initialization helper for a proxy. More...
#include <vtkSMProxyInitializationHelper.h>
| virtual void | PostInitializeProxy (vtkSMProxy *proxy, vtkPVXMLElement *xml, vtkMTimeType initializationTimeStamp)=0 |
| Called during vtkSMParaViewPipelineController::PostInitializeProxy() to initialize a proxy. More... | |
| virtual void | RegisterProxy (vtkSMProxy *proxy, vtkPVXMLElement *xml) |
| Called during vtkSMParaViewPipelineController::Register. More... | |
| static vtkSMProxyInitializationHelper * | SafeDownCast (vtkObject *o) |
| vtkSMProxyInitializationHelper () | |
| ~vtkSMProxyInitializationHelper () override | |
| vtkSMObject () | |
vtkSMProxyInitializationHelper is used to add custom initialization logic to the initialization of a proxy done by vtkSMParaViewPipelineController. Developers can create new subclasses of vtkSMProxyInitializationHelper for specific proxy types. vtkSMProxyInitializationHelper will instantiate the helper and call PostInitializeProxy() in vtkSMParaViewPipelineController::PostInitializeProxy().
Helpers are added to a proxy in the XML configuration as follows:
Definition at line 44 of file vtkSMProxyInitializationHelper.h.
Definition at line 47 of file vtkSMProxyInitializationHelper.h.
Reimplemented in vtkSMSpreadSheetRepresentationInitializationHelper, vtkSMCSVProxiesInitializationHelper, vtkSMOMETIFFChannelCalculatorInitializationHelper, vtkSMPLYWriterProxyInitializationHelper, vtkSMXYChartRepresentationInitializationHelper, and vtkSMExtractSelectionProxyInitializationHelper.
Reimplemented in vtkSMSpreadSheetRepresentationInitializationHelper, and vtkSMXYChartRepresentationInitializationHelper.
pure virtual |
| proxy | : the proxy being initialized. |
| xml | : the XML configuration from this helper from this Hints for the proxy. This makes it possible to pass additional configuration parameters to the initialization helper. |
| initializationTimeStamp | the timestamp for the proxy initialization. Generally, if a property on the proxy has MTime greater than initializationTimeStamp, the initializer should not modify the property since it was explicitly set by the user during initialization. |
Implemented in vtkSMSpreadSheetRepresentationInitializationHelper, vtkSMCSVProxiesInitializationHelper, vtkSMOMETIFFChannelCalculatorInitializationHelper, vtkSMPLYWriterProxyInitializationHelper, vtkSMXYChartRepresentationInitializationHelper, and vtkSMExtractSelectionProxyInitializationHelper.
*Proxy to register any helper proxies created during by this helper. Default implementation does nothing.
Reimplemented in vtkSMOMETIFFChannelCalculatorInitializationHelper.
