a widget with a tied slider and line edit for editing a int property
#include <pqIntRangeWidget.h>
Inherits QWidget.
Definition at line 48 of file pqIntRangeWidget.h.
◆ pqIntRangeWidget()
| pqIntRangeWidget::pqIntRangeWidget |
QWidget * |
parent = NULL | ) |
constructor requires the proxy, property
◆ ~pqIntRangeWidget()
| pqIntRangeWidget::~pqIntRangeWidget |
◆ value()
| int pqIntRangeWidget::value |
const |
◆ minimum()
| int pqIntRangeWidget::minimum |
const |
◆ maximum()
| int pqIntRangeWidget::maximum |
const |
◆ strictRange()
| bool pqIntRangeWidget::strictRange |
const |
- Deprecated:
- strictRange is deprecated and is not working as intended
◆ setDomain()
◆ valueChanged
| void pqIntRangeWidget::valueChanged |
int |
signal |
◆ valueEdited
| void pqIntRangeWidget::valueEdited |
int |
signal |
signal the value was edited this means the user is done changing text or the user is done moving the slider.
It implies value was changed and editing has finished.
◆ setValue
| void pqIntRangeWidget::setValue |
int |
slot |
◆ setMinimum
| void pqIntRangeWidget::setMinimum |
int |
slot |
◆ setMaximum
| void pqIntRangeWidget::setMaximum |
int |
slot |
◆ setStrictRange
| void pqIntRangeWidget::setStrictRange |
bool |
slot |
- Deprecated:
◆ value
readwrite |
◆ minimum
readwrite |
◆ maximum
readwrite |
◆ strictRange
readwrite |
