| int | IsInDomain (vtkSMProperty *property) override |
| | Returns true if the property is a vtkSMIntVectorProperty. More...
| void | SetAnimationValue (vtkSMProperty *property, int idx, double value) override |
| virtual void | Update (vtkSMProperty *requestingProperty) |
| | Update self based on the "unchecked" values of all required properties. More...
| | Helper method to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| | vtkSMBooleanDomain () |
| | ~vtkSMBooleanDomain () override |
| | vtkSMDomain () |
| virtual int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) |
| void | DomainModified () |
| void | InvokeModified () |
| virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
a domain with two values: true or false
vtkSMBooleanDomain does not really restrict the values of the property that contains it. All integer values are valid. Rather, it is used to specified that the property represents a true/false state. This domains works with only vtkSMIntVectorProperty.
- See also
- vtkSMDomain vtkSMIntVectorProperty
Definition at line 33 of file vtkSMBooleanDomain.h.
