vtkSMViewLayoutProxy.h
3  Program: ParaView
4  Module: $RCSfile$
5
6  Copyright (c) Kitware, Inc.
7  All rights reserved.
8  See Copyright.txt or http://www.paraview.org/HTML/Copyright.html for details.
9
10  This software is distributed WITHOUT ANY WARRANTY; without even
11  the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR
12  PURPOSE. See the above copyright notice for more information.
13
14 =========================================================================*/
40 #ifndef vtkSMViewLayoutProxy_h
41 #define vtkSMViewLayoutProxy_h
42
43 #include "vtkRemotingViewsModule.h" //needed for exports
44 #include "vtkSMProxy.h"
45 #include "vtkVector.h" // needed for vtkVector2i
46 #include <vector> // needed for std::vector.
47
48 class vtkSMViewProxy;
49 class vtkImageData;
50
51 class VTKREMOTINGVIEWS_EXPORT vtkSMViewLayoutProxy : public vtkSMProxy
52 {
53 public:
54  static vtkSMViewLayoutProxy* New();
56  void PrintSelf(ostream& os, vtkIndent indent) override;
57
58  enum Direction
59  {
62  HORIZONTAL
63  };
64
74  int Split(int location, int direction, double fraction);
75  int SplitVertical(int location, double fraction)
76  {
77  return this->Split(location, VERTICAL, fraction);
78  }
79  int SplitHorizontal(int location, double fraction)
80  {
81  return this->Split(location, HORIZONTAL, fraction);
82  }
83
88  bool AssignView(int location, vtkSMViewProxy* view);
89
99  int AssignViewToAnyCell(vtkSMViewProxy* view, int location_hint);
100
102
106  int RemoveView(vtkSMViewProxy* view);
107  bool RemoveView(int index);
109
116  bool Collapse(int location);
117
122  bool SwapCells(int location1, int location2);
123
128  bool SetSplitFraction(int location, double fraction);
129
136  bool MaximizeCell(int location);
137
141  void RestoreMaximizedState();
142
144
148  vtkGetMacro(MaximizedCell, int);
150
154  bool IsSplitCell(int location);
155
159  Direction GetSplitDirection(int location);
160
164  double GetSplitFraction(int location);
165
170  static int GetFirstChild(int location) { return 2 * location + 1; }
171
176  static int GetSecondChild(int location) { return 2 * location + 2; }
177
181  static int GetParent(int location) { return (location > 0 ? ((location - 1) / 2) : -1); }
182
186  vtkSMViewProxy* GetView(int location);
187
192  int GetViewLocation(vtkSMViewProxy*);
193
195
198  bool ContainsView(vtkSMViewProxy* view) { return this->GetViewLocation(view) != -1; }
199  bool ContainsView(vtkSMProxy* view);
201
207  void UpdateViewPositions();
208
214  void ShowViewsOnTileDisplay();
215
217
220  vtkImageData* CaptureWindow(int magnification)
221  {
222  return this->CaptureWindow(magnification, magnification);
223  }
224  vtkImageData* CaptureWindow(int magnificationX, int magnificationY);
226
231  {
232  return this->Superclass::SaveXMLState(root);
233  }
235
239  int LoadXMLState(vtkPVXMLElement* element, vtkSMProxyLocator* locator) override;
240
244  void Reset();
245
249  void GetLayoutExtent(int extent[4]);
250
252
257  void SetSize(const int size[2]);
258  void SetSize(int width, int height)
259  {
260  const int size[] = { width, height };
261  this->SetSize(size);
262  }
264
269  {
270  int extent[4];
271  this->GetLayoutExtent(extent);
272  return vtkVector2i(extent[1] - extent[0] + 1, extent[3] - extent[2] + 1);
273  }
274
279  static vtkSMViewLayoutProxy* FindLayout(vtkSMViewProxy*, const char* reggroup = "layouts");
280
284  std::vector<vtkSMViewProxy*> GetViews();
285
287
293  void SaveAsPNG(int rank, const char* fname);
295
296 protected:
298  ~vtkSMViewLayoutProxy() override;
299
303  void LoadState(const vtkSMMessage* message, vtkSMProxyLocator* locator) override;
304
310  virtual void UpdateState();
311
317  int GetEmptyCell(int root);
318
322  int GetSplittableCell(int root, Direction& suggested_direction);
323
325
326 private:
328  void operator=(const vtkSMViewLayoutProxy&) = delete;
329
330  class vtkInternals;
331  vtkInternals* Internals;
332
333  bool SetBlockUpdate(bool new_value)
334  {
335  bool temp = this->BlockUpdate;
336  this->BlockUpdate = new_value;
337  return temp;
338  }
339
340  bool BlockUpdate;
341
342  bool SetBlockUpdateViewPositions(bool val)
343  {
344  bool temp = this->BlockUpdateViewPositions;
345  this->BlockUpdateViewPositions = val;
346  return temp;
347  }
348  bool BlockUpdateViewPositions;
349 };
350
351 #endif
Returns the parent index.
location
Returns the index for the first child of the given location.
vtkImageData * CaptureWindow(int magnification)
Captures an image from the layout (including all the views in the layout.
Superclass for all view proxies.
bool ContainsView(vtkSMViewProxy *view)
Returns if a view is contained in this layout.
Update the size for all the views in the layout assuming the new size provided for the whole layout...
vtkPVXMLElement * SaveXMLState(vtkPVXMLElement *root) override
Overridden to save custom XML state.
size
void LoadState(const vtkSMMessage *msg, vtkSMProxyLocator *locator) override
This method is used to initialise the object to the given state If the definitionOnly Flag is set to ...
vtkSMViewLayoutProxy is used by ParaView to layout multiple views in a 2D KD-Tree layout...
static vtkSMProxy * New()
virtual int LoadXMLState(vtkPVXMLElement *element, vtkSMProxyLocator *locator)
Loads the proxy state from the XML element.
Definition: vtkSMProxy.h:152
void operator=(const vtkSMProxy &)=delete
vtkSMProxyInternals * Internals
Definition: vtkSMProxy.h:1006
virtual vtkPVXMLElement * SaveXMLState(vtkPVXMLElement *root)
Saves the state of the proxy.
extent
index
Returns the index for the second child of the given location.
vtkVector2i GetSize()
Returns the current size.
iterates over the properties of a proxy
