFileSetsOn () |
| virtual void | UseFileSetsOff () |
| int | CheckOutputConsistency () |
| virtual void | SetMeasuredFileName (const char *) |
| | Set the Measured file name. More...
| virtual void | SetMatchFileName (const char *) |
| | Set the Match file name. More...
| int | ReadCaseFile () |
| | Read the case file. More...
| int | ReadCaseFileGeometry (char *line) |
| int | ReadCaseFileVariable (char *line) |
| int | ReadCaseFileTime (char *line) |
| int | ReadCaseFileFile (char *line) |
| vtkIdType | GetTotalNumberOfCellIds (int index) |
| vtkIdType | GetLocalTotalNumberOfCellIds (int index) |
| void | InsertNextCellAndId (vtkUnstructuredGrid *, int vtkCellType, vtkIdType numPoints, vtkIdType *points, int partId, int ensightCellType, vtkIdType globalId, vtkIdType numElements, const std::vector< vtkIdType > &faces={}) |
| | Merge InsertNextCell & GetId->InsertNextId Take Distributed Read into account. More...
| void | InsertVariableComponent (vtkFloatArray *array, int i, int component, float *content, int partId, int ensightCellType, int insertionType) |
| | vtkPGenericEnSightReader () |
| | ~vtkPGenericEnSightReader () override |
| int | GetMultiProcessLocalProcessId () |
| | Multi Process cache. More...
| int | GetMultiProcessNumberOfProcesses () |
| | vtkGenericEnSightReader () |
| | ~vtkGenericEnSightReader () |
| virtual void | ClearForNewCaseFileName () |
| int | ReadLine (char result[256]) |
| int | ReadBinaryLine (char result[80]) |
| int | ReadNextDataLine (char result[256]) |
| void | SelectionModified () |
| char ** | CreateStringArray (int numStrings) |
| void | DestroyStringArray (int numStrings, char **strings) |
| void | SetDataArraySelectionSetsFromVariables () |
| void | SetDataArraySelectionSetsFromReader () |
| void | SetReaderDataArraySelectionSetsFromSelf () |
| virtual void | SetTimeSets (vtkDataArrayCollection *) |
| int | InsertNewPartId (int partId) |
| virtual void | SetGeometryFileName (const char *) |
| void | AddComplexVariableDescription (const char *description) |
| void | AddVariableType (int variableType) |
| void | AddComplexVariableType (int variableType) |
| int | ReplaceWildcards (char *fileName, int timeSet, int fileSet) |
| void | ReplaceWildcardsHelper (char *fileName, int num) |
| | vtkMultiBlockDataSetAlgorithm () |
| | ~vtkMultiBlockDataSetAlgorithm () |
| virtual int | FillInputPortInformation (int port, vtkInformation *info) |
| virtual int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
Superclass for EnSight file parallel readers.
* This file has been developed as part of the CARRIOCAS (Distributed
* computation over ultra high optical internet network ) project (
* http://www.carriocas.org/index.php?lng=ang ) of the SYSTEM@TIC French ICT
* Cluster (http://www.systematic-paris-region.org/en/index.html) under the
* supervision of CEA (http://www.cea.fr) and EDF (http://www.edf.fr) by
* Oxalya (http://www.oxalya.com)
* Copyright (c) CEA
Definition at line 58 of file vtkPEnSightReader.h.
