singleton used to keep track of options for vtkPVRenderView. More...
#include <vtkPVRenderViewSettings.h>
| enum | { DO_NOTHING = 0, OFFSET_FACES = 1, OFFSET_LINES_AND_VERTS = 2, ZSHIFT = 3 } |
| enum | { AUTOMATIC = 0, ALWAYS_2D = 1, ALWAYS_3D = 2 } |
| void | SetResolveCoincidentTopology (int mode) |
| vtkMapper settings. More... | |
| void | SetPolygonOffsetParameters (double factor, double units) |
| void | SetLineOffsetParameters (double factor, double units) |
| void | SetPointOffsetParameter (double units) |
| void | SetZShift (double a) |
| virtual void | SetOutlineThreshold (vtkIdType) |
| Set the number of cells (in millions) when the representations show try to use outline by default. More... | |
| virtual vtkIdType | GetOutlineThreshold () |
| virtual void | SetDefaultInteractionMode (int) |
| Set the default interaction mode. More... | |
| virtual int | GetDefaultInteractionMode () |
| virtual void | SetPointPickingRadius (int) |
| Set the radius in pixels to include for finding the closet point when selecting a point on render view. More... | |
| virtual int | GetPointPickingRadius () |
| virtual void | SetDisableIceT (bool) |
| EXPERIMENTAL: Add ability to disable IceT. More... | |
| virtual bool | GetDisableIceT () |
| virtual void | SetEnableFastPreselection (bool) |
| Enable fast preselection. More... | |
| virtual bool | GetEnableFastPreselection () |
| static vtkPVRenderViewSettings * | New () |
| static vtkPVRenderViewSettings * | SafeDownCast (vtkObject *o) |
| static vtkPVRenderViewSettings * | GetInstance () |
| Access the singleton. More... | |
| vtkPVRenderViewSettings () | |
| ~vtkPVRenderViewSettings () override | |
Protected Attributes | |
| int | DefaultInteractionMode |
| vtkIdType | OutlineThreshold |
| int | PointPickingRadius |
| bool | DisableIceT |
| bool | EnableFastPreselection |
vtkPVRenderViewSettings is a singleton used to keep track of selections for various configurable parameters used by vtkPVRenderView. All class to vtkPVRenderViewSettings::New() returns a reference to the singleton instance.
Definition at line 33 of file vtkPVRenderViewSettings.h.
Definition at line 37 of file vtkPVRenderViewSettings.h.
| anonymous enum |
| Enumerator | |
| DO_NOTHING | |
| OFFSET_FACES | |
| OFFSET_LINES_AND_VERTS | |
| ZSHIFT | |
Definition at line 45 of file vtkPVRenderViewSettings.h.
| anonymous enum |
| Enumerator | |
| AUTOMATIC | |
| ALWAYS_2D | |
| ALWAYS_3D | |
Definition at line 73 of file vtkPVRenderViewSettings.h.
vtkMapper settings.
vtkMapper settings.
This only after single point selections i.e. when selecting a regions this radius is not respected.
When enabled, the preselection is computed using the visible geometry. This avoids a call to the extract selection filter each time the mouse moves, improving a lot the preselection highlight display, especially for big datasets.
Definition at line 120 of file vtkPVRenderViewSettings.h.
Definition at line 121 of file vtkPVRenderViewSettings.h.
Definition at line 122 of file vtkPVRenderViewSettings.h.
Definition at line 123 of file vtkPVRenderViewSettings.h.
Definition at line 124 of file vtkPVRenderViewSettings.h.
