help class for python modules More...
#include <vtkInitializationHelper.h>
| void | PrintSelf (ostream &, vtkIndent) override |
| static vtkInitializationHelper * | SafeDownCast (vtkObject *o) |
| static void | Initialize (const char *executable, int type) |
| Initializes the server manager. More... | |
| static void | Initialize (const char *executable, int type, vtkPVOptions *options) |
| static void | Initialize (int argc, char **argv, int type, vtkPVOptions *options) |
| Alternative API to initialize the server manager. More... | |
| static void | Finalize () |
| Finalizes the server manager. More... | |
| static std::string | GetUserSettingsDirectory () |
| Get directory for user settings file. More... | |
| static std::string | GetUserSettingsFilePath () |
| Get file path for the user settings file. More... | |
| static void | StandaloneInitialize () |
| Initialization for standalone executables linking against a PV library. More... | |
| static void | StandaloneFinalize () |
| static void | SetLoadSettingsFilesDuringInitialization (bool) |
| During initialization, vtkInitializationHelper reads "settings" files for configuring vtkSMSettings. More... | |
| static bool | GetLoadSettingsFilesDuringInitialization () |
| static void | SetOrganizationName (const std::string &organizationName) |
| Sets the organization producing this application. More... | |
| static const std::string & | GetOrganizationName () |
| static void | SetApplicationName (const std::string &appName) |
| Sets the name of the application. More... | |
| static const std::string & | GetApplicationName () |
| vtkInitializationHelper () | |
| ~vtkInitializationHelper () override | |
Static Protected Member Functions | |
| static void | LoadSettings () |
| Load user and site settings. More... | |
This class is used by the python modules when they are loaded from python (as opposed to pvpython). It simply initializes the server manager so that it can be used.
Definition at line 33 of file vtkInitializationHelper.h.
Definition at line 36 of file vtkInitializationHelper.h.
inlineprotected |
Definition at line 121 of file vtkInitializationHelper.h.
inlineoverrideprotected |
Definition at line 122 of file vtkInitializationHelper.h.
Do not use the server manager before calling this.
Do not use the server manager before calling this. In this variant, one passes in a vtkPVOptions instance.
--no-mpi and --mpi options are handled specially, by this call. If you want to pass those to vtkProcessModule so it doesn't (or does) initialize MPI, set the corresponding ivars on the options object passed in.
This takes in the command line arguments and the vtkPVOptions instance to use to process the command line options.
Do not use the server manager after calling this.
This is needed to insure that linker does not remove object factories' auto init during static linking. It also cleans up after protobuf.
To disable this processing of the settings file for an application (e.g. in Catalyst), turn this off. On by default.
This is "ParaView" by default, but can be different for branded applications.
The last character is always the file path separator appropriate for the system.
staticprotected |
