| void | AddVolumeMapper (const char *name, vtkAbstractVolumeMapper *) |
| | Register a volume mapper with the representation. More...
| | vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More...
| void | SetExtractedBlockIndex (unsigned int index) |
| void | SetSamplingDimensions (int dims[3]) |
| void | SetSamplingDimensions (int xdim, int ydim, int zdim) |
| virtual void | SetActiveVolumeMapper (const char *) |
| | Set the active volume mapper to use. More...
| vtkAbstractVolumeMapper * | GetActiveVolumeMapper () |
| virtual void | SetUseDataPartitions (bool) |
| | Specify whether or not to redistribute the data. More...
| virtual bool | GetUseDataPartitions () |
| void | SetVisibility (bool val) override |
| | Get/Set the visibility for this representation. More...
| void | SetOrientation (double, double, double) |
| void | SetOrigin (double, double, double) |
| void | SetPickable (int val) |
| void | SetPosition (double, double, double) |
| void | SetScale (double, double, double) |
| void | SetInterpolationType (int val) |
| void | SetColor (vtkColorTransferFunction *lut) |
| void | SetScalarOpacity (vtkPiecewiseFunction *pwf) |
| void | SetScalarOpacityUnitDistance (double val) |
| void | SetMapScalars (bool) |
| void | SetMultiComponentsMapping (bool) |
| void | SetUseSeparateOpacityArray (bool) |
| void | SelectOpacityArray (int, int, int, int, const char *name) |
| void | SelectOpacityArrayComponent (int component) |
| vtkPVLODVolume * | GetActor () |
| | Provides access to the actor used by this representation. More...
| virtual void | MarkModified () |
| | This is one of the most important functions. More...
| virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| | Initialize the representation with an identifier range so each internal representation can own a unique ID. More...
| bool | GetNeedsUpdate () |
| void | ResetUpdateTime () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkUnstructuredGridVolumeRepresentation () |
| | ~vtkUnstructuredGridVolumeRepresentation () override |
| virtual void | UpdateMapperParameters () |
| | Passes on parameters to the active volume mapper. More...
| int | ProcessViewRequestResampleToImage (vtkInformationRequestKey *request_type, vtkInformation *inInfo, vtkInformation *outInfo) |
| int | RequestDataResampleToImage (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
| | vtkVolumeRepresentation () |
| | ~vtkVolumeRepresentation () override |
| bool | AppendOpacityComponent (vtkDataSet *dataset) |
| | Appends a designated opacity component to a scalar array used for color/opacity mapping. More...
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
