Abstraction of style away from button. More...
#include <vtkCameraManipulator.h>
| virtual void | OnMouseMove (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *iren) |
| virtual void | OnButtonDown (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *iren) |
| virtual void | OnButtonUp (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *iren) |
| virtual void | StartInteraction () |
| Event bindings controlling the effects of pressing mouse buttons or moving the mouse. More... | |
| virtual void | EndInteraction () |
| virtual void | OnKeyUp (vtkRenderWindowInteractor *iren) |
| These methods are called on all registered manipulators, not just the active one. More... | |
| virtual void | OnKeyDown (vtkRenderWindowInteractor *iren) |
| virtual void | SetButton (int) |
| These settings determine which button and modifiers the manipulator responds to. More... | |
| virtual int | GetButton () |
| virtual void | SetShift (int) |
| virtual int | GetShift () |
| virtual void | ShiftOn () |
| virtual void | ShiftOff () |
| virtual void | SetControl (int) |
| virtual int | GetControl () |
| virtual void | ControlOn () |
| virtual void | ControlOff () |
| virtual void | SetCenter (double, double, double) |
| For setting the center of rotation. More... | |
| virtual void | SetCenter (double [3]) |
| virtual double * | GetCenter () |
| virtual void | GetCenter (double &, double &, double &) |
| virtual void | GetCenter (double [3]) |
| virtual void | SetRotationFactor (double) |
| Set and get the rotation factor. More... | |
| virtual double | GetRotationFactor () |
| virtual void | SetManipulatorName (const char *) |
| Set and get the manipulator name. More... | |
| virtual char * | GetManipulatorName () |
| static vtkCameraManipulator * | New () |
| static vtkCameraManipulator * | SafeDownCast (vtkObject *o) |
| void | ComputeDisplayCenter (vtkRenderer *ren) |
Protected Attributes | |
| char * | ManipulatorName |
| int | Button |
| int | Shift |
| int | Control |
| double | Center [3] |
| double | RotationFactor |
| double | DisplayCenter [2] |
| vtkCameraManipulatorGUIHelper * | GUIHelper |
| void | SetGUIHelper (vtkCameraManipulatorGUIHelper *) |
| Get/Set the GUI helper. More... | |
| virtual vtkCameraManipulatorGUIHelper * | GetGUIHelper () |
| vtkCameraManipulator () | |
| ~vtkCameraManipulator () override | |
vtkCameraManipulator is a superclass foractions inside an interactor style and associated with a single button. An example might be rubber-band bounding-box zoom. This abstraction allows a camera manipulator to be assigned to any button. This super class might become a subclass of vtkInteractorObserver in the future.
Definition at line 36 of file vtkCameraManipulator.h.
Definition at line 40 of file vtkCameraManipulator.h.
Reimplemented in vtkPVTrackballMultiRotate, vtkPVTrackballZoom, vtkPVTrackballMoveActor, vtkTrackballPan, vtkPVTrackballPan, vtkPVJoystickFly, vtkPVTrackballRoll, vtkPVTrackballZoomToMouse, vtkPVJoystickFlyIn, vtkPVJoystickFlyOut, and vtkPVTrackballRotate.
Hence, these should just be used to record state and not perform any interactions.
Reimplemented in vtkPVTrackballRotate, and vtkTrackballPan.
Button can be either 1 (left), 2 (middle), and 3 right.
| void vtkCameraManipulator::SetGUIHelper | ( | vtkCameraManipulatorGUIHelper * | ) |
Definition at line 118 of file vtkCameraManipulator.h.
Definition at line 120 of file vtkCameraManipulator.h.
Definition at line 121 of file vtkCameraManipulator.h.
Definition at line 122 of file vtkCameraManipulator.h.
Definition at line 124 of file vtkCameraManipulator.h.
Definition at line 125 of file vtkCameraManipulator.h.
Definition at line 126 of file vtkCameraManipulator.h.
Definition at line 129 of file vtkCameraManipulator.h.
