abstract base class for all in situ pipelines. More...
#include <vtkInSituPipeline.h>
| virtual bool | Initialize () |
| Initialize is called once before the first call to 'Execute'. More... | |
| virtual bool | Execute (int timestep, double time)=0 |
| virtual bool | Finalize () |
| Called once before the in situ analysis is finalized. More... | |
| static vtkInSituPipeline * | SafeDownCast (vtkObject *o) |
| vtkInSituPipeline () | |
| ~vtkInSituPipeline () | |
vtkInSituPipeline is an abstract base-class for all in situ analysis pipelines.
A pipeline has three stages: Initialize, Execute and Finalize.
Initialize is called exactly once before the first call to Execute. If Initialize returns false, the initialization is deemed failed and pipeline is skipped for rest of the execution i.e. either Execute nor Finalize will be called.
Execute is called on each cycle. If the method returns false, then the execution is deemed failed and the Execute method will not be called in subsequent cycles.
If Initialize succeeded, then Finalize is called as the end of the simulation execution. Finalize is called even if Execute returned failure. However, it will not be called if Initialize returned failure too.
Definition at line 47 of file vtkInSituPipeline.h.
Definition at line 50 of file vtkInSituPipeline.h.
Reimplemented in vtkInSituPipelineIO, and vtkInSituPipelinePython.
inlinevirtual |
Definition at line 56 of file vtkInSituPipeline.h.
Implemented in vtkInSituPipelineIO, and vtkInSituPipelinePython.
inlinevirtual |
Definition at line 66 of file vtkInSituPipeline.h.
