pqTabbedMultiViewWidget.h
3  Program: ParaView
4  Module: $RCSfile$
5
6  Copyright (c) 2005,2006 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 ========================================================================*/
32 #ifndef pqTabbedMultiViewWidget_h
33 #define pqTabbedMultiViewWidget_h
35 #include "pqComponentsModule.h"
36 #include "vtkType.h" // needed for vtkIdType
37 #include <QStyle> // needed for QStyle:StandardPixmap
38 #include <QTabBar> // needed for QTabBar::ButtonPosition
39 #include <QTabWidget> // needed for QTabWidget.
40
41 class pqMultiViewWidget;
42 class pqProxy;
43 class pqServer;
45 class pqView;
46 class vtkImageData;
48
55 class PQCOMPONENTS_EXPORT pqTabbedMultiViewWidget : public QWidget
56 {
57  Q_OBJECT
58  typedef QWidget Superclass;
59  Q_PROPERTY(bool readOnly READ readOnly WRITE setReadOnly)
60 public:
61  pqTabbedMultiViewWidget(QWidget* parent = 0);
62  ~pqTabbedMultiViewWidget() override;
63
67  virtual QSize clientSize() const;
68
73  void setReadOnly(bool val);
74  bool readOnly() const;
75
80  void setTabVisibility(bool visible);
81  bool tabVisibility() const;
82
86  vtkSMViewLayoutProxy* layoutProxy() const;
87
91  bool decorationsVisibility() const;
92
97  pqMultiViewWidget* findTab(vtkSMViewLayoutProxy*) const;
98
99 Q_SIGNALS:
103  void viewSizeLocked(bool);
104
105 public Q_SLOTS:
106  virtual int createTab();
107  virtual int createTab(pqServer*);
108  virtual int createTab(vtkSMViewLayoutProxy*);
109  virtual void closeTab(int);
110
112
116  void setDecorationsVisibility(bool);
117  void showDecorations() { this->setDecorationsVisibility(true); }
118  void hideDecorations() { this->setDecorationsVisibility(false); }
120
124  virtual void toggleFullScreen();
125
129  virtual void toggleWidgetDecoration();
130
135  virtual void lockViewSize(const QSize&);
136
140  virtual void reset();
141
160  QSize preview(const QSize& previewSize = QSize());
161
162 protected Q_SLOTS:
166  virtual void proxyAdded(pqProxy*);
167  virtual void proxyRemoved(pqProxy*);
168  virtual void serverRemoved(pqServer*);
169
174  virtual void currentTabChanged(int);
175
180  virtual void onStateLoaded();
181
185  void contextMenuRequested(const QPoint&);
186
187  void onLayoutNameChanged(pqServerManagerModelItem*);
188
189 protected:
190  bool eventFilter(QObject* obj, QEvent* event) override;
191
195  class pqTabWidget : public QTabWidget
196  {
197  typedef QTabWidget Superclass;
198
199  public:
200  pqTabWidget(QWidget* parentWdg = NULL);
201  ~pqTabWidget() override;
202
206  virtual void setTabButton(int index, QTabBar::ButtonPosition position, QWidget* wdg);
207
213  virtual int tabButtonIndex(QWidget* wdg, QTabBar::ButtonPosition position) const;
214
220  virtual int addAsTab(pqMultiViewWidget* wdg, pqTabbedMultiViewWidget* self);
221
226  static const char* popoutLabelText(bool popped_out);
227
231  static QStyle::StandardPixmap popoutLabelPixmap(bool popped_out);
232
237  void setReadOnly(bool val);
238  bool readOnly() const { return this->ReadOnly; }
239
243  QSize preview(const QSize&);
244
246
251  void setTabBarVisibility(bool);
252  bool tabBarVisibility() const { return this->TabBarVisibility; }
254  private:
255  Q_DISABLE_COPY(pqTabWidget)
256  bool ReadOnly;
257  bool TabBarVisibility;
259  };
260
261 private:
262  Q_DISABLE_COPY(pqTabbedMultiViewWidget)
263
264  class pqInternals;
265  pqInternals* Internals;
266  friend class pqInternals;
267 };
268
269 #endif
pqMultiViewWidget is a widget that manages layout of multiple views.
When set to false, all decorations including title frames, separators, tab-bars are hidden...
pqServerManagerModelItem is a element maintained by pqServerManagerModel.
This is a PQ abstraction of a generic view module.
Definition: pqView.h:54
pqTabbedMultiViewWidget is used to to enable adding of multiple pqMultiViewWidget instances in tabs...
vtkSMViewLayoutProxy is used by ParaView to layout multiple views in a 2D KD-Tree layout...
This class represents any registered Server Manager proxy.
Definition: pqProxy.h:56
Get/Set tab bar visibility.
index
Internal class used as the TabWidget.
pqServer (should be renamed to pqSession) is a pqServerManagerModelItem subclass that represents a vt...
Definition: pqServer.h:64
position
