| void | SetForceUseStrips (int) |
| virtual int | GetForceUseStrips () |
| virtual void | ForceUseStripsOn () |
| virtual void | ForceUseStripsOff () |
| virtual int | GetOutlineFlag () |
| | This flag is set during the execute method. More...
| virtual void | SetUseOutline (int) |
| | Set/get whether to produce outline (vs. More...
| virtual int | GetUseOutline () |
| virtual void | SetGenerateFeatureEdges (bool) |
| | Set/get whether to produce feature edges (vs. More...
| virtual bool | GetGenerateFeatureEdges () |
| virtual void | SetBlockColorsDistinctValues (int) |
| | Determines the number of distinct values in vtkBlockColors. More...
| virtual int | GetBlockColorsDistinctValues () |
| void | SetUseStrips (int) |
| | When input is structured data, this flag will generate faces with triangle strips. More...
| virtual int | GetUseStrips () |
| virtual void | UseStripsOn () |
| virtual void | UseStripsOff () |
| virtual void | SetGenerateCellNormals (int) |
| | Whether to generate cell normals. More...
| virtual int | GetGenerateCellNormals () |
| virtual void | GenerateCellNormalsOn () |
| virtual void | GenerateCellNormalsOff () |
| virtual void | SetTriangulate (int val) |
| | Whether to triangulate mesh for rendering. More...
| virtual int | GetTriangulate () |
| virtual void | TriangulateOn () |
| virtual void | TriangulateOff () |
| virtual void | SetNonlinearSubdivisionLevel (int) |
| | Nonlinear faces are approximated with flat polygons. More...
| virtual int | GetNonlinearSubdivisionLevel () |
| virtual void | SetController (vtkMultiProcessController *) |
| | Set and get the controller. More...
| virtual vtkMultiProcessController * | GetController () |
| void | SetPassThroughCellIds (int) |
| | If on, the output polygonal dataset will have a celldata array that holds the cell index of the original 3D cell that produced each output cell. More...
| virtual int | GetPassThroughCellIds () |
| virtual void | PassThroughCellIdsOn () |
| virtual void | PassThroughCellIdsOff () |
| void | SetPassThroughPointIds (int) |
| | If on, the output polygonal dataset will have a pointdata array that holds the point index of the original vertex that produced each output vertex. More...
| virtual int | GetPassThroughPointIds () |
| virtual void | PassThroughPointIdsOn () |
| virtual void | PassThroughPointIdsOff () |
| virtual void | SetGenerateProcessIds (bool) |
| | If on, point arrays named vtkProcessId is added. More...
| virtual bool | GetGenerateProcessIds () |
| virtual void | GenerateProcessIdsOn () |
| virtual void | GenerateProcessIdsOff () |
| virtual void | SetHideInternalAMRFaces (bool) |
| | This property affects the way AMR outlines and faces are generated. More...
| virtual bool | GetHideInternalAMRFaces () |
| virtual void | HideInternalAMRFacesOn () |
| virtual void | HideInternalAMRFacesOff () |
| virtual void | SetUseNonOverlappingAMRMetaDataForOutlines (bool) |
| | For overlapping AMR, this property controls affects the way AMR outlines are generated. More...
| virtual bool | GetUseNonOverlappingAMRMetaDataForOutlines () |
| virtual void | UseNonOverlappingAMRMetaDataForOutlinesOn () |
| virtual void | UseNonOverlappingAMRMetaDataForOutlinesOff () |
| vtkDataObjectAlgorithm * | NewInstance () const |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPVGeometryFilter () |
| | ~vtkPVGeometryFilter () override |
| void | ExecuteAMRBlock (vtkUniformGrid *input, vtkPolyData *output, const bool extractface[6]) |
| | Produce geometry for a block in the dataset. More...
| void | ExecuteAMRBlockOutline (const double bounds[6], vtkPolyData *output, const bool extractface[6]) |
| | Used instead of ExecuteAMRBlock() when this->UseOutline is true. More...
| void | ExecuteBlock (vtkDataObject *input, vtkPolyData *output, int doCommunicate, int updatePiece, int updateNumPieces, int updateGhosts, const int *wholeExtent) |
| void | DataSetExecute (vtkDataSet *input, vtkPolyData *output, int doCommunicate) |
| void | GenericDataSetExecute (vtkGenericDataSet *input, vtkPolyData *output, int doCommunicate) |
| void | ImageDataExecute (vtkImageData *input, vtkPolyData *output, int doCommunicate, int updatePiece, const int *ext) |
| void | StructuredGridExecute (vtkStructuredGrid *input, vtkPolyData *output, int updatePiece, int updateNumPieces, int updateGhosts, const int *wholeExtent) |
| void | RectilinearGridExecute (vtkRectilinearGrid *input, vtkPolyData *output, int updatePiece, int updateNumPieces, int updateGhosts, const int *wholeExtent) |
| void | UnstructuredGridExecute (vtkUnstructuredGridBase *input, vtkPolyData *output, int doCommunicate) |
| void | PolyDataExecute (vtkPolyData *input, vtkPolyData *output, int doCommunicate) |
| void | HyperTreeGridExecute (vtkHyperTreeGrid *input, vtkPolyData *output, int doCommunicate) |
| void | ExplicitStructuredGridExecute (vtkExplicitStructuredGrid *input, vtkPolyData *out, int doCommunicate, const int *wholeExtent) |
| void | CleanupOutputData (vtkPolyData *output, int doCommunicate) |
| | Cleans up the output polydata. More...
| void | ExecuteCellNormals (vtkPolyData *output, int doCommunicate) |
| void | ChangeUseStripsInternal (int val, int force) |
| int | CheckAttributes (vtkDataObject *input) |
| | Call CheckAttributes on the input which ensures that all attribute arrays have valid lengths. More...
| void | HandleGeometryFilterProgress (vtkObject *caller, unsigned long, void *) |
| int | FillInputPortInformation (int, vtkInformation *) override |
| void | ReportReferences (vtkGarbageCollector *) override |
| int | RequestUpdateExtent (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| | Overridden to request ghost-cells for vtkUnstructuredGrid inputs so that we don't generate internal surfaces. More...
| void | RemoveGhostCells (vtkPolyData *) |
| int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| | Overridden to create vtkMultiBlockDataSet when input is a composite-dataset and vtkPolyData when input is a vtkDataSet. More...
| virtual int | RequestAMRData (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
| virtual int | RequestDataObjectTree (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
| | vtkDataObjectAlgorithm () |
| | ~vtkDataObjectAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
