| void | OnMouseMove (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *rwi) override |
| | Event bindings controlling the effects of pressing mouse buttons or moving the mouse. More...
| void | OnButtonDown (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *rwi) override |
| virtual void | SetUseDollyForPerspectiveProjection (bool) |
| | Set this to false (true by default) to not dolly in case of perspective projection and use zoom i.e. More...
| virtual bool | GetUseDollyForPerspectiveProjection () |
| virtual void | UseDollyForPerspectiveProjectionOn () |
| virtual void | UseDollyForPerspectiveProjectionOff () |
| void | OnButtonUp (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *rwi) override |
| virtual void | StartInteraction () |
| virtual void | EndInteraction () |
| virtual void | OnKeyUp (vtkRenderWindowInteractor *iren) |
| | These methods are called on all registered manipulators, not just the active one. More...
| virtual void | OnKeyDown (vtkRenderWindowInteractor *iren) |
| virtual void | SetButton (int) |
| | These settings determine which button and modifiers the manipulator responds to. More...
| virtual int | GetButton () |
| virtual void | SetShift (int) |
| virtual int | GetShift () |
| virtual void | ShiftOn () |
| virtual void | ShiftOff () |
| virtual void | SetControl (int) |
| virtual int | GetControl () |
| virtual void | ControlOn () |
| virtual void | ControlOff () |
| virtual void | SetCenter (double, double, double) |
| | For setting the center of rotation. More...
| virtual void | SetCenter (double [3]) |
| virtual double * | GetCenter () |
| virtual void | GetCenter (double &, double &, double &) |
| virtual void | GetCenter (double [3]) |
| virtual void | SetRotationFactor (double) |
| | Set and get the rotation factor. More...
| virtual double | GetRotationFactor () |
| virtual void | SetManipulatorName (const char *) |
| | Set and get the manipulator name. More...
| virtual char * | GetManipulatorName () |
| void | SetGUIHelper (vtkCameraManipulatorGUIHelper *) |
| | Get/Set the GUI helper. More...
| virtual vtkCameraManipulatorGUIHelper * | GetGUIHelper () |
Zooms camera with vertical mouse movement to mouse position.
vtkPVTrackballZoomToMouse is a redifinition of a vtkPVTrackballZoom allowing the user to zoom at the point projected under the mouse position.
Definition at line 29 of file vtkPVTrackballZoomToMouse.h.
