| virtual void | SetTetrahedraOnly (int) |
| | When On, the internal triangle filter will cull all 1D and 2D cells from the output. More...
| virtual int | GetTetrahedraOnly () |
| virtual void | SetExtractedBlockIndex (unsigned int) |
| | Sets which block will be extracted for volume rendering. More...
| virtual unsigned int | GetExtractedBlockIndex () |
| vtkUnstructuredGridAlgorithm * | NewInstance () const |
| vtkUnstructuredGrid * | GetUnstructuredGridInput (int port) |
| vtkUnstructuredGrid * | GetOutput () |
| vtkUnstructuredGrid * | GetOutput (int) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkVolumeRepresentationPreprocessor () |
| | ~vtkVolumeRepresentationPreprocessor () override |
| vtkSmartPointer< vtkUnstructuredGrid > | Tetrahedralize (vtkDataObject *) |
| vtkSmartPointer< vtkDataSet > | ExtractDataSet (vtkCompositeDataSet *) |
| | vtkUnstructuredGridAlgorithm () |
| | ~vtkUnstructuredGridAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
prepare data object for volume rendering
vtkVolumeRepresentationPreprocessor prepares data objects for volume rendering. If the data object is a data set, then the set is passed through a vtkDataSetTriangleFilter before being output as a vtkUnstructuredGrid. If the data object is a multiblock dataset with at least one unstructured grid leaf node, then the unstructured grid is extracted using vtkExtractBlock and vtkMergeBlocks. The TetrahedraOnly property may be set and it will be passed to the vtkDataSetTriangleFilter.
- See also
- vtkExtractBlock vtkTriangleFilter
Definition at line 40 of file vtkVolumeRepresentationPreprocessor.h.
