object for general options. More...
#include <vtkPVGeneralSettings.h>
| enum | { DEFAULT_TIME_STEP_UNCHANGED, DEFAULT_TIME_STEP_FIRST, DEFAULT_TIME_STEP_LAST } |
| Enum for DefaultTimeStep. More... | |
| enum | { MIXED = 0, SCIENTIFIC, FIXED } |
| enum | { ALL_IN_ONE = 0, SEPARATE_DISPLAY_PROPERTIES = 1, SEPARATE_VIEW_PROPERTIES = 2, ALL_SEPARATE = 3 } |
| void | SetInheritRepresentationProperties (bool val) |
| Forwarded for vtkSMParaViewPipelineControllerWithRendering. More... | |
| void | SetIgnoreNegativeLogAxisWarning (bool val) |
| bool | GetIgnoreNegativeLogAxisWarning () |
| void | SetAutoConvertProperties (bool val) |
| Automatically convert data arrays as needed by filters including converting cell arrays to point arrays, or vice versa, and extracting single components from multi-component arrays. More... | |
| bool | GetAutoConvertProperties () |
| virtual int | GetBlockColorsDistinctValues () |
| Determines the number of distinct values in vtkBlockColors. More... | |
| virtual void | SetBlockColorsDistinctValues (int) |
| virtual bool | GetAutoApply () |
| Automatically apply changes in the 'Properties' panel. More... | |
| virtual void | SetAutoApply (bool) |
| virtual bool | GetAutoApplyActiveOnly () |
| virtual void | SetAutoApplyActiveOnly (bool) |
| void | SetEnableAutoMPI (bool) |
| Enable auto-mpi. More... | |
| bool | GetEnableAutoMPI () |
| void | SetAutoMPILimit (int val) |
| Set the core limit for auto-mpi. More... | |
| int | GetAutoMPILimit () |
| virtual char * | GetDefaultViewType () |
| Get/Set the default view type. More... | |
| virtual void | SetDefaultViewType (const char *) |
| virtual int | GetTransferFunctionResetMode () |
| Get/Set the transfer function reset mode. More... | |
| virtual void | SetTransferFunctionResetMode (int) |
| void | SetCacheGeometryForAnimation (bool val) |
| Set when animation geometry caching is enabled. More... | |
| bool | GetCacheGeometryForAnimation () |
| void | SetAnimationGeometryCacheLimit (unsigned long val) |
| Set the animation cache limit in KBs. More... | |
| virtual unsigned long | GetAnimationGeometryCacheLimit () |
| virtual void | SetAnimationTimePrecision (int) |
| Set the precision of the animation time toolbar. More... | |
| virtual int | GetAnimationTimePrecision () |
| virtual void | SetAnimationTimeNotation (int) |
| Set the notation for the animation time toolbar. More... | |
| virtual int | GetAnimationTimeNotation () |
| virtual void | SetShowAnimationShortcuts (bool) |
| Set when animation shortcuts are shown. More... | |
| virtual bool | GetShowAnimationShortcuts () |
| virtual void | ShowAnimationShortcutsOn () |
| virtual void | ShowAnimationShortcutsOff () |
| virtual void | SetResetDisplayEmptyViews (bool) |
| Set whether to reset display when showing a representation in an empty view. More... | |
| virtual bool | GetResetDisplayEmptyViews () |
| virtual void | ResetDisplayEmptyViewsOn () |
| virtual void | ResetDisplayEmptyViewsOff () |
| virtual void | SetRealNumberDisplayedPrecision (int) |
| Get/Set the precision of real number displayed in widgets or views. More... | |
| virtual int | GetRealNumberDisplayedPrecision () |
| virtual void | SetPropertiesPanelMode (int) |
| Properties panel configuration. More... | |
| virtual int | GetPropertiesPanelMode () |
| virtual void | SetLockPanels (bool) |
| Set whether to dock widgets into place. More... | |
| virtual bool | GetLockPanels () |
| void | SetLoadAllVariables (bool val) |
| Load all variables when loading a data set. More... | |
| bool | GetLoadAllVariables () |
| void | SetLoadNoChartVariables (bool val) |
| Load no variables when showing a 2D chart. More... | |
| bool | GetLoadNoChartVariables () |
| virtual void | SetGUIFontSize (int) |
| Get/Set the GUI font size. More... | |
| virtual int | GetGUIFontSize () |
| virtual void | SetGUIOverrideFont (bool) |
| Get/Set whether the GUIFontSize should be used. More... | |
| virtual bool | GetGUIOverrideFont () |
| virtual void | SetConsoleFontSize (int) |
| Console font size. More... | |
| virtual int | GetConsoleFontSize () |
| virtual void | SetColorByBlockColorsOnApply (bool) |
Automatically color by vtkBlockColors if array is present on Apply. More... | |
| virtual bool | GetColorByBlockColorsOnApply () |
| void | SetEnableStreaming (bool) |
| Turn on streamed rendering. More... | |
| virtual bool | GetEnableStreaming () |
| virtual void | EnableStreamingOn () |
| virtual void | EnableStreamingOff () |
| static vtkPVGeneralSettings * | New () |
| static vtkPVGeneralSettings * | SafeDownCast (vtkObject *o) |
| static vtkPVGeneralSettings * | GetInstance () |
| Access the singleton. More... | |
| vtkPVGeneralSettings () | |
| ~vtkPVGeneralSettings () override | |
vtkPVGeneralSettings keeps track of general options in a ParaView application. This is a singleton. All calls to vtkPVGeneralSettings::New() return a pointer to the same global instance (with reference count incremented as expected).
Definition at line 33 of file vtkPVGeneralSettings.h.
Definition at line 37 of file vtkPVGeneralSettings.h.
| anonymous enum |
| Enumerator | |
| DEFAULT_TIME_STEP_UNCHANGED | |
| DEFAULT_TIME_STEP_FIRST | |
| DEFAULT_TIME_STEP_LAST | |
Definition at line 110 of file vtkPVGeneralSettings.h.
| anonymous enum |
Enum for ScalarBarMode.
| Enumerator | |
| AUTOMATICALLY_SHOW_AND_HIDE_SCALAR_BARS | |
| AUTOMATICALLY_HIDE_SCALAR_BARS | |
| MANUAL_SCALAR_BARS | |
Definition at line 129 of file vtkPVGeneralSettings.h.
| anonymous enum |
| Enumerator | |
| MIXED | |
| SCIENTIFIC | |
| FIXED | |
Definition at line 163 of file vtkPVGeneralSettings.h.
| anonymous enum |
This enum specifies which notations to use for displaying real number values.
| Enumerator | |
| DISPLAY_REALNUMBERS_USING_SCIENTIFIC_NOTATION | |
| DISPLAY_REALNUMBERS_USING_FIXED_NOTATION | |
Definition at line 202 of file vtkPVGeneralSettings.h.
| anonymous enum |
| Enumerator | |
| ALL_IN_ONE | |
| SEPARATE_DISPLAY_PROPERTIES | |
| SEPARATE_VIEW_PROPERTIES | |
| ALL_SEPARATE | |
Definition at line 233 of file vtkPVGeneralSettings.h.
| void vtkPVGeneralSettings::SetAutoConvertProperties | ( | bool | val | ) |
Forwards the call to vtkSMInputArrayDomain::SetAutomaticPropertyConversion.
| bool vtkPVGeneralSettings::GetAutoConvertProperties | ( | ) |
This array is added to each block if the dataset is a composite dataset. The array has one value set to (blockIndex % BlockColorsDistinctValues)
| void vtkPVGeneralSettings::SetEnableAutoMPI | ( | bool | ) |
Enable auto-mpi.
Forwarded to vtkProcessModuleAutoMPI.
| bool vtkPVGeneralSettings::GetEnableAutoMPI | ( | ) |
Enable auto-mpi.
| void vtkPVGeneralSettings::SetAutoMPILimit | ( | int | val | ) |
| int vtkPVGeneralSettings::GetAutoMPILimit | ( | ) |
| void vtkPVGeneralSettings::SetScalarBarMode | ( | int | ) |
| void vtkPVGeneralSettings::SetCacheGeometryForAnimation | ( | bool | val | ) |
| bool vtkPVGeneralSettings::GetCacheGeometryForAnimation | ( | ) |
| void vtkPVGeneralSettings::SetAnimationGeometryCacheLimit | ( | unsigned long | val | ) |
Accepted values are MIXED, SCIENTIFIC, and FIXED.
Get/Set the notation of real number displayed in widgets or views.
| void vtkPVGeneralSettings::SetInheritRepresentationProperties | ( | bool | val | ) |
| void vtkPVGeneralSettings::SetIgnoreNegativeLogAxisWarning | ( | bool | val | ) |
| bool vtkPVGeneralSettings::GetIgnoreNegativeLogAxisWarning | ( | ) |
| void vtkPVGeneralSettings::SetLoadAllVariables | ( | bool | val | ) |
| bool vtkPVGeneralSettings::GetLoadAllVariables | ( | ) |
| void vtkPVGeneralSettings::SetLoadNoChartVariables | ( | bool | val | ) |
| bool vtkPVGeneralSettings::GetLoadNoChartVariables | ( | ) |
This is used only if GUIOverrideFont is true.
Console font size.
Console font size.
| void vtkPVGeneralSettings::SetEnableStreaming | ( | bool | ) |
Definition at line 317 of file vtkPVGeneralSettings.h.
Definition at line 318 of file vtkPVGeneralSettings.h.
Definition at line 319 of file vtkPVGeneralSettings.h.
Definition at line 320 of file vtkPVGeneralSettings.h.
Definition at line 321 of file vtkPVGeneralSettings.h.
Definition at line 322 of file vtkPVGeneralSettings.h.
Definition at line 323 of file vtkPVGeneralSettings.h.
Definition at line 324 of file vtkPVGeneralSettings.h.
Definition at line 325 of file vtkPVGeneralSettings.h.
Definition at line 326 of file vtkPVGeneralSettings.h.
Definition at line 327 of file vtkPVGeneralSettings.h.
Definition at line 328 of file vtkPVGeneralSettings.h.
Definition at line 329 of file vtkPVGeneralSettings.h.
Definition at line 330 of file vtkPVGeneralSettings.h.
Definition at line 331 of file vtkPVGeneralSettings.h.
Definition at line 332 of file vtkPVGeneralSettings.h.
Definition at line 333 of file vtkPVGeneralSettings.h.
Definition at line 334 of file vtkPVGeneralSettings.h.
Definition at line 335 of file vtkPVGeneralSettings.h.
Definition at line 336 of file vtkPVGeneralSettings.h.
Definition at line 337 of file vtkPVGeneralSettings.h.
