Components
pqIntRangeWidget.h
1
3
Program: ParaView
4
Module: pqIntRangeWidget.h
5
6
Copyright (c) 2005-2008 Sandia Corporation, Kitware Inc.
7
All rights reserved.
9
ParaView is a free software; you can redistribute it and/or modify it
10
under the terms of the ParaView license version 1.2.
11
12
See License_v1.2.txt for the full ParaView license.
13
A copy of this license can be obtained by contacting
14
Kitware Inc.
15
28 Corporate Drive
16
Clifton Park, NY 12065
17
USA
18
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
20
``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
21
LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
22
A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHORS OR
23
CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
24
EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
25
PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
26
PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
27
LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
28
NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
30
31
32
#ifndef pqIntRangeWidget_h
33
#define pqIntRangeWidget_h
35
36
#include "vtkSetGet.h"
// for VTK_LEGACY
37
vtkSmartPointer.h
38
#include <QWidget>
40
QSlider;
41
pqLineEdit
42
vtkSMIntRangeDomain
43
vtkEventQtSlotConnect
48
PQCOMPONENTS_EXPORT
pqIntRangeWidget
public
QWidget
49
50
Q_OBJECT
51
Q_PROPERTY(
int
value READ value WRITE setValue USER
true
52
Q_PROPERTY(
int
minimum READ minimum WRITE setMinimum)
53
Q_PROPERTY(
int
maximum READ maximum WRITE setMaximum)
54
#if !defined(VTK_LEGACY_REMOVE)
55
Q_PROPERTY(
bool
strictRange READ strictRange WRITE setStrictRange);
56
#endif
57
58
public
62
pqIntRangeWidget
(QWidget* parent = NULL);
63
pqIntRangeWidget
override
64
68
int
value
const
69
70
// get the min range value
71
int
minimum()
const
72
// get the max range value
73
int
maximum()
const
74
78
VTK_LEGACY
bool
strictRange()
const
79
80
// Sets the range domain to monitor. This will automatically update
81
// the widgets range when the domain changes.
82
void
setDomain(
vtkSMIntRangeDomain
* domain);
83
84
Q_SIGNALS:
88
void
valueChanged(
int
89
96
void
valueEdited(
int
97
98
public
Q_SLOTS:
102
void
setValue(
int
103
104
// set the min range value
105
void
setMinimum(
int
106
// set the max range value
107
void
setMaximum(
int
108
109
110
113
void
setStrictRange(
bool
114
#endif
115
116
private
Q_SLOTS:
117
void
sliderChanged(
int
118
void
textChanged(
const
QString&);
119
void
editingFinished();
120
void
updateValidator();
121
void
domainChanged();
122
void
emitValueEdited();
123
void
emitIfDeferredValueEdited();
124
void
sliderPressed();
125
void
sliderReleased();
126
127
private
128
int
Value;
129
int
Minimum;
130
int
Maximum;
131
QSlider* Slider;
132
pqLineEdit
* LineEdit;
133
bool
BlockUpdate;
134
135
bool
StrictRange =
false
136
#endif
137
vtkSmartPointer<vtkSMIntRangeDomain>
Domain;
138
* DomainConnection;
139
bool
InteractingWithSlider;
140
bool
DeferredValueEdited;
141
142
143
#endif
vtkSMIntRangeDomain
type specific extension to vtkSMRangeDomainTemplate for ints.
Definition:
vtkSMIntRangeDomain.h:39
pqIntRangeWidget
a widget with a tied slider and line edit for editing a int property
Definition:
pqIntRangeWidget.h:48
VTK_LEGACY
#define VTK_LEGACY(method)
Definition:
vtkLegacy.h:52
vtkSmartPointer< vtkSMIntRangeDomain >
pqLineEdit
pqLineEdit is a specialization of QLineEdit which provide a new property 'text2'. ...
Definition:
pqLineEdit.h:53
vtkSmartPointer.h
value
value
