| virtual void | SetUseDollyForPerspectiveProjection (bool) |
| | Set this to false (true by default) to not dolly in case of perspective projection and use zoom i.e. More...
| virtual bool | GetUseDollyForPerspectiveProjection () |
| virtual void | UseDollyForPerspectiveProjectionOn () |
| virtual void | UseDollyForPerspectiveProjectionOff () |
| void | OnMouseMove (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *rwi) override |
| | Event bindings controlling the effects of pressing mouse buttons or moving the mouse. More...
| void | OnButtonDown (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *rwi) override |
| void | OnButtonUp (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *rwi) override |
| virtual void | StartInteraction () |
| virtual void | EndInteraction () |
| virtual void | OnKeyUp (vtkRenderWindowInteractor *iren) |
| | These methods are called on all registered manipulators, not just the active one. More...
| virtual void | OnKeyDown (vtkRenderWindowInteractor *iren) |
| virtual void | SetButton (int) |
| | These settings determine which button and modifiers the manipulator responds to. More...
| virtual int | GetButton () |
| virtual void | SetShift (int) |
| virtual int | GetShift () |
| virtual void | ShiftOn () |
| virtual void | ShiftOff () |
| virtual void | SetControl (int) |
| virtual int | GetControl () |
| virtual void | ControlOn () |
| virtual void | ControlOff () |
| virtual void | SetCenter (double, double, double) |
| | For setting the center of rotation. More...
| virtual void | SetCenter (double [3]) |
| virtual double * | GetCenter () |
| virtual void | GetCenter (double &, double &, double &) |
| virtual void | GetCenter (double [3]) |
| virtual void | SetRotationFactor (double) |
| | Set and get the rotation factor. More...
| virtual double | GetRotationFactor () |
| virtual void | SetManipulatorName (const char *) |
| | Set and get the manipulator name. More...
| virtual char * | GetManipulatorName () |
| void | SetGUIHelper (vtkCameraManipulatorGUIHelper *) |
| | Get/Set the GUI helper. More...
| virtual vtkCameraManipulatorGUIHelper * | GetGUIHelper () |
Zooms camera with vertical mouse movement.
vtkPVTrackballZoom allows the user to interactively manipulate the camera, the viewpoint of the scene. Moving the mouse down zooms in. Up zooms out.
When zooming in Perpective projection, this manipulator by default, dollys (rather than zooms) i.e. moves the camera further (or farther) in the view direction. This is default behavior. You can change that to use zoom instead i.e. change view angle on camera, by setting UseDollyForPerspectiveProjection to off.
Definition at line 36 of file vtkPVTrackballZoom.h.
