| virtual void | SetPosition (double, double, double) |
| virtual void | SetPosition (double [3]) |
| virtual double * | GetPosition () |
| virtual void | GetPosition (double &, double &, double &) |
| virtual void | GetPosition (double [3]) |
| virtual void | SetOrientation (double, double, double) |
| virtual void | SetOrientation (double [3]) |
| virtual double * | GetOrientation () |
| virtual void | GetOrientation (double &, double &, double &) |
| virtual void | GetOrientation (double [3]) |
| virtual void | SetScale (double, double, double) |
| virtual void | SetScale (double [3]) |
| virtual double * | GetScale () |
| virtual void | GetScale (double &, double &, double &) |
| virtual void | GetScale (double [3]) |
| virtual double * | GetDataBounds () |
| virtual void | GetDataBounds (double &, double &, double &, double &, double &, double &) |
| virtual void | GetDataBounds (double [6]) |
| virtual void | SetCustomBounds (double, double, double, double, double, double) |
| virtual void | SetCustomBounds (double [6]) |
| virtual double * | GetCustomBounds () |
| virtual void | GetCustomBounds (double &, double &, double &, double &, double &, double &) |
| virtual void | GetCustomBounds (double [6]) |
| virtual void | SetEnableCustomBounds (int, int, int) |
| virtual void | SetEnableCustomBounds (int [3]) |
| virtual int * | GetEnableCustomBounds () |
| virtual void | GetEnableCustomBounds (int &, int &, int &) |
| virtual void | GetEnableCustomBounds (int [3]) |
| virtual void | SetEnableCustomRange (bool) |
| virtual bool | GetEnableCustomRange () |
| virtual void | SetCustomRange (double, double) |
| void | SetCustomRange (double [2]) |
| virtual double * | GetCustomRange () |
| virtual void | GetCustomRange (double &, double &) |
| virtual void | GetCustomRange (double [2]) |
| virtual void | SetPolarAxisColor (double r, double g, double b) |
| virtual void | SetPolarArcsColor (double r, double g, double b) |
| virtual void | SetSecondaryPolarArcsColor (double r, double g, double b) |
| virtual void | SetSecondaryRadialAxesColor (double r, double g, double b) |
| virtual void | SetLastRadialAxisColor (double r, double g, double b) |
| virtual void | SetPolarAxisTitleTextProperty (vtkTextProperty *prop) |
| virtual void | SetPolarAxisLabelTextProperty (vtkTextProperty *prop) |
| virtual void | SetLastRadialAxisTextProperty (vtkTextProperty *prop) |
| virtual void | SetSecondaryRadialAxesTextProperty (vtkTextProperty *prop) |
| | This is one of the most important functions. More...
| | vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More...
| void | SetVisibility (bool visible) override |
| | Get/Set the visibility for this representation. More...
| virtual void | SetParentVisibility (bool visible) |
| virtual void | SetLog (bool active) |
| virtual void | SetNumberOfRadialAxes (vtkIdType val) |
| virtual void | SetNumberOfPolarAxisTicks (int val) |
| virtual void | SetAutoSubdividePolarAxis (bool active) |
| virtual void | SetMinimumRadius (double radius) |
| virtual void | SetMinimumAngle (double angle) |
| virtual void | SetMaximumAngle (double angle) |
| virtual void | SetSmallestVisiblePolarAngle (double angle) |
| virtual void | SetTickLocation (int location) |
| virtual void | SetRadialUnits (bool use) |
| virtual void | SetScreenSize (double size) |
| virtual void | SetPolarAxisTitle (const char *title) |
| virtual void | SetPolarLabelFormat (const char *format) |
| virtual void | SetExponentLocation (int location) |
| virtual void | SetRadialAngleFormat (const char *format) |
| virtual void | SetEnableDistanceLOD (int enable) |
| virtual void | SetDistanceLODThreshold (double val) |
| virtual void | SetEnableViewAngleLOD (int enable) |
| virtual void | SetViewAngleLODThreshold (double val) |
| virtual void | SetPolarAxisVisibility (int visible) |
| virtual void | SetDrawRadialGridlines (int draw) |
| virtual void | SetDrawPolarArcsGridlines (int draw) |
| virtual void | SetPolarTitleVisibility (int visible) |
| virtual void | SetRadialAxisTitleLocation (int location) |
| virtual void | SetPolarAxisTitleLocation (int location) |
| virtual void | SetPolarLabelVisibility (int visible) |
| virtual void | SetArcTicksOriginToPolarAxis (int use) |
| virtual void | SetRadialAxesOriginToPolarAxis (int use) |
| virtual void | SetPolarTickVisibility (int visible) |
| virtual void | SetAxisTickVisibility (int visible) |
| virtual void | SetAxisMinorTickVisibility (int visible) |
| virtual void | SetArcTickVisibility (int visible) |
| virtual void | SetArcMinorTickVisibility (int visible) |
| virtual void | SetArcMajorTickSize (double size) |
| virtual void | SetPolarAxisMajorTickSize (double size) |
| virtual void | SetLastRadialAxisMajorTickSize (double size) |
| virtual void | SetPolarAxisTickRatioSize (double size) |
| virtual void | SetLastAxisTickRatioSize (double size) |
| virtual void | SetArcTickRatioSize (double size) |
| virtual void | SetPolarAxisMajorTickThickness (double thickness) |
| virtual void | SetLastRadialAxisMajorTickThickness (double thickness) |
| virtual void | SetArcMajorTickThickness (double thickness) |
| virtual void | SetPolarAxisTickRatioThickness (double thickness) |
| virtual void | SetLastAxisTickRatioThickness (double thickness) |
| virtual void | SetArcTickRatioThickness (double thickness) |
| virtual void | SetDeltaAngleMajor (double delta) |
| virtual void | SetDeltaAngleMinor (double delta) |
| virtual void | SetRadialAxesVisibility (int visible) |
| virtual void | SetRadialTitleVisibility (int visible) |
| virtual void | SetPolarArcsVisibility (int visible) |
| virtual void | SetUse2DMode (int use) |
| virtual void | SetRatio (double ratio) |
| virtual double | GetDeltaRangeMinor () |
| virtual double | GetDeltaRangeMajor () |
| virtual void | SetRendererType (int) |
| virtual int | GetRendererType () |
| virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| | Initialize the representation with an identifier range so each internal representation can own a unique ID. More...
| bool | GetNeedsUpdate () |
| void | ResetUpdateTime () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPolarAxesRepresentation () |
| | ~vtkPolarAxesRepresentation () override |
| int | RequestData (vtkInformation *, vtkInformationVector **inputVector, vtkInformationVector *) override |
| virtual void | InitializeDataBoundsFromData (vtkDataObject *data) |
| virtual void | UpdateBounds () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
