| static vtkSMSelectionHelper * | New () |
| static vtkSMSelectionHelper * | SafeDownCast (vtkObject *o) |
| static vtkSMProxy * | NewSelectionSourceFromSelection (vtkSMSession *session, vtkSelection *selection, bool ignore_composite_keys=false) |
| | Given a selection, returns a proxy for a selection source that has the ids specified by it. More...
| static void | NewSelectionSourcesFromSelection (vtkSelection *selection, vtkSMProxy *view, vtkCollection *selSources, vtkCollection *selRepresentations) |
| static vtkSMProxy * | ConvertSelection (int outputType, vtkSMProxy *selectionSourceProxy, vtkSMSourceProxy *dataSource, int outputport) |
| | Given the ContentType for an output vtkSelection, this create a new source proxy generating the selection, the input selectionSourceProxy is used to fill the default values for created selection source. More...
| static bool | MergeSelection (vtkSMSourceProxy *output, vtkSMSourceProxy *input, vtkSMSourceProxy *dataSource, int outputport) |
| | Updates output to be a combination of (input | output) if the two selection sources are mergeable. More...
| static bool | SubtractSelection (vtkSMSourceProxy *output, vtkSMSourceProxy *input, vtkSMSourceProxy *dataSource, int outputport) |
| | Updates output to be a subtraction of input and output (input - output) if the two selection sources are mergeable. More...
| static bool | ToggleSelection (vtkSMSourceProxy *output, vtkSMSourceProxy *input, vtkSMSourceProxy *dataSource, int outputport) |
| | Updates output to be a toggle of input and output (input + (input | output ) - (input & output ) ) if the two selection sources are mergeable. More...
Utility class to help with selection tasks.
This class contains several static methods that help with the complicated selection task.
Definition at line 36 of file vtkSMSelectionHelper.h.
