vtkSynchronizedRenderers subclass that handles adjusting of camera for cave configurations. More...
#include <vtkCaveSynchronizedRenderers.h>
| typedef vtkSynchronizedRenderers | Superclass |
Public Types inherited from vtkSynchronizedRenderers | |
Public Member Functions inherited from vtkSynchronizedRenderers | |
| vtkSynchronizedRenderers * | NewInstance () const |
| void | CollectiveExpandForVisiblePropBounds (double bounds[6]) |
| virtual vtkRenderer * | GetRenderer () |
| virtual void | SetParallelController (vtkMultiProcessController *) |
| virtual vtkMultiProcessController * | GetParallelController () |
| virtual void | SetParallelRendering (bool) |
| virtual bool | GetParallelRendering () |
| virtual void | ParallelRenderingOn () |
| virtual void | ParallelRenderingOff () |
| virtual void | SetImageReductionFactor (int) |
| virtual int | GetImageReductionFactor () |
| virtual void | SetWriteBackImages (bool) |
| virtual bool | GetWriteBackImages () |
| virtual void | WriteBackImagesOn () |
| virtual void | WriteBackImagesOff () |
| virtual void | SetRootProcessId (int) |
| virtual int | GetRootProcessId () |
| virtual void | SetCaptureDelegate (vtkSynchronizedRenderers *) |
| virtual vtkSynchronizedRenderers * | GetCaptureDelegate () |
| virtual void | SetAutomaticEventHandling (bool) |
| virtual bool | GetAutomaticEventHandling () |
| virtual void | AutomaticEventHandlingOn () |
| virtual void | AutomaticEventHandlingOff () |
| static vtkCaveSynchronizedRenderers * | New () |
| static vtkCaveSynchronizedRenderers * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSynchronizedRenderers | |
| static vtkSynchronizedRenderers * | New () |
| static vtkSynchronizedRenderers * | SafeDownCast (vtkObjectBase *o) |
| vtkCaveSynchronizedRenderers () | |
| ~vtkCaveSynchronizedRenderers () override | |
| void | HandleStartRender () override |
| Called at the start of each render. More... | |
| void | ProcessCaveConfiguration () |
| During constructor, processes the configuration file to setup the display information. More... | |
| void | SetNumberOfDisplays (int numberOfDisplays) |
| These are to initialize the displays. More... | |
| void | SetEyeSeparation (double eyeSeparation) |
| Set the eye separation for all the displays. More... | |
| void | DefineDisplay (int idx, double origin[3], double x[3], double y[3]) |
| void | ComputeCamera (vtkCamera *cam) |
| Method to update the camera. More... | |
| void | SetRenderer (vtkRenderer *renderer) override |
| Override Superclass to compute Displays parameters in case of a single screen cave (e.g. More... | |
Protected Member Functions inherited from vtkSynchronizedRenderers | |
| vtkSynchronizedRenderers () | |
| ~vtkSynchronizedRenderers () | |
| virtual void | HandleEndRender () |
| virtual void | HandleAbortRender () |
| virtual void | MasterStartRender () |
| virtual void | SlaveStartRender () |
| virtual void | MasterEndRender () |
| virtual void | SlaveEndRender () |
| virtual vtkRawImage & | CaptureRenderedImage () |
| virtual void | PushImageToScreen () |
Protected Attributes | |
| double | EyeSeparation |
| int | NumberOfDisplays |
| double ** | Displays |
| double | DisplayOrigin [3] |
| double | DisplayX [3] |
| double | DisplayY [3] |
| int | once |
Protected Attributes inherited from vtkSynchronizedRenderers | |
| vtkMultiProcessController * | ParallelController |
| vtkOpenGLRenderer * | Renderer |
| vtkSynchronizedRenderers * | CaptureDelegate |
| vtkRawImage | ReducedImage |
| vtkRawImage | FullImage |
| bool | ParallelRendering |
| int | ImageReductionFactor |
| bool | WriteBackImages |
| int | RootProcessId |
| bool | AutomaticEventHandling |
Public Attributes inherited from vtkSynchronizedRenderers | |
| SYNC_RENDERER_TAG | |
| RESET_CAMERA_TAG | |
| COMPUTE_BOUNDS_TAG | |
vtkCaveSynchronizedRenderers is vtkSynchronizedRenderers used for in CAVE configuration. It is used on the render-server side. It ensures that the camera is transformed based on the orientations specified in the pvx configuration file. This code was previously in class vtkCaveRenderManager.
In case of a single display, if the cave bounds are not set, we compute these values from vtkPVServerOptions::Geometry and the client camera view angle.
Definition at line 39 of file vtkCaveSynchronizedRenderers.h.
Definition at line 43 of file vtkCaveSynchronizedRenderers.h.
Reimplemented from vtkSynchronizedRenderers.
overrideprotectedvirtual |
Overridden to ensure that the camera is updated based on the configuration.
(This is directly copied from vtkCaveRenderManager).
zSpace)
Definition at line 86 of file vtkCaveSynchronizedRenderers.h.
Definition at line 87 of file vtkCaveSynchronizedRenderers.h.
Definition at line 88 of file vtkCaveSynchronizedRenderers.h.
Definition at line 89 of file vtkCaveSynchronizedRenderers.h.
Definition at line 90 of file vtkCaveSynchronizedRenderers.h.
Definition at line 91 of file vtkCaveSynchronizedRenderers.h.
Definition at line 92 of file vtkCaveSynchronizedRenderers.h.
