| virtual std::string | GetCurrentFileName (const char *fname, int timestep, double time) |
| | Helper function to format a filename using current timestep and time. More...
| virtual void | SetFileName (const char *) |
| | Get/Set the filename. More...
| virtual char * | GetFileName () |
| virtual void | SetChannelName (const char *) |
| | Get/Set the channel name. More...
| virtual char * | GetChannelName () |
| bool | Initialize () override |
| | vtkInSituPipeline API implementaton More...
| bool | Execute (int timestep, double time) override |
| bool | Finalize () override |
insitu pipeline for IO
vtkInSituPipelineIO is a hard-coded pipeline that can be used to save out data using writers supported by ParaView.
Definition at line 35 of file vtkInSituPipelineIO.h.
