| void | AddGroup (const char *group) |
| | Add a group to the domain. More...
| int | IsInDomain (vtkSMProperty *property) override |
| | Returns true if the value of the property is in the domain. More...
| int | IsInDomain (vtkSMProxy *proxy) |
| | Returns true if the proxy is in the domain. More...
| unsigned int | GetNumberOfGroups () |
| | Returns the number of groups. More...
| const char * | GetGroup (unsigned int idx) |
| | Returns group with give id. More...
| unsigned int | GetNumberOfProxies () |
| | Returns the total number of proxies in the domain. More...
| vtkSMProxy * | GetProxy (const char *name) |
| | Given a name, returns a proxy. More...
| const char * | GetProxyName (unsigned int idx) |
| | Returns the name (in the group) of a proxy. More...
| vtkSMProxy * | GetProxy (unsigned int idx) |
| | Given an index, returns a proxy. More...
| const char * | GetProxyName (vtkSMProxy *proxy) |
| virtual void | Update (vtkSMProperty *requestingProperty) |
| | Update self based on the "unchecked" values of all required properties. More...
| | Helper method to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| | vtkSMProxyGroupDomain () |
| | ~vtkSMProxyGroupDomain () override |
| int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| | vtkSMDomain () |
| void | DomainModified () |
| void | InvokeModified () |
| virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
union of proxy groups
The proxy group domain consists of all proxies in a list of groups. This domain is commonly used together with vtkSMProxyproperty Valid XML elements are:
* * <Group name=""> where name is the groupname used by the proxy
* manager to refer to a group of proxies.
// .SECTION See Also vtkSMDomain vtkSMProxyproperty
Definition at line 40 of file vtkSMProxyGroupDomain.h.
