32 #ifndef vtkPEnSightReader_h 33 #define vtkPEnSightReader_h 36 #include "vtkPVVTKExtensionsIOEnSightModule.h" 54 class vtkPEnSightReaderCellIdsType;
56 #define NEXTMODULO3(x) (x == 0) ? 1 : ((x == 1) ? 2 : 0) 79 , cellLocalNumberOfIds(-1)
81 , ImplicitDimensions(NULL)
82 , ImplicitLocalDimensions(NULL)
83 , ImplicitSplitDimension(-1)
84 , ImplicitSplitDimensionBeginIndex(-1)
85 , ImplicitSplitDimensionEndIndex(-1)
93 , cellLocalNumberOfIds(-1)
95 , ImplicitDimensions(NULL)
96 , ImplicitLocalDimensions(NULL)
97 , ImplicitSplitDimension(-1)
98 , ImplicitSplitDimensionBeginIndex(-1)
99 , ImplicitSplitDimensionEndIndex(-1)
104 this->cellMap =
new IntIntMap;
105 this->cellNumberOfIds = 0;
106 this->cellVector = NULL;
110 this->ImplicitDimensions =
new int[3];
111 this->ImplicitSplitDimension = -1;
112 this->ImplicitSplitDimensionBeginIndex = -1;
113 this->ImplicitSplitDimensionEndIndex = -1;
117 this->cellMap = NULL;
118 this->cellVector =
new IntVector;
119 this->cellNumberOfIds = -1;
120 this->cellLocalNumberOfIds = -1;
126 delete this->cellMap;
127 delete this->cellVector;
128 delete[] this->ImplicitDimensions;
136 this->cellMap =
new IntIntMap;
137 this->cellNumberOfIds = 0;
138 this->cellVector = NULL;
142 this->ImplicitDimensions =
new int[3];
143 this->ImplicitSplitDimension = -1;
144 this->ImplicitSplitDimensionBeginIndex = -1;
145 this->ImplicitSplitDimensionEndIndex = -1;
149 this->cellMap = NULL;
150 this->cellVector =
new IntVector;
151 this->cellNumberOfIds = -1;
152 this->cellLocalNumberOfIds = -1;
158 this->ImplicitDimensions[0] = dim1;
159 this->ImplicitDimensions[1] = dim2;
160 this->ImplicitDimensions[2] = dim3;
167 this->ImplicitSplitDimensionBeginIndex = begin;
185 if (this->ImplicitSplitDimension == -1)
191 index[2] =
id / (this->ImplicitDimensions[0] * this->ImplicitDimensions[1]);
192 index[1] = (
id - (index[2] * this->ImplicitDimensions[0] * this->ImplicitDimensions[1])) /
193 this->ImplicitDimensions[0];
194 index[0] =
id - index[1] * this->ImplicitDimensions[0] -
195 index[2] * this->ImplicitDimensions[1] * this->ImplicitDimensions[0];
196 if ((index[this->ImplicitSplitDimension] < this->ImplicitSplitDimensionBeginIndex) ||
197 (index[this->ImplicitSplitDimension] >= this->ImplicitSplitDimensionEndIndex))
207 int dim = this->ImplicitSplitDimension;
208 localIndex[dim] = index[dim] - this->ImplicitSplitDimensionBeginIndex;
210 this->ImplicitSplitDimensionEndIndex - this->ImplicitSplitDimensionBeginIndex;
212 localIndex[dim] = index[dim];
213 localDim[dim] = this->ImplicitDimensions[dim];
215 localDim[dim] = this->ImplicitDimensions[dim];
216 localIndex[dim] = index[dim];
217 return localIndex[0] + localDim[0] * localIndex[1] +
218 localDim[0] * localDim[1] * localIndex[2];
223 std::map<int, int>::iterator it = this->cellMap->find(
id);
224 if (it == this->cellMap->end())
227 return (*this->cellMap)[id];
232 if (this->cellVector->size() > (
unsigned int)(
id))
233 return (*this->cellVector)[id];
253 std::map<int, int>::iterator it = this->cellMap->find(
id);
254 if (it == this->cellMap->end())
255 this->cellNumberOfIds++;
257 (*this->cellMap)[
id] = value;
262 if (this->cellVector->size() < (
unsigned int)(
id + 1))
265 int currentSize =
static_cast<int>(this->cellVector->size());
266 this->cellVector->resize(
id + 1);
267 for (k = currentSize; k < id; k++)
269 (*this->cellVector)[k] = -1;
271 (*this->cellVector)[
id] = value;
275 (*this->cellVector)[
id] = value;
298 (*this->cellMap)[this->cellNumberOfIds] =
id;
301 this->cellNumberOfIds++;
302 return this->cellNumberOfIds - 1;
307 this->cellVector->push_back(
id);
308 return static_cast<int>(this->cellVector->size() - 1);
312 return static_cast<int>(this->cellVector->size() - 1);
322 return this->cellNumberOfIds;
327 return this->cellNumberOfIds;
331 return this->cellNumberOfIds;
345 if (this->cellNumberOfIds >= 0)
347 return this->cellNumberOfIds;
350 return static_cast<int>(this->cellVector->size());
363 this->cellNumberOfIds = n;
377 this->cellLocalNumberOfIds = n;
385 this->cellMap->clear();
386 this->cellNumberOfIds = 0;
391 this->cellVector->clear();
392 if (this->cellNumberOfIds >= 0)
393 this->cellNumberOfIds = -1;
394 if (this->cellLocalNumberOfIds >= 0)
395 this->cellLocalNumberOfIds = -1;
406 return this->cellNumberOfIds;
411 return this->cellLocalNumberOfIds;
415 return static_cast<int>(this->cellMap->size());
425 if (this->cellLocalNumberOfIds >= 0)
427 return this->cellLocalNumberOfIds;
432 for (
unsigned int i = 0; i < this->cellVector->size(); i++)
434 if ((*this->cellVector)[i] != -1)
451 int dim = this->ImplicitSplitDimension;
453 this->ImplicitSplitDimensionEndIndex - this->ImplicitSplitDimensionBeginIndex;
455 localDim[dim] = this->ImplicitDimensions[dim];
457 localDim[dim] = this->ImplicitDimensions[dim];
461 for (
int k = 0; k < this->ImplicitDimensions[2]; k++)
463 for (
int j = 0; j < this->ImplicitDimensions[1]; j++)
465 for (
int i = 0; i < this->ImplicitDimensions[0]; i++)
467 int n = (this->ImplicitSplitDimension == 0)
469 : ((this->ImplicitSplitDimension == 1) ? j : k);
470 if ((n >= this->ImplicitSplitDimensionBeginIndex) &&
471 (n < this->ImplicitSplitDimensionEndIndex))
474 array->SetTypedTuple(index, &nn);
489 int min = 1000000000;
491 for (i = 0; i < this->GetNumberOfIds(); i++)
493 int id = this->GetId(i);
501 array->SetTypedTuple(
id, &ii);
546 NUMBER_OF_ELEMENT_TYPES = 17
553 TENSOR_SYMM_PER_NODE = 2,
554 SCALAR_PER_ELEMENT = 3,
555 VECTOR_PER_ELEMENT = 4,
556 TENSOR_SYMM_PER_ELEMENT = 5,
557 SCALAR_PER_MEASURED_NODE = 6,
558 VECTOR_PER_MEASURED_NODE = 7,
559 COMPLEX_SCALAR_PER_NODE = 8,
560 COMPLEX_VECTOR_PER_NODE = 9,
561 COMPLEX_SCALAR_PER_ELEMENT = 10,
562 COMPLEX_VECTOR_PER_ELEMENT = 11
577 vtkGetStringMacro(MeasuredFileName);
585 vtkGetStringMacro(MatchFileName);
605 vtkSetStringMacro(MeasuredFileName);
612 vtkSetStringMacro(MatchFileName);
620 int ReadCaseFileGeometry(
char* line);
621 int ReadCaseFileVariable(
char* line);
622 int ReadCaseFileTime(
char* line);
623 int ReadCaseFileFile(
char* line);
632 virtual int ReadGeometryFile(
639 virtual int ReadMeasuredGeometryFile(
651 virtual int ReadScalarsPerNode(
const char* fileName,
const char* description,
int timeStep,
653 int component = 0) = 0;
659 virtual int ReadVectorsPerNode(
int timeStep,
666 virtual int ReadTensorsPerNode(
673 virtual int ReadScalarsPerElement(
int timeStep,
680 virtual int ReadVectorsPerElement(
687 virtual int ReadTensorsPerElement(
694 virtual int CreateUnstructuredGridOutput(
701 virtual int CreateStructuredGridOutput(
707 void AddVariableFileName(
const char* fileName1,
const char* fileName2 = NULL);
712 void AddVariableDescription(
const char* description);
717 void AddVariableType();
723 int GetElementType(
const char* line);
729 int GetSectionType(
const char* line);
734 void ReplaceWildcards(
char* filename,
int num);
739 void RemoveLeadingBlanks(
char* line);
751 vtkIdType GetTotalNumberOfCellIds(
int index);
752 vtkIdType GetLocalTotalNumberOfCellIds(
int index);
786 const std::vector<vtkIdType>& faces = {});
787 void InsertVariableComponent(
vtkFloatArray* array,
int i,
int component,
float* content,
788 int partId,
int ensightCellType,
int insertionType);
803 void PrepareStructuredDimensionsForDistribution(
int partId,
int* oldDimensions,
804 int* newDimensions,
int* splitDimension,
int* splitDimensionBeginIndex,
int ghostLevel,
864 vtkSetMacro(UseTimeSets,
int);
865 vtkGetMacro(UseTimeSets,
int);
866 vtkBooleanMacro(UseTimeSets,
int);
869 vtkSetMacro(UseFileSets,
int);
870 vtkGetMacro(UseFileSets,
int);
871 vtkBooleanMacro(UseFileSets,
int);
881 int CheckOutputConsistency();
void SetMode(EnsightReaderCellIdMode amode)
std::vector< int > IntVector
vtkPEnSightReaderCellIds(EnsightReaderCellIdMode amode)
void SetImplicitSplitDimensionEndIndex(int end)
vtkIdList * VariableTimeSetIds
EnsightReaderCellIdMode mode
Superclass for EnSight file parallel readers.
vtkIdList * TimeSetsWithFilenameNumbers
vtkIdList * ComplexVariableFileSetIds
int NumberOfGeometryParts
std::map< int, int > IntIntMap
int ImplicitSplitDimensionBeginIndex
void SetImplicitSplitDimensionBeginIndex(int begin)
char ** ComplexVariableFileNames
vtkIdList * UnstructuredPartIds
class to read any type of EnSight files
vtkPEnSightReaderCellIdsType * CellIds
virtual void SetName(const char *)
void SetImplicitSplitDimension(int dim)
vtkIdTypeArray * GenerateGlobalIdsArray(const char *name)
static vtkIdTypeArray * New()
void SetLocalNumberOfIds(int n)
vtkIdList * VariableFileSetIds
int GetLocalNumberOfIds()
int * ImplicitLocalDimensions
bool InjectGlobalElementIds
virtual void SetNumberOfComponents(int)
vtkPEnSightReaderCellIds()
vtkIdListCollection * FileSetFileNameNumbers
int ImplicitSplitDimensionEndIndex
void SetImplicitDimensions(int dim1, int dim2, int dim3)
~vtkPEnSightReaderCellIds()
char ** VariableFileNames
void SetId(int id, int value)
vtkIdListCollection * TimeSetFileNameNumbers
vtkIdList * ComplexVariableTimeSetIds
virtual void SetNumberOfTuples(vtkIdType numTuples)=0
void SetNumberOfIds(int n)
vtkIdListCollection * FileSetNumberOfSteps
vtkIdList * StructuredPartIds
std::map< std::string, std::map< int, long > > FileOffsets
int NumberOfMeasuredPoints
vtkPEnSightReaderCellIdsType * PointIds
vtkIdList * FileSetsWithFilenameNumbers
