| int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| | Set the default values for the property. More...
| void | Update (vtkSMProperty *requestingProperty) override |
| | Overridden to fire DomainModified when the required property changes. More...
Public Member Functions inherited from vtkSMBooleanDomain |
| int | IsInDomain (vtkSMProperty *property) override |
| | Returns true if the property is a vtkSMIntVectorProperty. More...
| void | SetAnimationValue (vtkSMProperty *property, int idx, double value) override |
| | Helper method to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| | vtkSMChartUseIndexForAxisDomain () |
| | ~vtkSMChartUseIndexForAxisDomain () override |
Protected Member Functions inherited from vtkSMBooleanDomain |
| | vtkSMBooleanDomain () |
| | ~vtkSMBooleanDomain () override |
| | vtkSMDomain () |
| virtual int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) |
| void | DomainModified () |
| void | InvokeModified () |
| virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
extends vtkSMBooleanDomain to pick a good default for properties such as "UseIndexForXAxis" on chart representations.
vtkSMChartUseIndexForAxisDomain extends vtkSMBooleanDomain to add logic to pick an appropriate default e.g. UseIndexForXAxis for bar and line charts needs to be set to 0 by default, if the XArrayName contains one of the known arrays such as "bin_extents", "arc_length", and set to 1 otherwise. This class encapsulates that logic.
Supported Required-Property functions:
- ArraySelection : (required) refers to the property that dictates the array selection.
Definition at line 38 of file vtkSMChartUseIndexForAxisDomain.h.
